Ricoh MP7040 naar de ju!?
  • 136 views sinds 30-01-2008
Sinds vorig jaar heb ik een Ricoh MP7040 burner die tot twee maanden geleden prima heeft gefunctioneerd. Sinds twee maanden kan hij echter geen enkele cd langer dan 12 minuten (plm 140mb) burnen. Hij geeft dan de volgende errors in Nero 5.01
Invalid writestate
Could not perform EndTrack
Burnprocess failed
Weet iemand wat er met mijn burner aan de hand is?
Bijlage: Nero error log
oDs
oRcA iNtElLiGeNcE
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10-9-99 13:06:00
Nero Version: 5.0.1.8
Recorder: <RICOH CD-R/RW MP7040A> Version: 1.40 - HA 1 TA 0 - 5.0.1.8
Adapter driver: <ESDI_506> HA 1
Drive buffer : 2048kB
CD-ROM: <RICOH CD-R/RW MP7040A>Version: 1.40 - HA 1 TA 0 - 5.0.1.8
RICOH CD-R/RW MP7040A (Target 0, J :): Autoinsert On, DMA Off, Disconnect On, SyncDataXfer Off
PIONEER DVD-ROM DVD-104F (Target 1, K :): Autoinsert On, DMA On, Disconnect On, SyncDataXfer Off
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 26214400 (26214400) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 63MB (65036kB)
Free physical memory: 0MB (4kB)
Memory in use : 100 %
Uncached PFiles: 0xFC
Wizard: Off
CD-ROM (ISO)
1.8.2000
15:21:35 #1 Text 0 File BusArbiter.cpp, Line 84
bus arbitration: bus type category
SCSI 0
unknown 1
other 2
IDE 3
drives from category 1 and 3 competition level 1
stall writers at 95%, reactivate at 70%
15:21:35 #2 Text 0 File Reader.cpp, Line 75
Reader running
15:21:35 #3 Text 0 File Writer.cpp, Line 101
Writer RICOH CD-R/RW MP7040A running
15:21:35 #4 Text 0 File BusArbiter.cpp, Line 827
Tue Aug 01 15:21:35 2000
RICOH CD-R/RW MP7040A: Register
arbitration enabled
n. category bus drive writer name
0. 2 1 0 yes RICOH CD-R/RW MP7040A
i
r
15:21:35 #5 ISO9660GEN -11 File geniso.cpp, Line 3236
First writeable address = 0 (0x00000000)
15:21:35 #6 Text 0 File ThreadedTransferInterface.cpp, Line 637
Setup items (original item values)
0: TRM_DATA_MODE2_FORM1_NOSUB (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 261337 (261337) = #261337
relocatable, CD pos for caching/writing not required/required, no patch infos
15:21:39 #7 Text 0 File Burncd.cpp, Line 1454
Recorder: RICOH CD-R/RW MP7040A;
CDRW code: 00 97 27 00; CD manufacturer: DIGITAL STORAGE TECHNOLOGY CO.,LTD
15:21:39 #8 Text 0 File ThreadedTransferInterface.cpp, Line 769
Prepare recorder RICOH CD-R/RW MP7040A for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x20 Close Session
Tracks 1 to 1:
TRM_DATA_MODE2_FORM1_NOSUB, 2048/0x0, ISRC "", FilePos 0 307200 535525376
15:21:39 #9 Text 0 File ThreadedTransferInterface.cpp, Line 797
Removed 2 run-out blocks from end of track 1.
15:21:39 #10 Text 0 File ThreadedTransferInterface.cpp, Line 637
Setup items (after recorder preparation)
-> TRM_DATA_MODE2_FORM1_NOSUB, 2048, config 0, wanted index0 0 blocks, length 261335 blocks [RICOH CD-R/RW MP7040A]
15:21:39 #11 Phase 24 File dlgbrnst.cpp, Line 1174
Start of caching files
15:21:39 #12 Phase 25 File dlgbrnst.cpp, Line 1174
Caching files completed
15:21:39 #13 Phase 36 File dlgbrnst.cpp, Line 1174
Start of burnprocess at 4x (600 KB/s)
15:21:39 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1711
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
15:21:39 #15 Text 0 File BusArbiter.cpp, Line 827
Tue Aug 01 15:21:39 2000
READ: Register
arbitration enabled
1. 1 -1 -1 no READ
i i
r r
15:24:46 #16 SCSI -1135 File Cdrdrv.cpp, Line 1324
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x040F7990
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0xAA 0x00 0x00 0x00 0xCE 0xF4 0x00 0x00 0x00 0x1E 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x00 0xCC 0x75 0x0C
0x00 0x00 0x00 0x00 0x0C 0x00
15:24:46 #17 mmc 3072 File Writer.cpp, Line 283
Write error
15:24:46 #18 Text 0 File ThreadedTransfer.cpp, Line 211
all writers idle, stopping conversion
15:24:50 #19 Text 0 File ThreadedTransfer.cpp, Line 205
conversion idle, stopping reader
15:24:55 #20 SCSI -1135 File Cdrdrv.cpp, Line 1123
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x00 0xCC 0x75 0x0C
15:24:55 #21 CDR -201 File WriterStatus.cpp, Line 155
Invalid writestate
15:24:55 #22 TRANSFER -18 File WriterStatus.cpp, Line 155
15:26:13 #23 Phase 38 File dlgbrnst.cpp, Line 1174
Burnprocess failed at 4x (600 KB/s)
15:26:13 #24 Text 0 File Scsicmd.cpp, Line 260
SCSI not using temporary buffers
15:26:13 #25 Text 0 File Scsicmd.cpp, Line 283
10 out of 10 temporary buffers allocated
15:26:13 #26 Text 0 File WinNeroThreads.cpp, Line 909
Thread priorities:
Pri. name -> class / level
0. Idle -> 32 / -15 = default
1. Background -> 32 / -2 = default
2. Normal -> 32 / 0 = default
3. HighIdle -> 128 / -1 = default
4. High -> 128 / 0 = default
5. Higher -> 128 / 1 = default
6. Realtime -> 128 / 2 = default
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 16-5-98 4:01:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 8, size=30887 bytes, created 1-8-00 15:05:28
File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (077), size=207238 bytes, created 26-8-99 9:20:00
File 'IoSubsys\C2REC.VXD': Ver=3.00.044, size=28335 bytes, created 6-1-99 18:44:36
File 'IoSubsys\C2APIX.VXD': Ver=Version 1.01.026, size=10469 bytes, created 16-11-98 13:45:44
File 'IoSubsys\C2UDFFS.VXD': Ver=3,0,0,209, size=141448 bytes, created 5-1-00 15:23:40
File 'IoSubsys\C2UDFVSD.VXD': Ver=1.10.043, size=25256 bytes, created 29-7-99 14:43:26
File 'IoSubsys\UDF_200.VXD': Ver=1.00.009, size=16541 bytes, created 1-7-98 10:53:30
File 'IoSubsys\UDF_920.VXD': Ver=1.00.010, size=18073 bytes, created 1-7-98 10:53:14
File 'IoSubsys\UDF_JVC.VXD': Ver=1.00.020, size=22169 bytes, created 3-9-98 9:49:50
File 'IoSubsys\DRVWPPQT.VXD': Ver=3.10.36a, size=228223 bytes, created 16-5-98 4:01:00
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 16-5-98 4:01:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.1998, size=24406 bytes, created 16-5-98 4:01:00
