• El Cid
Official prototype of kilogram mysteriously losing weight
PARIS, France (AP) -- A kilogram just isn't what it used to be.
The 118-year-old cylinder that is the international prototype for the metric mass, kept tightly under lock and key outside Paris, is mysteriously losing weight -- if ever so slightly. Physicist Richard Davis of the International Bureau of Weights and Measures in Sevres, southwest of Paris, says the reference kilo appears to have lost 50 micrograms compared with the average of dozens of copies.
"The mystery is that they were all made of the same material, and many were made at the same time and kept under the same conditions, and yet the masses among them are slowly drifting apart," he said. "We don't really have a good hypothesis for it."
The kilogram's uncertainty could affect even countries that don't use the metric system -- it is the ultimate weight standard for the U.S. customary system, where it equals 2.2 pounds. For scientists, the inconstant metric constant is a nuisance, threatening calculation of things like electricity generation.
"They depend on a mass measurement and it's inconvenient for them to have a definition of the kilogram which is based on some artifact," said Davis, who is American.
But don't expect the slimmed-down kilo to have any effect, other than possibly envy, on wary waistline-watchers: 50 micrograms is roughly equivalent to the weight of a fingerprint.
"For the lay person, it won't mean anything," said Davis. "The kilogram will stay the kilogram, and the weights you have in a weight set will all still be correct."
Of all the world's kilograms, only the one in Sevres really counts. It is kept in a triple-locked safe at a chateau and rarely sees the light of day -- mostly for comparison with other cylinders shipped in periodically from around the world.
"It's not clear whether the original has become lighter, or the national prototypes have become heavier," said Michael Borys, a senior researcher with Germany's national measures institute in Braunschweig. "But by definition, only the original represents exactly a kilogram."
The kilogram's fluctuation shows how technological progress is leaving science's most basic measurements in its dust. The cylinder was high-tech for its day in 1889 when cast from a platinum and iridium alloy, measuring 1.54 inches in diameter and height.
At a November meeting of scientists in Paris, an advisory panel on measurements will present possible steps toward basing the kilogram and other measures -- like Kelvin for temperature, and the mole for amount -- on more precise calculations. Ultimately, policy makers from around the world would have to agree to any change.
Many measurements have undergone makeovers over the years. The meter was once defined as roughly the distance between scratches on a bar, a far cry from today's high-tech standard involving the distance that light travels in a vacuum.
One of the leading alternatives for a 21st-century kilogram is a sphere made out of a Silicon-28 isotope crystal, which would involve a single type of atom and have a fixed mass.
"We could obviously use a better definition," Davis said.
Bron: CNN
Toen ik gisteren toevallig op de weegschaal stond dacht ik al: ben ik nu afgevallen?
  • Kixtart
Kixtart
Destruction = Improvement
  • SinergyX
  • Laatst online: 11:39
SinergyX
____(>^^(>0o)>____
En wanneer is die weegschaal voor het laatst ge-eikt? :P
Dit snap ik dan niet, de andere moeten dan toch 1.000000050 gram zijn of het 'orgineel' 9.9999999950?
[ Voor 4% gewijzigd door SinergyX op 14-09-2007 16:28 ]
SinergyX schreef op vrijdag 14 september 2007 @ 16:27:
Ten opzichte van welke?
  • SinergyX
SinergyX
____(>^^(>0o)>____
De weegschaal? :P :?
Of de kopieën kloppen gewoon niet :)
  • djluc
  • Laatst online: 11:22
En die is weer geeikt op basis van de kilo die nu blijkbaar wat gewicht kwijt is. ;)
Verwijderd schreef op vrijdag 14 september 2007 @ 16:31:
Wel stug dat meerdere kopieen veranderen dan.
[ Voor 54% gewijzigd door djluc op 14-09-2007 16:35 ]
  • El Cid
Zo te lezen hebben ze het gemiddelde genomen van alle exemplaren. Dit betekent dat het origineel lichter is geworden, of dat alle anderen zwaarder zijn geworden. Aangezien volgens het artikel veel van de staven op vergelijkbare manier geproduceerd en bewaard worden, schat ik in dat het het origineel is waar iets mis mee is.
Misschien vallen er door slijtage deeltjes af? Ik kan me voorstellen dat elk voorwerp duizenden moleculen per minuut/uur/dag verliest, ook al is dat voorwerp geïsoleerd. Zo kom je na een eeuw al gauw aan enkele microgrammen.
