PHP/Flash(Javascript)/HTML] Uploader Probleem.
  • 80 views sinds 30-01-2008
Hoi ik ben al vanaf 16:00 uur bezig met het volgende.
Een upload script.
De scripten:
SampleUpload.html (Deze staat in www.domein.com/upload)
<head>
    <meta>
    <title>BelgiumBass Upload!</title>
    <link>
</head>
<body>
<table>
    <tr>
        <td>
            <font>
                You need at least 8 version of Flash player. Download last version
                <a target="_blank" href="http://www.adobe.com/shockwave/download/alternates/">here</a>
            </font><br>
<OBJECT id="FlashFilesUpload" codeBase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0" width="450" height="350" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000">
        <Replace>
    <embed bgcolor="#F8F6E6" id="EmbedFlashFilesUpload" src="ElementITMultiPowUpload1.7.swf" quality="high" pluginspage="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="450" height="350" flashvars="uploadUrl=">
    </embed>
  </OBJECT>
        </td>
    </tr>
</table>
<hr>
<a href="Default.html" title="Other examples">Other examples</a>
</body>
</html>
Het PHP Bestandje dat je nodig hebt: uploadfiles.php (deze staat ook op www.domein.com/upload)
<?php
// In PHP versions earlier than 4.1.0, $HTTP_POST_FILES should be used instead
// of $_FILES.
echo 'Upload result:<br>'; // At least one symbol should be sent to response!!!
$uploaddir = dirname($_SERVER['SCRIPT_FILENAME'])."database";
$target_encoding = "ISO-8859-1";
echo '<pre>';
if(count($_FILES) > 0)
    $arrfile = pos($_FILES);
    $uploadfile = $uploaddir . iconv("UTF-8", $target_encoding,basename($arrfile['name']));
           if (move_uploaded_file($arrfile['tmp_name'], $uploadfile))
       echo "File is valid, and was successfully uploaded.\n";
else
    echo 'No files sent. Script is OK!'; //Say to Flash that script exists and can receive files
echo 'Here is some more debugging info:';
print_r($_FILES);
echo "</pre>";
En als het goed is zouden alle bestanden dan op: www.domein.com/upload/database komen?
Ziet iemand wat ik fout doe?
De error:
Upload script URL (uploadUrl parameter) is empty!
[ Voor 7% gewijzigd door Verwijderd op 04-09-2007 19:32 ]
  • Snake
  • Laatst online: 07-03-2024
Snake
Los Angeles, CA, USA
Regel 16 van SampleUpload.html
Op het einde: flashvars="uploadUrl="
uploadUrl, vul die eens in :)
Going for adventure, lots of sun and a convertible! | GMT-8
Snake schreef op dinsdag 04 september 2007 @ 19:29:
ik heb die ene " toegevoegt.
Maar nog steeds de error.
  • Snake
Snake
Verwijderd schreef op dinsdag 04 september 2007 @ 19:36:
Daar gaat t niet om, ge moet een volledige url erin vullen, naar het uploadscript!
if (move_uploaded_file($arrfile['tmp_name'], $uploadfile)) "FlashVars" VALUE="uploadUrl="/uploadfiles.php"
Zo dus?
  • Snake
Snake
flashvars="uploadUrl=/uploadfiles.php"
zo dus :)
thats normaal it :)
HTTP Error, '404' occurred. Page not found. Can't find '/uploadfiles.php' page on server!
Please see http://www.w3.org/Protoco...2616-sec10.html#sec10.4.5 error code definitions for more information.
is de error nu.
  • dB90
  • Laatst online: 26-01 11:45
flashvars="uploadUrl=/upload/uploadfiles.php"
Webberry Webdevelopment
<PARAM NAME="FlashVars" VALUE="uploadUrl="/upload/uploadfiles.php">
heb ik nu.
Maar dan test ik er een.
Staat er upload compleeded, en dan vervolgens niks op de server?
  • dB90
ja ehm debuggen :+
  • we_are_borg
  • Laatst online: 13-10 16:39
we_are_borg
You will Comply
Verwijderd schreef op dinsdag 04 september 2007 @ 20:06:
heb ik nu.
Is de dir schrijfbaar voor bestanden.
You need the computing power of a P1, 16 MB RAM and 1 GB Harddisk to run Win95. It took the computing power of 3 Commodore 64 to fly to the Moon. Something is wrong here, and it wasn't the Apollo.
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Op code van derden geven we hier sowieso geen 'support', daarvoor mag je de makers mailen. Los daarvan is dit gewoon debug-werk en zijn we hier niet om je aan je handje te houden tijdens het debuggen. Hier moet je prima zelf uit kunnen komen met wat moeite.
Neem onze Programming Beleid Quickstart een door, en zie ook even quickfixes.
Je eigen tweaker.me redirect
Over mij
