[XEN kernel 2.6.18] VFS: Cannot open root device
  • 1.178 views sinds 30-01-2008
  • Centauriprime
  • Laatst online: 01:03
Mijn Systeem
een Asrock ALIVENF6G-VSTA
HDD een 3Ware 9650SE-8LP DISK PCI-E
Ik heb op dit systeem Debian gezet met kernel 2.6.21
Gekozen filesystem en partities
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
== FILESYSTEMS =================================================================
--[ Cmd: /sbin/fdisk -l 2>/dev/null ]--(0755, root, root, 84624)----------------
Disk /dev/sda: 1279.9 GB, 1279954780160 bytes
255 heads, 63 sectors/track, 155612 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *           1          36      289138+  83  Linux
/dev/sda2              37      155612  1249664220    5  Extended
/dev/sda5              37        1252     9767488+  83  Linux
/dev/sda6            1253        1501     2000061   82  Linux swap / Solaris
/dev/sda7            1502      155612  1237896576   8e  Linux LVM
--[ Cmd: /sbin/sfdisk -l ]--(0755, root, root, 58512)---------------------------
Disk /dev/sda: 155612 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0
   Device Boot Start     End   #cyls    #blocks   Id  System
/dev/sda1   *      0+     35      36-    289138+  83  Linux
/dev/sda2         36  155611  155576  1249664220    5  Extended
/dev/sda3          0       -       0          0    0  Empty
/dev/sda4          0       -       0          0    0  Empty
/dev/sda5         36+   1251    1216-   9767488+  83  Linux
/dev/sda6       1252+   1500     249-   2000061   82  Linux swap / Solaris
/dev/sda7       1501+ 155611  154111- 1237896576   8e  Linux LVM
--[ Cmd: /bin/df -h ]--(0755, root, root, 37616)--------------------------------
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda5             9.2G  1.9G  6.9G  22% /
tmpfs                 495M     0  495M   0% /lib/init/rw
udev                   10M   68K   10M   1% /dev
tmpfs                 495M     0  495M   0% /dev/shm
/dev/sda1             274M   35M  225M  14% /boot
--[ Cmd: /bin/mount  ]--(4755, root, root, 88744)-------------------------------
/dev/sda5 on / type ext3 (rw,errors=remount-ro)
tmpfs on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
procbususb on /proc/bus/usb type usbfs (rw)
udev on /dev type tmpfs (rw,mode=0755)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=620)
/dev/sda1 on /boot type ext3 (rw)
--[ File: /etc/fstab ]--(0644, root, root, 464)---------------------------------
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    defaults        0       0
/dev/sda5       /               ext3    defaults,errors=remount-ro 0       1
/dev/sda1       /boot           ext3    defaults        0       2
/dev/sda6       none            swap    sw              0       0
/dev/hda        /media/cdrom0   udf,iso9660 user,noauto     0       0
Alles werkt zonder problemen.
Toen XEN OpenSource gedownload en geinstalleerd
Das met kernel 2.6.18
make linux-2.6-xen0-config CONFIGMODE=menuconfig KERNELS="linux-2.6-xen0"
make linux-2.6-xen0-build
make linux-2.6-xen0-install
depmod 2.6.18-xen0
update-grub
De Sata raid controller (3w9xxx) en het filesystem (Ext3) ingebakken in de kernel.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
# SCSI low-level drivers
# CONFIG_ISCSI_TCP is not set
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
CONFIG_SCSI_3W_9XXX=y
CONFIG_SCSI_SATA=y
# File systems
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
CONFIG_EXT3_FS_XATTR=y
CONFIG_EXT3_FS_POSIX_ACL=y
CONFIG_EXT3_FS_SECURITY=y
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=y
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
# CONFIG_REISERFS_FS_XATTR is not set
# CONFIG_JFS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_XFS_FS=y
# CONFIG_XFS_QUOTA is not set
# CONFIG_XFS_SECURITY is not set
# CONFIG_XFS_POSIX_ACL is not set
# CONFIG_XFS_RT is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_ROMFS_FS is not set
CONFIG_INOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_QUOTA=y
CONFIG_QFMT_V1=m
CONFIG_QFMT_V2=m
CONFIG_QUOTACTL=y
CONFIG_DNOTIFY=y
CONFIG_AUTOFS_FS=y
CONFIG_AUTOFS4_FS=y
Maar nu krijg ik dus de melding \
VFS: Cannot open root device "sda5" or unknown-block(0,0)
Gebruikte menu.lst (Grub)
title       Xen 3.1.0 / Debian GNU/Linux, kernel 2.6.18-xen0
root        (hd0,0)
kernel      /xen-3.1.0.gz
module      /vmlinuz-2.6.18-xen0 root=/dev/sda5 ro console=tty0
savedefault
root        (hd0,0)
module      /vmlinuz-2.6.18-xen root=/dev/sda5 ro console=tty0
savedefault
title       Debian GNU/Linux, kernel 2.6.21-2-amd64
root        (hd0,0)
kernel      /vmlinuz-2.6.21-2-amd64 root=/dev/sda5 ro
initrd      /initrd.img-2.6.21-2-amd64
savedefault
title       Debian GNU/Linux, kernel 2.6.21-2-amd64 (single-user mode)
root        (hd0,0)
kernel      /vmlinuz-2.6.21-2-amd64 root=/dev/sda5 ro single
savedefault
Ik heb het een keer werkend gekregen zonder initrd. enkel het nodige in de kernel.