[ Voor 13% gewijzigd door Verwijderd op 14-09-2007 16:52 ]
  • 0rbit
  • Laatst online: 22-09 12:16
Zowel iridium als platinum zijn beschikbaar in radioactieve isotopen. Iridium heeft een isotoop (naast nog een dozijn of wat anderen) dat een halfwaardetijd heeft van 240 jaar. Als er dus in het origineel een beetje meer dan 100 microgram van dat isotoop zat dan klopt dat wel ongeveer; lijkt mij een aannemelijke verklaring, zeker als de moderne kopie van stabiel silicium gemaakt wordt.
Ik ben geheel voldaan, dank u wel!
Wat een onzin dat het verder invloed zou hebben op iets, of wordt die kilo nog echt ergens voor gebruikt?
Vreemd is het in ieder geval wel, maar ik weet niet hoe dat ding is opgeslagen verder.
Mr_Atheist schreef op vrijdag 14 september 2007 @ 16:53:
ze zeggen duidelijk dat ze in dezeflde tijd gemaakt zijn.
maar het lijkt me dat we hem maar moeten vervangen door iets stabielers.
  • El Cid
Verwijderd schreef op vrijdag 14 september 2007 @ 16:52:
Volgens het artikel zijn veel van de andere staven rond dezelfde tijd gefabriceerd. Dus dan zouden de andere staven toch ook gewicht kwijtgeraakt moeten zijn?
RoeAnSte was me voor.
[ Voor 3% gewijzigd door El Cid op 14-09-2007 17:04 ]
Als de concentraties van een bepaald isotoop met die halfwaardetijd niet bij elke kopie identiek is ga je door verval verschillen krijgen tussen de verschillende staven.
  • Edmin
  • Laatst online: 26-10 17:03
Edmin
Crew Council
get on my horse!
Zo'n referentiestaaf is toch ouderwets? Kunnen we niet beter een kilogram omschrijven als de cumulatieve massa van een x aantal moleculen van stof y?
  • El Cid
Edmin schreef op vrijdag 14 september 2007 @ 17:05:
Er is inderdaad behoefte aan een operationele definitie van de kilogram. Helaas blijkt in de praktiek dat dat nog niet zo eenvoudig is. Vandaar dat de kilogram de laatst overgebleven eenheid is die nog met een artefact wordt vastgelegd.
El Cid schreef op vrijdag 14 september 2007 @ 17:11:
Er zijn toch ook nog een aantal eenheden die worden bepaald adhv de omtrek van de Aarde? De Aarde is ook een artefact en wil ook nogal eens van omtrek veranderen.
En ook genoeg aan de omlooptijd van de Aarde, dat is in principe ook hetzelfde verhaal.
(Hoewel de meeste idd al vervangen zijn een keer)
[ Voor 11% gewijzigd door Verwijderd op 14-09-2007 17:28 ]
  • Edmin
Edmin
Crew Council
get on my horse!
Is een meter nog steeds gerelateerd aan de omtrek v.d. aarde? Een vaste afstand zou volgens mij een goede basis zijn voor de eenheid 'tijd'.
'Een seconde is de tijdsduur die licht nodig heeft om x afstand af te leggen.'
Iets in die geest.
Dat had je ook gewoon kunnen googlen:
http://en.wikipedia.org/wiki/Metre
The metre is the length of the path travelled by light in vacuum during a time interval of 1/299 792 458 of a second
De definitie is dus precies andersom.
[ Voor 9% gewijzigd door Verwijderd op 14-09-2007 17:29 ]
De meter (symbool m) is de SI-basiseenheid voor lengte. Hij is sinds 1983 gedefinieerd als de afstand die licht in 1/299.792.458 seconde in vacuüm aflegt.
De seconde is de internationale standaardeenheid van tijd. Zij is gedefinieerd als de duur van 9.192.631.770 perioden van de straling die correspondeert met de overgang tussen de twee hyperfijn energieniveaus van de grondtoestand van een cesium-133 atoom in rust bij een temperatuur van 0 K.
Doordat de seconde nu niet langer gedefinieerd is als een vast gedeelte van de dag, is het noodzakelijk geworden nu en dan een schrikkelseconde in te voegen.
  • eamelink
eamelink
Droptikkels
Dat lijkt mij niet echt een aannemelijke verklaring, want beide delen van de de oorspronkelijke kern blijven gewoon in het metaal zitten, waardoor het dus nauwelijks aan massa verliest :)
't probleem is dat wat hier een kilogram is, het op de maan niet is? dus dan moet je ook nog iets met N in je definitie.
x moleculen stofy bij 0 K en 1N = 1kg?
bedenk maar een goede :p
Verwijderd schreef op vrijdag 14 september 2007 @ 18:03:
Massa is massa hoor, maakt niet uit waar je zit ;)
e=mc2 enzo
De denkfout komt altijd doordat het op de basisschool verkeerd wordt uitgelegd. Zwaartekracht en massa hebben niets met elkaar te maken.
[ Voor 15% gewijzigd door Verwijderd op 14-09-2007 18:08 ]
  • Edmin
Edmin
Crew Council
get on my horse!
Verwijderd schreef op vrijdag 14 september 2007 @ 17:28:
ik ben blij dat ik zo slim ben om uit mezelf dit te bedenken. d:)b
  • .oisyn
  • Laatst online: 11:30
.oisyn
Moderator Devschuur®
Demotivational Speaker
Verwijderd schreef op vrijdag 14 september 2007 @ 18:04:
e=mc2 enzo
Massa en zwaartekracht hebben juist veel met elkaar te maken, anders vielen we allemaal van onze geliefde aardbol af :P. Wat je bedoelt uit te leggen is het verschil in gewicht en massa. Om massa te wegen (hence 'gewicht') heb je zwaartekracht nodig, en die is op aarde idd anders dan op de maan.
En de maatstaaf voor massa is het gewicht van die massa hier op aarde.
[ Voor 5% gewijzigd door .oisyn op 14-09-2007 18:37 ]
  • El Cid
.oisyn schreef op vrijdag 14 september 2007 @ 18:36:
Nee hoor, in de ruimte kan je een operationele definitie gebruiken. Bijvoorbeeld met F=ma kun je de massa bepalen door de acceleratie te meten bij een gegeven kracht.
  • Punksmurf
  • Laatst online: 06-01-2024
El Cid schreef op vrijdag 14 september 2007 @ 16:25:
Nope, je bent aangekomen.
X kilo staat gelijk aan jouw massa. Als de kilo minder zwaar wordt heb je dus meer kilo's nodig om jouw massa te evenaren :P.
Ze stellen dat die andere cylinders gelijk behandeld zijn, maar dat is duidelijk niet zo. 'De' kilocylinder blijft op z'n plek terwijl de andere cylinders de hele wereld overvliegen, volgens het artikel. Ik doe nu een heel wilde gooi en het lijkt me sterk dat het een significant veschil geeft, maar gaat de tijd niet langzamer als je in beweging bent (voor de stilstaande toeschouwer)? Dan hebben die andere cylinders dus minder tijd gehad om te vervallen dat de belangrijkste.
Daarentegen lijkt me dat de andere cylinders vaker uit hun opbergkistje worden genomen en zo dus meer te lijden hebben door slijtage, oxidatie en ik weet niet wat.
met een hamer past alles
  • Duesenberg J
  • Laatst online: 24-10 18:12
Punksmurf schreef op vrijdag 14 september 2007 @ 19:32:
Volgens die theorie zouden de andere cilinders juist lichter moeten zijn dan het origineel. En hier is het net andersom.
Overigens is het ook niet handig om de kilo te definiëren aan de hand van de aantrekkingskracht van de aarde, want de aarde verzamelt elke dag massa (en verliest ook wat) Dat zorgt voor (zeer kleine) fluctuaties in de zwaartekracht, waardoor dezelfde hoeveelheid massa een ander gewicht krijgt op aarde. Deze fluctuaties lijken me voor normale berekeningen verwaarloosbaar, maar als je een eenheid aan het definiëren bent wil je toch zoveel mogelijk significante cijfers hebben neem ik aan.
  • GoldenSample
GoldenSample
Huub, Huub, Barbatruc!
El Cid schreef op vrijdag 14 september 2007 @ 18:52:
true.
daarnaast zijn ze er in de natuurkunde ook echt nog niet uit hoe het precies met tijd zit icm Zwarte gaten, Wormhole's en de zogenaamde 'tijdkromming' ;)
  • Duesenberg J
Ik dacht dat er misschien wel eens een atoom Pt of Ir van die cilinder af zou kunnen vallen of 'verdampen' en dat daarom het gewichtsverlies verklaard zou kunnen worden.
Ik twijfelde al direct aan die theorie, want als het waar was hadden de knappe koppen die er al lang mee bezig zijn daar wel aan gedacht. Maar ik heb toch maar even de berekeningen uitgevoerd.
Daaruit kwam dat er maarliefst 1.6 * 1016 atomen Ir en 1.4 * 1017 atomen Pt van het blok af zouden moeten vallen, wil er 50 microgram gewichtsverlies gemeten worden.
Daar gaat mijn theorie.
