[SATA] HD toch stuk!
  • 149 views sinds 30-01-2008
  • Darkasantion
  • Laatst online: 05:48
Darkasantion
Just keep swimming!
Harde schijf voelt zich niet lekker want:
SMART geeft 2 meldingen namelijk deze:
NOTE : your hard disk has 2 pending sectors. Those are sectors that couldn't be properly read and that the hard disk logic is waiting for a write operation to try to remap to a spare sector (if available). According to the Reallocated Sector Count attribute, your hard disk seems to have available spare sectors. A simple disk surface scan won't be enough to force the remap operation. You need a read/write surface scan to remap the sector. The best option should be a tool that knows about what should be read from that sector so that it has some option to apply the best fix to the missing data.
NOTE : your hard disk has 2 offline uncorrectable sectors. Those are sectors that an offline scanning found as unreadable. Offline scanning is a process that can be automatically started by the hard disk logic when a long enough idle period is detected or that can be forced by some tool. Those unreadable sectors are identified and the hard disk logic is waiting for a write command that will overwrite them to try to remap them to spare sectors (if available). According to the Reallocated Sector Count attribute, your hard disk seems to have available spare sectors. A simple disk surface scan won't be enough to force the remap operation. You need a read/write surface scan to remap the sector. The best option should be a tool that knows about what should be read from that sector so that it has some option to apply the best fix to the missing data.
Dit lijkt mij een goede indicatie, naast het feit dat mijn muziek die op die schijf staat af en toe stottert, de PC soms traag is/wordt en het geklik om de schijf op RMA te doen!
Ook wil hij niet meer defragmenteren op de schijf, dan moet eerst chkdsk /f gedraaid worden
Zijn jullie het ermee eens of niet?
En waar komt de schade van? Overclock, kan eigenlijk niet want de PCI en AGP bus hebben steeds een lock gehad dus. Dus gewoon slijtage?
Nu doet hij het weer zonder problemen, en andere SMART programma geeft geen fouten aan, wat is het nu??? Antwoord graag :|
[ Voor 3% gewijzigd door Darkasantion op 26-09-2007 20:59 ]
Join het DPC Whatpulse team Intel/ATI.AMD Powered PC!
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
SMART zou ik nooit 100% vertrouwen, het zit er redelijk vaak naast namelijk.
Wat je het beste kunt doen is gewoon het tooltje van de fabrikant pakken en daarmee testen. Geeft die fouten, dan gelijk RMAen.
  • Darkasantion
Darkasantion
Just keep swimming!
Data Lifeguard Tools heeft niks om de HD me te checken, programma waar in de FAQ naar gelinkt wordt
  • Fauna
  • Laatst online: 12:45
Controleer je harde schijf eens met de tool van de betreffende fabrikant. Grote kans dat die een betrouwbaarder resultaat geeft dan SMART. Echter mijn ervaring is toch dat áls er SMART-errors zijn, dat de schijf binnen afzienbare tijd ook echt stuk gaat.
De schijf dus controleren met een goede tool, en daarna waarschijnlijk RMA. Zo weet je ook zeker dat je de schijf niet voor niets op stuurt, al heb ik het ernstige vermoeden dat je schijf steeds meer kuren zal gaan vertonen.
  • Darkasantion
Darkasantion
Just keep swimming!
Controle is nu bezig, jij kijkt alle sectoren na, maar duurt even dus vanavond/morgen is hij hopelijk klaar. Dan RMA en dan met bijbetaling Raptor regelen!
  • Darkasantion
Darkasantion
Just keep swimming!
Ok eerst bij de leverancier RMA aangevraag, die gaaf aan dat ik naar Western Digital moest voor RMA, dus maandag mail gestuurd, om later te horen dat je online het moest ' vragen'.
Maandag avond dus gedaan, en zou binnen 1 dag antwoord krijgen, en heb nu nog niks mee gehoord :( . Iemand hier enige ervaring mee, of tips wat ik nu kan doen?
  • vanaalten
  • Laatst online: 15:01
Hoe oud is de harde schijf? Beter gezegd, wanneer heb je hem gekocht? Als het minder dan een jaar geleden is, dan niet met de fabrikant maar met de winkel waar je hem gekocht hebt regelen.
  • Darkasantion
Darkasantion
Just keep swimming!
Het is net langer dan 1 jaar, dus die optie is er niet meer.