Alleen wou ik nog een keer vanaf scratch op nieuw beginnen.
En nu lukt het niet meer.
Iemand misschien suggesties wat ik vergeten kan zijn.
Volledige config.
15x330 SW38
  • MrBarBarian
  • Laatst online: 07-03-2023
Volgens mij ben je je initrd vergeten ;)
Ofwel geen drivers (static) voor je HD-controller in je kernel, dus heb je een initrd nodig.
iRacing Profiel
  • Centauriprime
Het is de eerste keer ook gelukt zonder initrd. :?
Alles zit verder in de kernel.
15x330 SW38
  • deadinspace
  • Laatst online: 16-10 14:15
deadinspace
The what goes where now?
Je hebt ook drivers voor andere controllers (op je moederbord neem ik aan) aanstaan, misschien hangt daar een drive aan die sda wordt, waardoor je boot-array een andere naam krijgt, sbd bijvoorbeeld? Als je host-kernel boot, ziet hij dan je 3ware controller wel?
Debian heeft overigens -xen kernels en andere Xen packages in de repository, dus misschien is zelf een kernel compilen helemaal niet nodig?
Laat eens een dmesg zien van de stock debian kernel zien. Dan kan je eens nagaan welke modules/drivers er geladen worden voor het aansturen van je hd
  • Centauriprime
deadinspace schreef op donderdag 23 augustus 2007 @ 15:48:
Ja wat er in Debian zit is te oud 3.0.2 dacht ik.
Hier de volledige dmesg
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
Linux version 2.6.21-2-amd64 (Debian 2.6.21-6~bpo.1) (nobse@backports.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Fri Jul 13 10:58:39 UTC 2007
Command line: root=/dev/sda5 ro
BIOS-provided physical RAM map:
 BIOS-e820: 0000000000000000 - 000000000009f400 (usable)
 BIOS-e820: 000000000009f400 - 00000000000a0000 (reserved)
 BIOS-e820: 00000000000e8000 - 0000000000100000 (reserved)
 BIOS-e820: 0000000000100000 - 000000003efb0000 (usable)
 BIOS-e820: 000000003efb0000 - 000000003efc0000 (ACPI data)
 BIOS-e820: 000000003efc0000 - 000000003eff0000 (ACPI NVS)
 BIOS-e820: 000000003eff0000 - 000000003f000000 (reserved)
 BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
 BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
 BIOS-e820: 00000000ff380000 - 0000000100000000 (reserved)
Entering add_active_range(0, 0, 159) 0 entries of 3200 used
Entering add_active_range(0, 256, 257968) 1 entries of 3200 used
end_pfn_map = 1048576
DMI present.
ACPI: RSDP 000FA870, 0014 (r0 ACPIAM)
ACPI: RSDT 3EFB0000, 0034 (r1 A_M_I  OEMRSDT   8000708 MSFT       97)
ACPI: FACP 3EFB0200, 0084 (r2 A M I  OEMFACP  12000601 MSFT       97)
ACPI: DSDT 3EFB0440, 4C5F (r1  ALV6V ALV6V172      172 INTL 20051117)
ACPI: FACS 3EFC0000, 0040
ACPI: APIC 3EFB0390, 0070 (r1 A_M_I  OEMAPIC   8000708 MSFT       97)
ACPI: MCFG 3EFB0400, 003C (r1 A_M_I  OEMMCFG   8000708 MSFT       97)
ACPI: OEMB 3EFC0040, 0060 (r1 A_M_I  AMI_OEM   8000708 MSFT       97)
Scanning NUMA topology in Northbridge 24
Number of nodes 1
Node 0 MemBase 0000000000000000 Limit 000000003efb0000
NUMA: Using 63 for the hash shift.