Ik denk overigens dat, wanneer de 'nieuwe' definitie van een kilogram ook op een artefact gebaseerd wordt (dat silicium-28-kristal), het misschien een beter idee is om het blok precies langs de splijtrichtingen van het kristalrooster vorm te geven, zodat er minder ruimte over is voor andere atomen om zich ergens aan te binden. Maar die gedachte hoort thuis in de pseudo-wetenschap dus ik houd mijn mond maar :X
  • naftebakje
Over de variërende zwaartekracht enzo: het meten en refereren aan de "standaard kilo" gebeurt met (ontzaglijk preciese) balansen, waarbij je dus een evenwicht zoekt tussen 2 massa's die elk onderhevig zijn aan dezelfde zwaartekracht (waarbij de variatie in zwaartekracht tussen de 2 massa's die zich op minder dan een meter afstand van elkaar bevinden te verwaarlozen is). Vandaar dat dit niet uitmaakt, ook op de maan kan je met een balans controleren of een te meten object meer of minder weegt dan een "standaard kilo".
Een andere kandidaat voor het exact vastleggen van een kilogram was het gebruiken van een spoel die aan een kant van een balans trekt, aan de andere kant zet je je te meten object; door nu door die exact gespecificeerde spoel een vast aantal electronen per seconde te sturen kan je ook de kilogram vastleggen.
De praktische bezwaren hebben er wellicht voor gezorgd dat deze mogelijkheid niet aan de orde is, er is geen zicht op de mogelijkheid om het aantal electronen wat je door een spoel stuurt exact te bepalen en in te stellen.
  • blobber
blobber
Sol Lucet Omnibus
GoldenSample schreef op vrijdag 14 september 2007 @ 19:48:
true.
Volgens mij is dat prima beschreven met de Srt en de Art ;)
To See A World In A Grain Of Sand, And A Heaven In A Wild Flower, Hold Infinity In The Palm Of Your Hand, And Eternity In An Hour
  • Rey Nemaattori
  • Laatst online: 18-09 20:46
Hoe zit dat met natuurlijk nucleair verval? Gedurende de jaren wil d'r weleens eens atoompje gek doen?
naftebakje schreef op vrijdag 14 september 2007 @ 20:28:
Da's tog wel uitterekenen? Je wéét de lading per electron, je meet voltage&stroom en dnak un je gaan rekenen?
[ Voor 68% gewijzigd door Rey Nemaattori op 14-09-2007 20:55 ]
Speks:The Hexagon Iks Twee Servertje
"When everything is allright,there is nothing left."Rey_Nemaattori
Ja precies dat ja :D
Maar al die theorien worden in no time uit het water geschoten door Einstein:
E = mc2
Als dat ding dus massa verliest dan moet ie op een of andere manier energie uitstoten, die energie is dan meetbaar. Ik ga er vanuit dat als ie echt energie uitstoot (radioactief bijvoorbeeld) dat ze dat wel ontdekt hadden na al die jaren?
Of het is gewoon iemand die een grap uithaalt, of een fout, of iemand die de definitie van een kilo wil laten aanpassen en er gewoon stiekum steeds een beetje af schraapt.
[ Voor 33% gewijzigd door Verwijderd op 14-09-2007 21:20 ]
  • Punksmurf
Duesenberg J schreef op vrijdag 14 september 2007 @ 19:44:
Bij mijn tweede theorie inderdaad. Vandaar ook 'daarentegen'.
Verwijderd schreef op vrijdag 14 september 2007 @ 21:18:
Als niemand er ooit aan dacht dat te meten, zal met het ook niet weten tenzij de verschijnselen van die energie wel heel duidelijk zijn dat men gewaarschuwd wordt (zoveel warmteontwikkeling dat er brand ontstaat bijvoorbeeld).
[ Voor 49% gewijzigd door Punksmurf op 14-09-2007 21:59 ]
  • .oisyn
.oisyn
Ik benadrukte expliciet "wegen". Natuurlijk kun je massa ook meten in de ruimte, maar ik vind dat niet wegen - de massa is immers gewichtloos.
Maar na een bezoekje aan vandale.nl zie ik dat mijn definitie van wegen niet helemaal juist is. Vandale zegt:
de zwaarte, het gewicht, resp. de massa onderzoeken, bepalen van
Dus in de ruimte kun je ook wegen. Je hebt idd gelijk :)
Maar dat wil niet zeggen dat in de ruimte een kilo geen kilo meer is, als je in de ruimte iets zou wegen zou het precies even zwaar zijn als hier op Aarde.
  • Dutch_Razor
  • Laatst online: 01-11-2024
eamelink schreef op vrijdag 14 september 2007 @ 17:59:
Volgens mij wordt de straling uitgezonden in alpha, beta of gamma deeltejs, en die verlaten het metaal dan.
