Creative DTT2500 op laptop met onboard Realtek ALC655
  • 810 views sinds 30-01-2008
  • Leolinedance
  • Laatst online: 29-07 17:48
Ik heb een Fujitsu Siemens Amilo L1310g
Audio
AC97 ALC655
2 high quality built-in speakers (1.5 W)
microphone in (mono) shared with line-in
Headphone out shared with SPDIF support
sound volume controlled by Hot Keys
Nu is de SPDIF uitgang dus optisch, en de ingang van de speakerset coaxiaal.
Ik kan zo'n convertor kopen, maar is dit de moeite? En gaat dit werken zoals ik wil? (Surround geluid in dvd films, stereo bij mp3's ed.)
features van de chipset:
Features
* Meets performance requirements for audio on PC99/2001 systems
* Meets Microsoft WHQL/WLP 2.0 audio requirements
* 16-bit Stereo full-duplex CODEC with 48KHz sampling rate
* Compliant with AC'97 Rev 2.3 specifications
o Front-Out, Surround-Out, MIC-In and LINE-In Jack Sensing
o 14.318MHz -> 24.576MHz PLL to eliminate crystal
o 12.288MHz BITCLK input
o Integrated PCBEEP generator to save buzzer
o Interrupt capability
* Three analog line-level stereo inputs with 5-bit volume control, LINE_IN, CD, AUX
* High-quality differential CD input
* Two analog line-level mono inputs: PCBEEP, PHONE-IN
* Two software selectable MIC inputs
* Dedicated Front-MIC input for front panel applications (software selectable)
* Boost preamplifier for MIC input
* LINE input shared with surround output; MIC input shared with Center and LFE output
* Built-in 50mW/20ohm amplifier for both Front-out and Surround-Out
* External Amplifier Power Down (EAPD) capability
* Power management and enhanced power saving features
* Supports Power-Off CD function
* Adjustable VREFOUT control
* Supports 48KHz S/PDIF output, complying with AC'97 Rev 2.3 specifications
* Supports 32K/44.1K/48KHz S/PDIF input
* Power support: Digital: 3.3V; Analog: 3.3V/5V
* Standard 48-pin LQFP package
* EAX™ 1.0 & 2.0 compatible
* Direct Sound 3D™ compatible
* A3D™ compatible
* I3DL2 compatible
* HRTF 3D positional audio
* Sensaura™ 3DPA enhancement (optional)
* 10-band software equalizer
* Voice cancellation and key shifting in Karaoke mode
* AVRack® Media Player
* Configuration Panel for improved user convenience
  • Leolinedance
En bovenal, klinkt het een beetje? Of zal ik gewoon een 2.1 speakersetje op de kop tikken..
  • kaajee
  • Laatst online: 25-09 13:02
Ligt er natuurlijk helemaal wat je wilt gaan afspelen.....
Als het alleen maar stereo is (mp3, audio cd's) kun je je wellicht beter de moeite besparen en gewoon een goede 2.1 boxenset kopen.
Als je DVD's met 5.1 (Dolby Digital of DTS) wilt gaan afspelen en optimaal genieten hiervan is een 5.1 boxenset absoluut aan te raden. Vaak zelfs een must omdat de onboard geluidskaarten deze sognalen (DD51 & DTS) niet (analoog) kunnen decoderen......en moet je dus met S/PDIF pass though gaan werken.....
De (DAC's) en decoders in externe apparaten (boxenset, maar met name A/V Receivers) is iha veel beter dan de DAC (digitaal-analoog converter) van de geluidschip van je computer....
Ook voor gewoon stereo geldt dit overigens, in principe presteren de meeste externe DAC's beter dan de onboard geluidskaarten, dus ja, je zult verbetering krijgen. Of jij het ook zult horen is een tweede natuurlijk......
  • Leolinedance
kaajee schreef op dinsdag 02 oktober 2007 @ 23:57:
Ik ben een redelijke muziekliefhebber, heb buiten mijn computer een hele aardige set staan. Heb alleen niet zo'n verstand van geluid in/uit computers :) Denk dus wel dat ik het verschil zal horen. Deze set schijnt heel aardig te zijn, denk maar dat ik er voor ga :)
(of iemand anders moet nog tips hebben?)
  • kaajee
Leolinedance schreef op woensdag 03 oktober 2007 @ 14:12:
Heb je het nu over je geluidsset of over je computer?
En waar denk je voor te gaan nu uiteindelijk?
  • Leolinedance
kaajee schreef op donderdag 04 oktober 2007 @ 10:22:
Ik heb het over het setje (DTT 2500). Dat mijn set best aardig is weet ik al ;)
Denk dus dat ik er maar voor ga :)
  • kaajee
Leolinedance schreef op vrijdag 05 oktober 2007 @ 17:27:
Een Creative Cambridge Sound Works Playworks DTT 2500?
Deze heeft welliswaar een digitale ingang maar decodeert niet DTS en DD51 volgens mij......
En wáár ga je nou precies voor? Wat dat is me nog steeds niet duidelijk........
Digitaal aansluiten middels een optisch-coaxiaal converter?
  • Leolinedance
kaajee schreef op vrijdag 05 oktober 2007 @ 18:38:
Morgen komt het setje binnen.
Ik sluit het eerst even analoog aan, dus 2.1, totdat ik een optical -> coax convertor heb. Dan sluit ik het geheel digitaal aan dmv SPDIF.
Ik kan al die surround standaarden niet meer onthouden, dus ik gok er maar een beetje op dat deze zijn werk goed zal doen. Mijn setje is 5.1 en mijn geluidschip kan 5.1 doorgeven volgens de handleidingen enzo. Klein gokje, maar zo duur is de set ook weer niet. Anders heb ik altijd nog een leuk klinkende 2.1 set!
  • Leolinedance
Inderdaad dat setje wat in de door jou gepostte link staat. Schijnt een goede set te zijn!
  • Leolinedance
Heb de set binnen en geinstalleerd. Nu nog alleen in stereo met gewone analoge aansluiting. Klinkt al érg goed _/-\o_ Ben benieuwd hoe het is met SPDIF aangesloten :)
  • Zilver
  • Laatst online: 23-10-2025
Heb je de convertor al gehaald en werkt dit. Welke converter heb je precies gehaald?
Ik heb hetzelfde probleem namelijk. Een DTT2500 die alleen stereo 2.1 weergeeft.
Zo,n converter lijkt me een uitkomst.
  • Leolinedance
Zilver schreef op maandag 12 november 2007 @ 16:22:
Ik heb hem nog niet gekocht, laat het maar even zo. Ook mooi geluid, in ieder geval veel beter dan wat er standaard in de laptop zit. Zou het wel graag eens willen proberen, maar heb niet zo'n convertor en weet niet eens of SDDIF wel aan staat (en of het optische/TOSlink is). Het Fujitsu Siemens gemaild maar nooit iets terug gehad. Verder valt het nergens op internet terug te vinden..
ik heb een asus p5n32-e sli plus moederbord met onboard sound. daar zit ook optical en coax optical op. ik heb ook zo'n set 2500. er zit alleen een rare kabel aan die ik vroeger in de mini stekker stopje van mijn digitale creative 1024 player geluidskaart. ging met een verloopstekker. dat kan nu dus niet, ik moet hem rechtststreek met mijn optical verbinden. ik heb echter geen 5.1 geluid. hoe los ik dit op?
de digital din connecter gebruik ik dus nu niet van mijn speakerset, die ging naar dat verloop kabeltje...
[ Voor 11% gewijzigd door Verwijderd op 10-04-2008 16:26 ]