Using node hash shift of 63
Bootmem setup node 0 0000000000000000-000000003efb0000
Zone PFN ranges:
  DMA             0 ->     4096
  DMA32        4096 ->  1048576
  Normal    1048576 ->  1048576
early_node_map[2] active PFN ranges
    0:        0 ->      159
    0:      256 ->   257968
On node 0 totalpages: 257871
  DMA zone: 56 pages used for memmap
  DMA zone: 978 pages reserved
  DMA zone: 2965 pages, LIFO batch:0
  DMA32 zone: 3470 pages used for memmap
  DMA32 zone: 250402 pages, LIFO batch:31
  Normal zone: 0 pages used for memmap
Nvidia board detected. Ignoring ACPI timer override.
If you got timer trouble try acpi_use_timer_override
ACPI: PM-Timer IO Port: 0x4008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 (Bootup-CPU)
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Processor #1
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: BIOS IRQ0 pin2 override ignored.
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
ACPI: IRQ9 used by override.
ACPI: IRQ14 used by override.
ACPI: IRQ15 used by override.
Setting APIC routing to physical flat
Using ACPI (MADT) for SMP configuration information
Nosave address range: 000000000009f000 - 00000000000a0000
Nosave address range: 00000000000a0000 - 00000000000e8000
Nosave address range: 00000000000e8000 - 0000000000100000
Allocating PCI resources starting at 40000000 (gap: 3f000000:bfc00000)
SMP: Allowing 2 CPUs, 0 hotplug CPUs
PERCPU: Allocating 37504 bytes of per cpu data
Built 1 zonelists.  Total pages: 253367
Kernel command line: root=/dev/sda5 ro
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 32768 bytes)
time.c: Detected 1908.562 MHz processor.
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Checking aperture...
CPU 0: aperture @ 83fc000000 size 32 MB
Aperture too small (32 MB)
No AGP bridge found
Memory: 1006660k/1031872k available (1982k kernel code, 24824k reserved, 933k data, 296k init)
Calibrating delay using timer specific routine.. 3821.09 BogoMIPS (lpj=7642189)
Security Framework v1.0.0 initialized
SELinux:  Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 256
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU 0/0 -> Node 0
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
SMP alternatives: switching to UP code
ACPI: Core revision 20070126
Using local APIC timer interrupts.
result 12556349
Detected 12.556 MHz APIC timer.
SMP alternatives: switching to SMP code
Booting processor 1/2 APIC 0x1
Initializing CPU#1
Calibrating delay using timer specific routine.. 3817.36 BogoMIPS (lpj=7634733)
CPU 1/1 -> Node 0
CPU: Processor Core ID: 1
AMD Athlon(tm) 64 X2 Dual Core Processor 3600+ stepping 01
Brought up 2 CPUs
migration_cost=328
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: BIOS Bug: MCFG area at e0000000 is not E820-reserved
PCI: Not using MMCONFIG.
