[JAVA]Repaint forceren
  • 2.145 views sinds 30-01-2008
  • pderaaij
  • Laatst online: 18-08-2025
Ik ben bezig met een opdrachtje voor mijn studie (LOI Informatica) en loop tegen een probleempje aan, wat voor de guru's hier waarschijnlijk zo op te lossen is.
Java:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
package kreta;
import java.awt.*;
import java.awt.event.*;
import java.util.Vector;
import javax.swing.*;
public class Kreta extends JApplet {
    public JPanel buttonPanel;
    public JPanel contentPanel;
    public JPanel mainPanel;
    private Vector vecMeals;
    private Menu   menu;
    public Kreta() {
        menu = new Menu();
        mainPanel = new JPanel();
        contentPanel = new JPanel();
        vecMeals = new Vector();
    public void createButtonPanel() {
        buttonPanel = new JPanel();
        JButton btnMealList = new JButton("Gerecht overzicht");
        JButton btnAddMeal  = new JButton("Gerecht toevoegen");
        btnMealList.addActionListener(new btnMealList());
        btnAddMeal.addActionListener(new btnAddMeal());
        buttonPanel.add(btnMealList);
        buttonPanel.add(btnAddMeal);
    public void createMealListPanel() {
        vecMeals = menu.getAllMeals();
        JList mealList = new JList(vecMeals);
        contentPanel.removeAll();
        contentPanel.add(mealList);
        repaint();
    public void addMealPanel() {
        contentPanel.add(new JLabel("test"));
        paintFrame();
    public void init() {
        // create panels
        createButtonPanel();
        createMealListPanel();
        paintFrame();
    public void paintFrame() {
        mainPanel.removeAll();
        // add panels to the main panel
        mainPanel.add(new JLabel("Receptoverzicht"), BorderLayout.NORTH);
        mainPanel.add(buttonPanel, BorderLayout.SOUTH);
        mainPanel.add(contentPanel, BorderLayout.CENTER);
        mainPanel.invalidate();
        // add mainPanel to the applet
        getContentPane().add(mainPanel);
        getContentPane().invalidate();
        getContentPane().repaint();
    public class btnMealList implements ActionListener {
        public void actionPerformed(ActionEvent ev) {
    public class btnAddMeal implements ActionListener {
            addMealPanel();
Standaard krijgt men bij opening dit scherm te zien:
Afbeeldingslocatie: http://home.kabelfoon.nl/~pderaaij/prog1.jpg
Als men dan op de knop gerecht toevoegen drukt zou je nu test in beeld moeten krijgen, maar je krijgt dit:
Afbeeldingslocatie: http://home.kabelfoon.nl/~pderaaij/prog2.jpg
Als ik iets aan de grootte verander krijg ik wel een volledige repaint en krijg je wat ik direct wil:
Afbeeldingslocatie: http://home.kabelfoon.nl/~pderaaij/prog3.jpg
Mijn vraag is dus: hoe forceer ik een volledige repaint? Ik heb al geprobeerd:
mainPanel.repaint();
maar dat werkt ook niet... iemand hier ideeën??
  • MrBucket
  • Laatst online: 29-10-2022
pderaaij schreef op zaterdag 20 oktober 2007 @ 14:07:
Nou, dat lijkt nog tegen te vallen, zie o.a. deze thread: http://forum.java.sun.com/thread.jspa?threadID=497595. :)
Maar, de suggestie die hier geopperd wordt is om revalidate() aan te roepen (zie replies 16 en 17 op de 2e pagina).
  • Enfer
  • Laatst online: 19-09 12:56
Probeer eens de methode revalidate() van een JPanel.. Als je componenten toevoegt wil het wel eens helpen om te revalidaten..
  • pderaaij
en dat werkt perfect!
Ook te simpel eigenlijk, dat ik er zelf niet opkwam |:( |:(
Bedankt in ieder geval!
[ Voor 13% gewijzigd door pderaaij op 20-10-2007 14:48 ]
  • Enfer
En even voor de duidelijkheid:
void revalidate() Request that the component and its affected containers be laid out again. You should not generally need to invoke this method unless you explicitly change a component's size/alignment hints after it's visible or change a containment hierarchy after it is visible. Always invoke repaint after revalidate.
