[Win2003SP2] GUID DNS resolve failed
  • Dutch2007
  • Laatst online: 06-03 08:45
najah zoals de topic zegt, ik heb de volgende error...
een GUID DNS error...
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: Default-First-Site-Name\OMG-SERVER
Starting test: Connectivity
The host 8bfb58a7-3132-4659-8a26-41a007fa7dee._msdcs.omg-gaming.local could not be resolved to an
IP address. Check the DNS server, DHCP, server name, etc
Although the Guid DNS name
(8bfb58a7-3132-4659-8a26-41a007fa7dee._msdcs.omg-gaming.local)
couldn't be resolved, the server name (omg-server.omg-gaming.local)
resolved to the IP address (192.168.1.105) and was pingable. Check
that the IP address is registered correctly with the DNS server.
......................... OMG-SERVER failed test Connectivity
Doing primary tests
Skipping all tests, because server OMG-SERVER is
not responding to directory service requests
Running partition tests on : ForestDnsZones
Starting test: CrossRefValidation
......................... ForestDnsZones passed test CrossRefValidation
Starting test: CheckSDRefDom
......................... ForestDnsZones passed test CheckSDRefDom
Running partition tests on : DomainDnsZones
......................... DomainDnsZones passed test CrossRefValidation
......................... DomainDnsZones passed test CheckSDRefDom
Running partition tests on : Schema
......................... Schema passed test CrossRefValidation
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test CrossRefValidation
......................... Configuration passed test CheckSDRefDom
Running partition tests on : omg-gaming
......................... omg-gaming passed test CrossRefValidation
......................... omg-gaming passed test CheckSDRefDom
Running enterprise tests on : omg-gaming.local
Starting test: Intersite
......................... omg-gaming.local passed test Intersite
Starting test: FsmoCheck
......................... omg-gaming.local passed test FsmoCheck
DNS zelf werkt wel, en kan ook pc's toevoegen aan het domain, maar wilde nog een 2e server toevoegen als backup server en jah, je raad em al, dat gaat dus mooi niet werken momenteel, suggestie's hoe dit het beste/snelste op te lossen is?
heb al verschillende dingen opgezocht maar werkten allen niet... en zie niet zo 1 2 3 hoe ik de GUID link aan de DC/server...
ok deze heb ik "vrij" eenvoudig opgelost, door..
8bfb58a7-3132-4659-8a26-41a007fa7dee als cname in te stellen voor omg-server.omg-gaming.local..
maar nu kan ik de 2e server nog steeds niet toevoegen...
volgende error krijg ik dan
The following error occurred when DNS was queried for the service location (SRV) resource record used to locate a domain controller for domain omg-gaming.local:
The error was: "DNS name does not exist."
(error code 0x0000232B RCODE_NAME_ERROR)
The query was for the SRV record for _ldap._tcp.dc._msdcs.omg-gaming.local
Common causes of this error include the following:
- The DNS SRV records required to locate a domain controller for the domain are not registered in DNS. These records are registered with a DNS server automatically when a domain controller is added to a domain. They are updated by the domain controller at set intervals. This computer is configured to use DNS servers with following IP addresses:
217.19.16.132
217.19.16.131
192.168.1.105
- One or more of the following zones do not include delegation to its child zone:
omg-gaming.local
local
. (the root zone)
For information about correcting this problem, click Help
(ook zonder de 217 ip's werkt ut niet)
[ Voor 16% gewijzigd door Dutch2007 op 19-10-2007 16:44 ]
  • Question Mark
  • Laatst online: 20-10 15:07
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Vul op alle Domain controllers enkel je interne DNS-servers in (die geconfigureerd zijn voor auto update). Restart vervolgens de Netlogon en DHCP-client service op je DC's eens en test nog eens?
Check ook je evenlog even na het herstarten van de services op errors.
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Die guid-achtige records moet je niet met de hand aanmaken, dan is ownership etc niet goed geregeld, kan het ook weer zijn dat ze niet goed zijn.
Mijn spoorwegfotografie
  • Dutch2007
ok, zal ze morge (zondag), en anders maandag, uns ff die GUID deleten, moet ie die dan zelf aanmaken?, en als ie dat niet doet, hoe fix ik dat ie ze wel aanmaakt?
  • alt-92
alt-92
ye olde farte
Dat legt Question Mark je net uit.
Als je niet begrijpt waar hij het over heeft, dat kan, maar zeg dat dan wel eerlijk :)
