[MSSQL/PHP]
  • 1.290 views sinds 30-01-2008
  • Yahiko750
  • Laatst online: 14-10 01:11
Hoi allemaal,
Ik heb extreem weinig ervaring op het gebied van MSSQL2000 en ben op dit moment dus aan het stoeien met een script.
<?php
$dbhost = "localhost";
$dbuser = "xxxx";
$dbpass = "xxxx";
$dbworld = 'xxxx';
$dblogin = 'xxxx';
if (!$_POST)
<form action="create-account.php" method="post">
Account: <input type="text" name="Account" maxlength=10 ><br>
Password: <input type="password" name="password" maxlength=10 ><br>
Password: <input type="password" name="password2" maxlength=10 ><br>
E-Mail: <input type="text" name="email"><br>
Real Name: <input type="text" name="realname"><br>
Secret Q: <input type="text" name="question"><br>
Secret A: <input type="text" name="answer"><br>
<input type="submit" value="Create Account"><br>
</form>
<?php
else {
$Account=$_POST['Account'];
$password=$_POST['password'];
$password2=$_POST['password2'];
$email=$_POST['email'];
$q=$_POST['question'];
$a=$_POST['answer'];
$realname=$_POST['realname'];
if ($password != $password2) die("Passwords do not match<br>");
if(!ereg(".",$email) or !ereg("@",$email)) die("Please type a valid Email.<br>".$date);
$ip=getenv("REMOTE_ADDR");
$msconnect=mssql_connect("$dbhost","$dbuser","$dbpass");
if ($msconnect)
mssql_select_db($dblogin, $msconnect);
$accidrow = mssql_query ("select * from ACCOUNT_T",$msconnect);
$Accountid = mssql_num_rows($accidrow) + 1001;
$query = "INSERT INTO ACCOUNT_T VALUES ('".$Account."','".$password."', '".$Accountid."', '".$ip."', '0', '03/04/2002', NULL, NULL, NULL, '".$realname."', NULL,'".$email."', NULL, '".$q."', '".$a."', '4/5/15', NULL, '500', NULL)";
$end = mssql_query ($query, $msconnect );
if ($end)
echo "Account created,you can log in<br>";
mssql_close($msconnect);
Ik krijg de volgende, vreemd in mijn ogen lijkende, foutmelding:
Warning: mssql_query() [function.mssql-query]: message: An explicit value for the identity column in table 'ACCOUNT_T' can only be specified when a column list is used and IDENTITY_INSERT is ON. (severity 16) in C:\Webserver\htdocs\hbusa.savium.net\create-account.php on line 48
Warning: mssql_query() [function.mssql-query]: Query failed in C:\Webserver\htdocs\hbusa.savium.net\create-account.php on line 48
Iemand enig idee hoe ik dit eventueel gefixt krijg?
  • Tubby
  • Laatst online: 14-10 23:14
Tubby
or not to be
Je insert columns specifieren, je probeert een waarde in de primary key column te stoppen welke op identity seed staat.
Probeer de query eerst werkend te krijgen via de Query Analyser in je Enterprise Manager.
[ Voor 28% gewijzigd door Tubby op 08-09-2007 20:30 ]
tubby.nl - Artes Moriendi - q1 - bf1942 - WoT - pubg - LinkedIN
  • Snake
  • Laatst online: 07-03-2024
Snake
Los Angeles, CA, USA
1) zet je code tussen PHP-tags
2) je code is daadwerkelijk verschrikkelijk. Een single quote "'" in je input, en alles ligt overhoop.
3) zorg eerst dat je query bolt in een of ander tooltje van MSSQL.
4) lees de errors, PHP geeft zowat de meest verbose errors!
Going for adventure, lots of sun and a convertible! | GMT-8
  • NMe
  • Laatst online: 29-09 10:17
NMe
Quia Ego Sic Dico.
Je zal hier inderdaad even de expliciete manier van schrijven moeten gebruiken:
SQL:
INSERT INTO tabel (veld1, veld2) VALUES ("waarde1", "waarde2")
Dat is overigens iets wat best wel uit de foutmelding te halen is, en bovendien na wat Googlen ook wel op te lossen is. ;) Vandaar ook dat ik je topic sluit, je zal er verder wel uit kunnen komen. :)
Overigens: Hoe post je code? / Hoe gebruik je de code tag? :)
