[gentoo]compiz compile error (No rule to make target)
  • 111 views sinds 30-01-2008
nu wil ik dus compiz-fusion updaten.. en hij heeft alles mooi verwijdert... maar bij het emergen van de nieuwe compiz krijg ik een compile error:
/var/tmp/portage/x11-wm/compiz-9999/temp/build.log
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
the following optional plugins will be compiled:
  glib:     yes
  gconf:    yes
  kconfig:  no
  place:    yes
  dbus:     yes
  annotate: yes
  svg:      yes
  inotify:  yes
  fuse:     yes
and the following optional features will be compiled:
  gtk:      yes
  metacity: yes
  gnome:    yes
  kde:      no
make  all-recursive
make[1]: Entering directory `/var/tmp/portage/x11-wm/compiz-9999/work/compiz-9999'
Making all in include
make[2]: Entering directory `/var/tmp/portage/x11-wm/compiz-9999/work/compiz-9999/include'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/var/tmp/portage/x11-wm/compiz-9999/work/compiz-9999/include'
Making all in src
make[2]: Entering directory `/var/tmp/portage/x11-wm/compiz-9999/work/compiz-9999/src'
i686-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/libxml2 -I/usr/include/startup-notification-1.0 -I../include -DPLUGINDIR=\"/usr/lib/compiz\" -DIMAGEDIR=\"/usr/share/compiz\" -DMETADATADIR=\"/usr/share/compiz\"    -march=prescott -O2 -pipe -fomit-frame-pointer -Wall -Wpointer-arith -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wnested-externs -D_FORTIFY_SOURCE=2 -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.c
mv -f .deps/main.Tpo .deps/main.Po
i686-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/libxml2 -I/usr/include/startup-notification-1.0 -I../include -DPLUGINDIR=\"/usr/lib/compiz\" -DIMAGEDIR=\"/usr/share/compiz\" -DMETADATADIR=\"/usr/share/compiz\"    -march=prescott -O2 -pipe -fomit-frame-pointer -Wall -Wpointer-arith -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wnested-externs -D_FORTIFY_SOURCE=2 -MT privates.o -MD -MP -MF .deps/privates.Tpo -c -o privates.o privates.c
mv -f .deps/privates.Tpo .deps/privates.Po
make[2]: *** No rule to make target `object.o', needed by `compiz'.  Stop.
make[2]: Leaving directory `/var/tmp/portage/x11-wm/compiz-9999/work/compiz-9999/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/x11-wm/compiz-9999/work/compiz-9999'
make: *** [all] Error 2
!!! ERROR: x11-wm/compiz-9999 failed.
Call stack:
  ebuild.sh, line 1638:   Called dyn_compile
  ebuild.sh, line 985:   Called qa_call 'src_compile'
  ebuild.sh, line 44:   Called src_compile
  compiz-9999.ebuild, line 73:   Called die
!!! make failed
!!! If you need support, post the topmost build error, and the call stack if relevant.
!!! A complete build log is located at '/var/tmp/portage/x11-wm/compiz-9999/temp/build.log'.
een revdep-rebuild heeft niets geholpen 8)7
[ Voor 23% gewijzigd door Verwijderd op 30-08-2007 19:47 ]
  • Bastiaan V
Bastiaan V
Tux's lil' helper
simpel antwoord: ff wachten tot de patches gefixed zijn.
iets meer details: http://lists.freedesktop....z/2007-August/002616.html
  • Boudewijn
Boudewijn
omdat het kan
aan de versie te zien is het een SVN ebuild oid. daar heb je dat hoor ;)
gewoon dagje wachten en resyncen.
Boudewijn schreef op donderdag 30 augustus 2007 @ 19:54:
Zoals Bert van Bert & Ernie al zei: "Wachten duurt lang lang lang..."
  • Boudewijn
Boudewijn
omdat het kan
tsja weet je als je svn zooi draait.
aan de error kun je ook weinig doen zonder je er fors in te verdiepen schat ik zo in :/
hoe kan ik eigenlijk zien wanneer ik compiz wel kan mergen?..
  • Boudewijn
Boudewijn
omdat het kan
pfff resyncen en daarna gewoon weer proberen?
probeer het morgen wel weer s :P
bij de weg.. emerge compiz enz. doet iets met git://
morgen zit ik weer achter een proxy.. maar hoe stel ik die in voor git?
export git_proxy=... werkt niet :P
(morgen anders maar s googlen)
en we zijn los ;) compiz compiled weer.. thnx dudes ;)