  • blobber
blobber
Sol Lucet Omnibus
Alleen alpha straling vertegenwoordigt dan enige relevante massa (heliumkernen) b straling zijn electronen en gamma's zijn fotonen, dus dat schiet niet echt op :)
En er zijn iig geen Iridium isotopen die alpha verval hebben, echter Platina bezit wel veel Alpha vervallende isotopen.
Er bestaan van zowel iridium als Platina isotopen die alpha verval vertonen:
http://education.jlab.org/itselemental/iso077.html voor iridium, platina staat ook op die site.
Maar die isotopen hebben een zeer kleine halfwaardetijd, dus vallen af.
(en de enige langere hwt is zo lang dat het bijna stabiel is)
[ Voor 68% gewijzigd door blobber op 15-09-2007 19:00 ]
  • Sicknus
  • Laatst online: 14-09 21:20
Een vraag die bij me opkwam:
Hoe kan men natuurkundig verantwoord zeggen dat dat standaardgewichtje in Sèvres massa verliest?
De eenheid van massa is nu juist geëikt op dat ene object.
Natuurkundig gezien zouden we dus moeten zeggen dat alles een grotere massa heeft gekregen.
(Nu snap ik natuurlijk ook wel dat er wat aan de hand is met het standaardartefact, ipv de rest van de wereld, maar hoe ga je hier natuurkundig gezien mee om?)
[ Voor 7% gewijzigd door Sicknus op 15-09-2007 21:43 ]
  • eamelink
eamelink
Droptikkels
Dutch_Razor schreef op zaterdag 15 september 2007 @ 18:15:
Alpha deeltjes zijn de enigen met een serieuze massa, en die komen ook echt niet uit een blok metaal zetten als het verval op meer dan een millimeter van de rand van het metaal plaatsvindt :)
Sicknus schreef op zaterdag 15 september 2007 @ 21:42:
Natuurkundig gezien zijn we niet gebonden aan dat blokje in Frankrijk. Definitietechnisch gezien is alles misschien zwaarder geworden, maar natuurkundig gezien natuurlijk niet :)
Je gaat op zoek naar een betere manier om je standaard te definiëren. Vroeger was een seconde een bepaald deel van een dag. De lichtsnelheid was de afstand die licht in een seconde aflegde, waarbij de meter uit Frankrijk werd gebruikt, en de seconde als deel van de dag. Toen bleek dat de snelheid waarmee de aarde tolt nogal varieert, waardoor een seconde nogal wiebelig was. De frequentie van een hyperfijnovergang van een atoom bleek veel stabieler; waardoor die is genomen. Verder was de meter ook niet erg handig als die maar ééns per jaar uit de kluis werd gehaald, en bovendien uitzette of kromp als iemand een warme danwel koude scheet liet. De lichtsnelheid blijkt veel constanter te zijn, dus is die gebruikt, samen met de seconde, om de meter te definiëren.
Momenteel zijn fysici in staat om met behulp van optische frequentiekammen (frequency combs; voor de Googelaars) zo nauwkeurig tijd te meten, dat de nauwkeurigheid daarvan hoger is dan die van de definitie van de seconde :). De hyperfijnovergang als definitie van de seconde is dan waarschijnlijk ook geen lang leven meer beschoren :*).
Momenteel is eigenlijk alleen de kilo heel brak gedefinieerd :), maar daar zit ook verandering in aan te komen, door gewoon een geheel aantal atomen te pakken, en dan het liefste in een vorm waarin je ze gemakkelijk kan tellen en controleren of het er precies genoeg zijn :)
[ Voor 71% gewijzigd door eamelink op 15-09-2007 21:59 ]
Verwijderd schreef op zaterdag 15 september 2007 @ 17:41:
Wat is zwaarder; een kilo lood of een kilo veren? En hoeveel wegen ze wanneer ze zich in een staat van gewichtsloosheid bevinden?
  • Dutch_Razor
eamelink schreef op zaterdag 15 september 2007 @ 21:51:
Ah ja dat klopt ook weer.
  • MSalters
  • Laatst online: 22-10 15:29
Verwijderd schreef op zondag 16 september 2007 @ 01:05:
Wegen = gewocht =/= massa.
Je kunt massa's in de ruimte bijvoorbeeld meten door de frequentie van een massa-veersysteem te bepalen, waarvan de veer een bekende veerconstante heeft, via F=ma.
