Aanpassen baudrate van Serial/COM poort
  • 2.890 views sinds 30-01-2008
  • Extreme smell
  • Laatst online: 05-10 22:19
Beste tweakers,
Ik probeer hier een Dymo LabelWriter SE300 aan de praat te krijgen op Windows XP.
Nu is dit nog niet zo makkelijk aangezien deze printer eigenlijk bedoeld is om in DOS/Unix gebruikt te worden. Maar er zijn manieren om hem toch aan de praat te krijgen. Zo plukte ik dit van de Dymo support site:
The SE300 is not listed in the DYMO Label Software (DLS) because it is designed to work in a DOS/UNIX environment. As a workaround, however, you can do the following:
1. Download the LabelWriter XL and EL Series Print Drivers for Windows from the Drivers and Downloads page.
2. Select a location on your computer for the file. You can create a new folder if you wish (i.e. c:\DYMOFILE).
3. Once the download is complete, run the file.
4.Select a location on your computer where the executable will unzip the files to. Make a note of this location.
5. Open the Printers folder. Based on Operating System and system configuration, the Printers folder can be accessed in one of the following ways:
Start > Settings > Printers
Start > Control Panel > Printers & Other Hardware > View installed printers or fax printers
Start > Control Panel > Printers & Faxes
6. In the Printers folder click on File and select Add Printer.
7.Proceed through the Add Printer Wizard. You must install the printer as an LabelWriter EL 60. When prompted to select a Make/Model printer, select Have Disk and browse to the location where you previously unzipped the files contained in the executable you downloaded.
8. Select the DYMO.inf file and continue with the Add Printer Wizard until it has completed.
9. Once the printer has been added to the Printers folder, remember to ensure that the BAUD rate on the SE300 matches the BAUD rate for the Serial/COM port in Windows. If the BAUD rates do not match, the LabelWriter will not print properly.
10. If you'd like, you can use the LabelWriter in conjunction with DLS. Simply download and install DLS 6.1.1. Click here to be redirected to the Drivers and Downloads section.
Dit is allemaal wel gelukt, alleen het vetgedrukte stuk wil niet lukken.
Ik probeerde het eerst zonder dat te doen, en als ik dan een label print komt er allemaal zooi uitgeprint, dus het lijkt mij dat er iets niet goed zit in de baudrates.
Ik weet hoe ik de baudrate van de printer kan aanpassen dmv hyperterminal, maar hoe kan ik nou de baudrate van mijn Serial/COM poort bekijken? Help alstublieft, ik ben hier al een aardige tijd mee aan het klooien en het wil gewoon niet lukken.
Mvg ;)
  • DrivinUCrazy
DrivinUCrazy
Vechte, valle en opstoan
Start -> instellingen -> configuratiescherm -> Systeem
Dan naar het tabblad "hardware", en klikken op de knop apparaatbeheer.
Daarna zoek je bij "poorten" de gewenste COMpoort op, en open je daarvan de eigenschappen. Daar kun je deze instellingen aanpassen.
  • Rone
Rone
Moderator Tweaking
En als dat niet wil lukken kan het ook via de commandoprompt (Start » Uitvoeren » cmd).
Het commando 'mode' geeft onder andere de instellingen van de COM-poorten weer.
C:\>mode
Status for device LPT1:
    Printer output is not being rerouted.
Status for device COM1:
    Baud:            4800
    Parity:          None
    Data Bits:       7
    Stop Bits:       1
    Timeout:         OFF
    XON/XOFF:        OFF
    CTS handshaking: OFF
    DSR handshaking: OFF
    DSR sensitivity: OFF
    DTR circuit:     ON
    RTS circuit:     ON
Vervolgens kun je het ook wijzigen door middel van het volgende commando:
mode com1:9600,n,8,1,p
Dit stelt COM1 in op 9600 baud, geen parity, 8 databits, 1 stopbit en XON/XOFF (standaard). :)
PC1: 9800X3D + RX 9070 XT
PC2: 5800X3D + RTX 3080
  • Extreme smell
Ok bedankt, nu ik heb gevonden hoe en wat ik moet instellen, probeerde ik een verbinding te maken dmv HyperTerminal.
Ik deed het volgende:
Ik opende Hyperterminal > Nieuwe Verbinding > Naam: Dymo LabelWriter EL60 en een icoontje > OK > Verbinding maken via: COM1 Poort > OK > Bits per seconde: 9600 | Databits: 8 | Pariteit: Geen | Stopbits: 1 | Datatransportbesturing: Hardware > OK > Kan COM1 niet openen. Controleer de poortinstellingen.
en toen hield het voor mij op :S ik had dus maar de COM1 poort ook op 9600 gezet, en er veranderde niks.
Ik heb geen ervaring met dat apparaat, maar de printerdriver die je hebt geinstalleerd zal wel de compoort blokkeren. Als je dat apparaat in wil stellen moet je hem even in een andere compoort steken of de driver verwijderen.
  • Extreme smell
Nop, ik kan hem niet zonder driver installeren, en ik heb ook geen andere COM poort. Ik stuur nog maar eens een email naar de Dymo support.
