[iPod Touch] Linkerzijde van de scherm werkt nauwelijks (EN)
  • 127 views sinds 30-01-2008
Omdat ik inmiddels deze thread over 3 andere forums heb gepost (zonder reactie) heb ik niet echt zin om mijn verhaal te vertalen en het is niet also jullie geen engels kunnen ;)
I got my touch today and checked it out and after a while i noticed that the left side of the screen is hardly responding, the weird part is that when im in the settings adjusting some things like entering my Wi-Fi WEP code all of the keyboard is responding flawlessly but if i go back Home and try to click on either: Safari, Clock or Music it's barely responding.
Also when im in music playing a song and want to press the back button it wont work unless it sorta slide my finger to the left but on the right the buttons work just pressing them.
This is exremely annoying and i hope that it's not an hardware bug but I'm afraid it is.
If anyone has experienced or heard about a problem similar like mine, please reply on this topic.
Thanks,
MDC
edit
I just went to HTTP Proxy to test the keyboard, and there the W and A werent working, but the Q and E were.
edit2
Okay this is extremely odd, so after just messing with the keyboard for a minute (holding my finger down on a letter and just moving it around to see how it responds to the left) the A started to flip out, popping up a few times and then left. Now it's working perfect... I'll post up results after a while, cause it might act up later.
I also already tried putting it to sleep mode and waking it up, switching it completely off and everything but it's still working.
edit3
Okay so I've messed around with it all day now and it did good for a long time but then i removed the music that was on it and it started to go crazy on me again, I did my keyboard trick and i got it to work again but later it went away and it just went back and forth a little bit. I'm leaving it untouched now and I'll see what it will do from here on out, it's working good now but if it starts going crazy later I will try getting a new one from my local Apple store.
edit4
So I was messing on YouTube last night and after about 30 minutes or an hour of browsing and watching stuff, pretty much the entire screen in YouTube started flipping on me, i would barely touch it and the volume slider would go left and right, wouldnt let me press "Done" even when I wasn't touching it it would flip, could it be that recognizes the heat of my finger too soon or something?
I plan on sending it back soon through my local Apple Premium Reseller, because this is too crazy.
I can't find a similar problem like mine anywhere yet, so if anyone knows...please reply to this.
  • mOrPhie
  • Laatst online: 29-10 13:00
mOrPhie
Wat verwacht je hier als antwoord? Wat je moet doen is teruggaan met dat ding. Een probleem met een gekocht apparaat valt toch gewoon onder de garantie? :)
Een experimentele community-site: https://technobabblenerdtalk.nl/. DM voor invite code.
humm.. misschien iemand die dit ook mee heeft gemaakt dat die ff zegt wat hij in deze situatie heeft gedaan?...
maar dat kan aan mij liggen hoor, oh nee wacht that the dude said 2.
Ik verwacht niets, ik HOOP op een (normaal) antwoord van mensen die hier misschien eerder iets over hebben gehoord of gezien zodat er misschien een mogelijke oplossing of reden is waarom hij zo doet, lijkt me logisch toch?
Overal is een verklaring voor, ik stuur hem niet zomaar terug als het op te lossen is, ik ben niet zo narrow-minded.
  • Erkel
  • Laatst online: 01-11 18:25
Niet dat ik je wil afzeiken ofzo, maar ik vind dat het netter had geweest wanneer je je verhaal gewoon in het nederlands had neergezet. Je wil er zelf geen moeite voor doen maar wij moeten wel moeite voor jou doen? Sommige stukjes zijn ook moeilijk te volgen btw.
Je hebt best kans dat mensen die niet zo goed in engels zijn het antwoord weten op jou probleem, dus misschien handig om het te vertalen!
C2D E6600 - 2048MB Kingston - Sapphire HD2900XT - 200Gb Samsung - Asus P5B-E
Verwijderd schreef op vrijdag 05 oktober 2007 @ 14:36:
WIj wel, maar dat engels van jou is echt niet te volgen.
  • funk-e
  • Laatst online: 15-10 17:17
gast,
of het nu een hardware of een software fout is.
Je hebt nog garantie op dat ding!
Dus mee terug gaan zou ik zeggen.
en nee dat is niet 'narrow-minded'
...less is more
Het is inderdaad een bekend probleem. Vooral de rechterbovenhoek laat het snel afweten door een productiefout in het kabeltje. De meeste mensen die het probleem bij apple hebben voorgelegd hebben een nieuwe gekregen, een aantal hebben dat niet aangezien die niet zorgvuldig met het apparaat waren omgesprongen.
@Erkel&Qlone
Ik weet niet hoe jullie lezen, hier en daar een missende komma, of letter, that's all, niet zo zeiken andere mensen snappen het prima.
@funk-e:
Dude, denk je dat ik dat niet weet? Ik zei toch al dat ik hem waarschijnlijk terug ga brengen, lees goed.
@mark platvoet:
Oke ten eerste BEDANKT voor een NORMALE reply op mijn thread, zo moeilijk was het toch niet?
ten tweede, de rechterbovenhoek? hmm daar heb ik dan weer geen last van maar het lijkt me duidelijk wel dat ik dezelfde fout heb.
Nogmaals bedankt voor je hulp, hier heb ik tenminste wat aan!
  • Daedalus
Daedalus
Moderator Apple Talk
Keep tryin'
Ten eerste verwachten hier op GoT enige mate van eigen inzet. Dat houd onder andere in dat je een fatsoenlijk topicstart in het Nederlands maakt. Ten tweede is dit een probleem waar je gewoon voor terug moet naar de winkel waar je 'm gekocht hebt. Dit staat ook in Policy Apple Talk (update 2 oktober 2007). Om deze redenen gaat dit topic op slot.
“You know what I've noticed Hobbes? Things don't bug you if you don't think about them. So from now on, I simply won't think about anything I don't like, and I'll be happy all the time!” | 宇多田ヒカル \o/