Man hopes. Genius creates. Ralph Waldo Emerson
Never worry about theory as long as the machinery does what it's supposed to do. R. A. Heinlein
  • eamelink
eamelink
Droptikkels
Aanhakend op MSalters; om die reden wordt er in de fysica ook wel gesproken van 'zware massa' wanneer we de massa bedoelen die gebruikt wordt in vergelijkingen met zwaartekracht, en 'trage massa' wanneer we de massa bedoelen die gebruikt wordt in vergelijkingen met een versnelling :)
Gelukkig heeft Einstein voor ons ontdekt dat de zware en de trage massa identiek zijn; dat maakt het leven weer makkelijker :P
  • Confusion
  • Laatst online: 01-07 21:46
Confusion
Fallen from grace
eamelink schreef op maandag 17 september 2007 @ 21:34:
Is dat niet stiekem een postulaat? Een postulaat dat door metingen geverifieerd is tot op een factor 10-8 ofzo, maar niettemin een postulaat?
Wie trösten wir uns, die Mörder aller Mörder?
  • YouKnow
Jouw laatste opmerking, grappig bedoeld weliswaar, klopt helaas niet. Volgens mij ben je dan zwaarder geworden :>
  • El Cid
YouKnow schreef op donderdag 20 september 2007 @ 21:03:
Jawel, hij klopt wel. Toevallig stond ik de dag ervoor sinds lang weer op een weegschaal. De laatste keer dat ik mezelf had gewogen stond de weegschaal op zo'n 100 kilo. Nu stond hij op 93 kilo. Dus ik vroeg me weldegelijk af: ben ik nu afgevallen?
:P
  • eamelink
eamelink
Droptikkels
Confusion schreef op maandag 17 september 2007 @ 22:28:
Dat zou kunnen ja :). In principe kan je natuurlijk ook niet meten of ze gelijk zijn, maar alleen of de trage massa en de zware massa evenredig zijn en dat blijkt inderdaad zo te zijn. Door een handige keuze van eenheden kun je vervolgens stellen dat 1 gram zware massa gelijk is aan 1 gram trage massa.
Einstein zei vervolgens
"Hitherto Mechanics has taken note of this correct rule, but has not interpreted it. A satisfactory interpretation can only arise, if one realizes that the same property of a body expresses itself according to the conditions as inertia or as weight."
wat dus neerkomt op de gebruikelijke interpretatie dat beide massa's hetzelfde zijn en daarmee ook dezelfde eigenschap beschrijven :)
  • Seesar
  • Laatst online: 21-10 11:16
Seesar
Icon thnx to l0c4lh0st
e=mc2 enzo
maar als je gaat wegen met een precisie weegsschaal en je N constante is anders (o paarde verschilt deze al) dan kan je weegschaal dus iets anders aangeven dan dat dat ding echt is. M.a.w. als je met de weegschaal en dat artifact naar de maan gaat en daar gaat weten, meet je bijvoorbeeld de helft (ofzo).
Dus de vraag is hoe de meting verloopt, als de meting afhankelijk is van de zwaartekracht (ik ken alleen maar massa metingen gebaseerd op zwaartekracht (balans wordt ook beinvloed door de constante) dan weet je dus niet of de fout in de massa of in de weegschaal zit.
lees nu de reacties over het F =m maal a, als ze op die manier zouden wegen dan zou je wel een constante kunnen uitsluiten, maar hetl ijkt mij een nogal onpreciese manier: veerconstante varieert bij temperatuur, en weerstand kan -voor meten van micron kg's- enorm varieren.....ljikt me meer geschik om op hooguit grammen nauwkeurig te kunnen meten dan in microgrammen
[ Voor 17% gewijzigd door Seesar op 20-09-2007 21:59 ]
T60P Widescreen
  • HammerT
  • Laatst online: 02-10 13:24
Ik vraag me af of ze ook rekening houden met de stand van de maan als ze dat ding wegen.
En ook met de afstand van de zon op de aarde, want de baan die de aarde om de zon aflegt is namelijk niet rond maar een beetje ovaal.
  • naftebakje
De grootste beperking is de wrijving in de balans, die zorgt ervoor dat er een stuk "grijs gebied" is waar de balans niet overhelt maar er wel een verschil is, door extreem nauwkeurige afwerking wordt dat gebied zo klein mogelijk gemaakt.
Uit die "standaardkilo" kan je dan terugkeren naar grammen door de balans te construeren met variabele aangrijppunten op de armen, lengteverhouding is nagenoeg exact te bepalen om zo een verhouding van 1/1000 te krijgen (om van kg naar g te gaan).
Stand van de maan, dikte van de buik van de persoon die de meting uitvoert,... maken allemaal niets uit. Wel moet je alle externe beïnvloedingen tegenwerken, dus geen luchtstromen, trillingen of andere factoren.
