Sinds kort ben ik in het bezit van een LG GSA-H54L.
In het begin brandde hij perfect en zonder problemen op 16x
Helaas genereerd Nero nu meteen een foutmelding als ik wil gaan branden.
Ik kan er geen wijs uit worden, misschien iemand van jullie?
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=?.?.?.?, size=30208 bytes, created 11-6-1997 19:01:02
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder: <HL-DT-ST DVD-RAM GSA-H54L>Version: 1.00 - HA 1 TA 1 - 7.10.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <IDE DVD-ROM 16X >Version: 2.71 - HA 1 TA 0 - 7.10.1.0
=== Scsi-Device-Map ===
DiskPeripheral : ST3160021A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : IDE DVD-ROM 16X atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST DVD-RAM GSA-H54L atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
IDE DVD-ROM 16X K: CdRom0
HL-DT-ST DVD-RAM GSA-H54L L: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2096624kB)
Free physical memory: 1456MB (1491060kB)
Memory in use : 28 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.8.2007
UDF/ISO compilation
14:07:36 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
14:07:36 #2 Phase 112 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation started
14:07:36 #3 Phase 114 File dlgbrnst.cpp, Line 1762
DVD-Video files reallocation completed (no file modified)
14:07:36 #4 Text 0 File Isodoc.cpp, Line 6666
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
14:07:36 #5 Phase 111 File dlgbrnst.cpp, Line 1762
DVD-Video files sorted
14:07:36 #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
14:07:36 #7 ISO9660GEN -11 File Geniso.cpp, Line 3343
14:07:36 #8 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
14:07:36 #9 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2058783 (457:30.33, 4021MB)
14:07:36 #10 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
14:07:36 #11 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: HL-DT-ST DVD-RAM GSA-H54L, Media type: DVD+R
Disc Manufacturer ID: MBIPG101, Media Type ID: R05, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 7
14:07:36 #12 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
14:07:36 #13 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2058784 (2058784) = #2058784/457:30.34
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2058784 blocks [L: HL-DT-ST DVD-RAM GSA-H54L]
14:07:36 #14 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [L: HL-DT-ST DVD-RAM GSA-H54L] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4216389632, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2058784 | 0 | 0x00
2058784 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
14:07:36 #15 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
14:07:36 #16 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
14:07:36 #17 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
14:07:36 #18 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
14:07:36 #19 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
14:07:36 #20 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 4x (5.540 KB/s)
14:07:36 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:07:36 #22 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Media type ID: R05
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 42 49 50 47 - 31 30 31 52 30 35 01 38 ...MBIPG101R05.8
23 54 37 11 02 3C 6E 02 - 84 68 15 15 0B 0B 08 08 #T7..<n..h......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
14:07:36 #23 Text 0 File DVDR.cpp, Line 6553
Drive: HL-DT-ST DVD-RAM GSA-H54L
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
14:07:36 #24 CDR -1207 File DVDR.cpp, Line 6477
Book Type automatically set to: DVD-ROM
14:07:36 #25 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x08e3e240: Len x648
14:07:36 #26 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
14:07:36 #27 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
14:07:46 #28 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x80
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 0C 80
Buffer x09310040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
14:07:46 #29 CDR -1135 File Writer.cpp, Line 303
Write error
14:07:46 #30 Phase 127 File dlgbrnst.cpp, Line 1762
Generating DVD high compatibility borders
14:07:46 #31 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 0
14:07:46 #32 Phase 129 File dlgbrnst.cpp, Line 1762
Generating DVD borders completed successfully
14:07:46 #33 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 4x (5.540 KB/s)
14:07:47 #34 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
14:07:53 #35 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
14:07:53 #36 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Windows XP 5.1
IA32
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Use Inquiry : 1
30.8.2007
UDF/ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet : FALSE
DAO infos:
MCN: ""
DAO layout:
Media type ID: R05
Sense Code: 0x24
Sense Qual: 0x00
Sense Code: 0x0C
Sense Qual: 0x80
Write error
Existing drivers:
Registry Keys:
