[CentOs] Login incorrect met vsftpd
  • 419 views sinds 30-01-2008
  • r0y89
  • Laatst online: 09-09 09:12
Hey mensen,
Ik heb het volgende probleem.
Als ik probeer in te loggen met een willekeurige ftp client op me server krijg ik login incorrect.
Hier even mijn vsftpd config:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
# Example config file /etc/vsftpd/vsftpd.conf
# The default compiled in settings are fairly paranoid. This sample file
# loosens things up a bit, to make the ftp daemon more usable.
# Please see vsftpd.conf.5 for all compiled in defaults.
# READ THIS: This example file is NOT an exhaustive list of vsftpd options.
# Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
# capabilities.
# Allow anonymous FTP? (Beware - allowed by default if you comment this out).
anonymous_enable=No
# Uncomment this to allow local users to log in.
local_enable=YES
# Uncomment this to enable any form of FTP write command.
write_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
local_umask=022
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
# Uncomment this if you want the anonymous FTP user to be able to create
# new directories.
#anon_mkdir_write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
#chown_uploads=YES
#chown_username=whoever
# You may override where the log file goes if you like. The default is shown
# below.
xferlog_file=/var/log/vsftpd.log
# If you want, you can have your log file in standard ftpd xferlog format
xferlog_std_format=NO
# You may change the default value for timing out an idle session.
#idle_session_timeout=600
# You may change the default value for timing out a data connection.
#data_connection_timeout=120
# It is recommended that you define on your system a unique user which the
# ftp server can use as a totally isolated and unprivileged user.
#nopriv_user=ftpsecure
# Enable this and the server will recognise asynchronous ABOR requests. Not
# recommended for security (the code is non-trivial). Not enabling it,
# however, may confuse older FTP clients.
#async_abor_enable=YES
# By default the server will pretend to allow ASCII mode but in fact ignore
# the request. Turn on the below options to have the server actually do ASCII
# mangling on files when in ASCII mode.
# Beware that turning on ascii_download_enable enables malicious remote parties
# to consume your I/O resources, by issuing the command "SIZE /big/file" in
# ASCII mode.
# These ASCII options are split into upload and download because you may wish
# to enable ASCII uploads (to prevent uploaded scripts etc. from breaking),
# without the DoS risk of SIZE and ASCII downloads. ASCII mangling should be
# on the client anyway..
#ascii_upload_enable=YES
#ascii_download_enable=YES
# You may fully customise the login banner string:
ftpd_banner=Welcome to r0y's FTP service.
# You may specify a file of disallowed anonymous e-mail addresses. Apparently
# useful for combatting certain DoS attacks.
#deny_email_enable=YES
# (default follows)
#banned_email_file=/etc/vsftpd.banned_emails
# You may specify an explicit list of local users to chroot() to their home
# directory. If chroot_local_user is YES, then this list becomes a list of
# users to NOT chroot().
chroot_list_enable=YES
# (default follows)
chroot_list_file=/etc/vsftpd/chroot_list
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
pam_service_name=vsftpd
userlist_enable=YES
userlist_file=/etc/vsftpd.user_list
userlist_deny=YES
#enable for standalone mode
listen=YES
tcp_wrappers=YES
log_ftp_protocol=YES
De chroot list staat op de juiste locatie. De users heb ik ook goed aangegeven in de chroot list. Gebruikersnaam en wachtwoord die kloppen.
Stukje uit me log:
Fri Oct 19 22:24:19 2007 [pid 5232] FTP command: Client "ip", "USER roy"
Fri Oct 19 22:24:19 2007 [pid 5232] [roy] FTP response: Client "ip", "331 Please specify the password."
Fri Oct 19 22:24:26 2007 [pid 5232] [roy] FTP command: Client "ip", "PASS <password>"
Fri Oct 19 22:24:29 2007 [pid 5231] [roy] FAIL LOGIN: Client "ip"
Fri Oct 19 22:24:29 2007 [pid 5232] [roy] FTP response: Client "ip", "530 Login incorrect."
Ik hoop dat jullie me verder kunnen helpen.
Alvast bedankt!
Edit: even wat overzichtelijker gemaakt
  • deadinspace
  • Laatst online: 14-10 18:32
deadinspace
The what goes where now?
Hoi r0y89, welkom op GoT :)
Het is hier gebruikelijk om stukken configuratiefile en log en dergelijke in [code] [/code] blokken te zetten voor de overzichtelijkheid ;)
Verder is het praktisch als je vermeldt hoe je vsftpd geinstalleerd hebt. Is dit via de package manager, of heb je hem zelf van source gebuild?
Om je probleem op te lossen kun je waarschijnlijk het beste je config versimpelen totdat het wel werkt, en dan kijken welke optie nou de boosdoener was, en waarom. Je zou bijvoorbeeld kunnen proberen chroot_list_enable, userlist_enable en tcp_wrappers eens uit te zetten. Vergeet ook niet vsftpd te herstarten na wijzigingen aan de configuratie.
  • r0y89
deadinspace schreef op dinsdag 23 oktober 2007 @ 17:54:
Bedankt voor je reply, De ftp server heb ik tijdens de installatie can centos 4.4 mee geinstalleerd. Ik zal die functies even aanpassen.
  • r0y89
Functies aangepast maar geen positief resultaat.