[ Voor 8% gewijzigd door naftebakje op 25-09-2007 22:28 ]
  • B-BOB
  • Laatst online: 26-08 11:53
Ik had me ook laten vertellen dat er in Parijs niet enkel een "referentiekilo" ligt, maar ook een "referentiemeter". Die dingen zijn meer dan een eeuw in een of ander conventie vastgelegd en vandaag hebben we, zoals voor mij al vermeld, andere methodes om lengte en massa te bepalen.
Waar ik echter wel vreemd vond in het artikel is dat wetenschappers 'verbaast' zijn dat het gewicht afneemt ten op zichte van de andere kopieen. Simpelweg omdat er factoren zijn die we niet kunnen verklaren, wil het nog niet zeggen je met een beetje logisch verstand wel kunt denken dat iets na 120 jaar opslag kan veranderen.
Mijn docent die kansberekening doceerde, gaf een prachtig voorbeeld:
Stel je koplamp van een doorsnee auto voor. In sommige auto's heb je twee identieke lichtjes per koplamp. Deze lampjes zijn gefabriceerd in dezelfde fabriek, uit hetzelfde materiaal (zelfde batch), op hetzelfde tijdstip, machinaal met dezelfde kracht geplaatst. Tijdens het rijden, werken ze altijd in dezelfde temperatuur, elk schokje komt even hard aan, ze branden altijd samen, krijgen altijd hetzelfde voltage, en toch is de kans dat deze samen defect gaan nagenoeg onbestaande.
Bottom line: 2 verschillende dingen zijn nooit hetzelfde.
  • blobber
blobber
Sol Lucet Omnibus
Van twee gloeidraden die constant heet worden en weer afkoelen, is het idd weinig verbazingwekkend dat ze ongelijke branduren vertonen ;)
  • naftebakje
Volgens mij heeft die leraar een dom of heel slim (als ie hoopt dat jullie hem op zijn grandioze fout wijzen) voorbeeld genomen. Als je even doordenkt, zie je toch zo in dat het rechter en het linkerwiel van een wagen op een ander strookje asfalt lopen, om nog maar te zwijgen van het effect dat aan iets hogere snelheid een bocht nemen heeft op de effectiviteit van de schokdempers. En vergeet volledigheidshalve ook maar dat de wagen quasi altijd ongelijk geladen is, bestuurder en stuurkolom zitten in de meeste landen niet exact in het midden van de wagen ;) Kansberekening zou er net om moeten gaan om die effecten (die verschil in levensduur bepalen) te voorspellen, berekenen, meten en specificiëren.
En alsof leraars mij dwingen om hun, door gebrek aan vakkennis, te verafschuwen: koplampen van een auto zijn zo geconstrueerd om rechts en links ongelijk licht te geven, de rechterkant van de weg (waar reflecterende verkeersborden staan) wordt veel verder verlicht dan de linkerkant waar tegenliggers verblind kunnen worden. Als die mens even zelf had nagedacht over zijn voorbeeld, had ie toch meteen de achterlichten als voorbeeld genomen, die hebben minder te verduren dan koplampen, van bovenstaande effecten die verschillend zijn voor rechts en links hebben ze ook minder last.
Resumerend: gelijklopendheid van levensduur van schokgevoelige gloeilampen die variërende schokken te verduren krijgen, is niet iets wat je kan verwachten. Het gewicht van inerte materialen die extreem voorzichtig behandeld worden, daar verwacht je veel minder verschillen (en die hebben niets met kansberekening te maken).
  • leuk_he
  • Laatst online: 14-10 16:13
leuk_he
1. Controleer de kabel!
HammerT schreef op dinsdag 25 september 2007 @ 20:37:
het is hier al eerder gezelgd: maar 1 kilo massa is 1 kilo op de maan, als hier, net zo goed als 1 kilo veren net zoveel weegt als 1 kilo lood op de maan. Zeker als je bedenkt dat in het originele artikel de kilo vergeleken wordt, en niet zozeer gewogen op een huis tuin en keuken weegschaal.
(leuke strikvaag: ;) wat heeft de meeste massa: 1 Kilo Lood op de maan, of 1 kilo veren op mars)
Het verscil in gewicht is miniem, "50 micrograms is roughly equivalent to the weight of a fingerprint."
Kortom, een of andere nerd heeft met zijn vette vingers aan de kilo gezeten.
  • Confusion
Confusion
Fallen from grace
leuk_he schreef op vrijdag 28 september 2007 @ 17:47:
Dat heeft helemaal niets te maken met de opmerking van HammerT.
  • Seesar
Seesar
naftebakje schreef op vrijdag 28 september 2007 @ 17:37:
Als in dat ze dus naast elkaar zitten, of die 2 cm verschil dan nog verschil uitmaakt, das iets voor de kansberekenaars ;)
T60P Widescreen
  • naftebakje
[...]Kortom, een of andere nerd heeft met zijn vette vingers aan de kilo gezeten.
Voor het wegen worden de standaardkilo en zijn "kloontjes" heel voorzichtig "gewassen" (zal wel eerder een tijdje onderdompelen zijn) in een bad van alcohol, waarna ze rustig mogen drogen voor ze de weegschaal op gaan.
Seesar schreef op vrijdag 28 september 2007 @ 22:10:
[...]Als in dat ze dus naast elkaar zitten, of die 2 cm verschil dan nog verschil uitmaakt, das iets voor de kansberekenaars ;)
Ah, das wat anders, maar het neemt niet weg dat de bevestiging niet gelijk zal zijn dus trillingen zijn niet egaal (gaan op net wat andere frequenties resoneren enzo), machine staat niet 100% gelijk ingesteld voor de 2 lampjes, als er hoogteverschil is maakt het ene lampje het andere warmer,...
[ Voor 39% gewijzigd door naftebakje op 28-09-2007 22:25 ]
  • MPAnnihilator
  • Laatst online: 17-08 19:36
Ik heb geen natuurkunde gestudeerd , maar kan men die kilo niet beter definiëren als zijnde een kubus van 10x10x10 cm gevuld met zuiver H2O :) Of is dat te variabel ook ?
Mijn Specs
  • .oisyn
.oisyn
Welke temperatuur? Welke omgevingsdruk? Daarnaast, een druppeltje meer of minder zul je niet merken, terwijl je juist een exacte waarde wilt hebben :). Het volume van iets is dus niet handig.
  • eamelink
eamelink
Droptikkels
-GF-Annihilator schreef op vrijdag 05 oktober 2007 @ 11:33:
Die definitie is niet bruikbaar. Het is bijzonder moeilijk om een volume te bepalen, het zou dus heel erg moeilijk zijn om precies een liter water te nemen. Verder heeft niemand de beschikking over zuiver H2O en sommige verontreinigingen kunnen een zeer grote massa hebben, maar toch nauwelijks het volume doen veranderen. Los maar eens 100 gram suiker in een kilo water op en kijk hoe weinig het volume verandert.
Wat betreft de omgevingsvariabelen die .oisyn noemt, daarvan denk ik niet dat de omgevingsdruk problematisch is, die is vrij goed te controleren en die kan je natuurlijk meenemen in je definitie. Temperatuur iets lastiger te controleren, maar dat geldt natuurlijk ook voor de huidige metalen kilo :)
  • leuk_he
leuk_he
Van standaard water is ongeveer 1 op de 6000 moleculen zwaar water. VOor zo'n licht element as water maakt het dus uit. Maar er zijn dus allerlei voorstellen voor:
http://en.wikipedia.org/w...oposed_future_definitions
MSalters schreef op maandag 17 september 2007 @ 21:24:
jaha, maar dat zei ik niet he... O-)
  • Vinnienerd
  • Laatst online: 10:50
Het leuke van dit probleem is dat wetenschappers toch wel een permanente oplossing zullen vinden :P
  • Dido
  • Laatst online: 26-10 14:39
Dido
heforshe
eamelink schreef op vrijdag 05 oktober 2007 @ 12:50:
Kan ik allemaal inkomen, maar als ik kijk naar de definitie van de seconde en ik zie daar 0K genoemd staan, dan is het eerste wat ik denk: da's dus niet te meten, maar alleen te berekenen.
Waarom mag dat bij de seconde wel, en is het voor de kilo een probleem?
[quoe]Temperatuur iets lastiger te controleren, maar dat geldt natuurlijk ook voor de huidige metalen kilo :)[/quote]
Gelukkig dat die temperatuur de massa van de huidige kilo niet beinvloed ;)
Wat betekent mijn avatar?
  • hstoker
  • Laatst online: 10:36
hstoker
Yatta!
Edmin schreef op vrijdag 14 september 2007 @ 18:21:
Je had het zelfs in de OP kunnen lezen...
Dutch: If it bleeds, we can kill it.
Dat klopt niet. Als de kilo kleiner wordt (minder massa heeft) betekend dat niet dat jij ook minder gaat wegen, maar juist andersom. Als ik op de weegschaal gaat staan lijkt het er inderdaad op dat de "kilogram" waarmee het ding geijkt is kleiner is geworden. Ik weeg 85 kg maar de weegschaal geeft 95 kg aan! Ergo, ik weeg en wordt te zwaar bevonden. . .dank zij die "standaard kilogram" de minder weegt dan voorheen :(