PCI: Using configuration type 1
ACPI: Interpreter enabled
ACPI: (supports S0 S1 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
Error attaching device data
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:00:0d.0
PCI: Transparent bridge - 0000:00:04.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR10._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR11._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEA] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEB] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEC] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNED] (IRQs 16 17 18 19) *5
ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *5
ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *7
ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LACI] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LMC9] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *11
ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LSA1] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: ACPI device : hid PNP0A03
pnp: ACPI device : hid PNP0200
pnp: ACPI device : hid PNP0B00
pnp: ACPI device : hid PNP0800
pnp: ACPI device : hid PNP0C04
pnp: ACPI device : hid PNP0C02
pnp: ACPI device : hid PNP0303
pnp: ACPI device : hid PNP0F03
pnp: ACPI device : hid PNP0C01
pnp: PnP ACPI: found 12 devices
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
NET: Registered protocol family 8
NET: Registered protocol family 20
pnp: the driver 'system' has been registered
pnp: match found with the PnP device '00:05' and the driver 'system'
pnp: 00:05: iomem range 0x0-0x0 could not be reserved
pnp: 00:05: iomem range 0xfefe0000-0xfefe01ff has been reserved
pnp: 00:05: iomem range 0xfefe1000-0xfefe1fff has been reserved
pnp: 00:05: iomem range 0xfee01000-0xfeefffff has been reserved
pnp: match found with the PnP device '00:06' and the driver 'system'
pnp: 00:06: iomem range 0xfec00000-0xfec00fff could not be reserved
pnp: 00:06: iomem range 0xfee00000-0xfee00fff could not be reserved
pnp: match found with the PnP device '00:09' and the driver 'system'
pnp: 00:09: ioport range 0x290-0x29f has been reserved
pnp: match found with the PnP device '00:0a' and the driver 'system'
pnp: 00:0a: iomem range 0xe0000000-0xefffffff has been reserved
pnp: match found with the PnP device '00:0b' and the driver 'system'
pnp: 00:0b: iomem range 0x0-0x9ffff could not be reserved
pnp: 00:0b: iomem range 0xc0000-0xcffff has been reserved
pnp: 00:0b: iomem range 0xe0000-0xfffff could not be reserved
pnp: 00:0b: iomem range 0x100000-0x3fffffff could not be reserved
PCI: Bridge: 0000:00:04.0
  IO window: d000-dfff
  MEM window: dfe00000-dfefffff
  PREFETCH window: 40000000-400fffff
PCI: Bridge: 0000:00:09.0
  IO window: e000-efff
  MEM window: dff00000-dfffffff
  PREFETCH window: da000000-dbffffff
PCI: Bridge: 0000:00:0b.0
  IO window: disabled.
  MEM window: disabled.
  PREFETCH window: disabled.
PCI: Bridge: 0000:00:0c.0
PCI: Setting latency timer of device 0000:00:04.0 to 64
PCI: Setting latency timer of device 0000:00:09.0 to 64
PCI: Setting latency timer of device 0000:00:0b.0 to 64
PCI: Setting latency timer of device 0000:00:0c.0 to 64
Time: acpi_pm clocksource has been installed.
IP route cache hash table entries: 32768 (order: 6, 262144 bytes)
TCP established hash table entries: 131072 (order: 9, 3145728 bytes)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
checking if image is initramfs... it is
Freeing initrd memory: 5096k freed
audit: initializing netlink socket (disabled)
audit(1187944003.844:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:09.0:pcie00]
Allocate Port Service[0000:00:0b.0:pcie00]
Allocate Port Service[0000:00:0c.0:pcie00]
Real Time Clock Driver v1.12ac
Linux agpgart interface v0.102 (c) Dave Jones
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
pnp: the driver 'serial' has been registered
RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
pnp: the driver 'i8042 kbd' has been registered
pnp: match found with the PnP device '00:07' and the driver 'i8042 kbd'
pnp: the driver 'i8042 aux' has been registered
pnp: match found with the PnP device '00:08' and the driver 'i8042 aux'
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 296k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 23
ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LUB2] -> GSI 23 (level, low) -> IRQ 23
PCI: Setting latency timer of device 0000:00:02.1 to 64
ehci_hcd 0000:00:02.1: EHCI Host Controller
ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:02.1: debug port 1
PCI: cache line size of 64 is not supported by device 0000:00:02.1
ehci_hcd 0000:00:02.1: irq 23, io mem 0xdfdfec00
ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 10 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
pnp: the driver 'ide' has been registered
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.60.
SCSI subsystem initialized
3ware 9000 Storage Controller device driver for Linux v2.26.02.008.
ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [LMAC] -> GSI 22 (level, low) -> IRQ 22
PCI: Setting latency timer of device 0000:00:07.0 to 64
forcedeth: using HIGHDMA
eth0: forcedeth.c: subsystem: 01849:03ef bound to 0000:00:07.0
r8169 Gigabit Ethernet driver 2.2LK-NAPI loaded
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 19
ACPI: PCI Interrupt 0000:01:08.0[A] -> Link [LNKA] -> GSI 19 (level, low) -> IRQ 19
eth1: RTL8169s/8110s at 0xffffc20000022c00, 00:14:c1:0f:72:3f, IRQ 19
ACPI: PCI Interrupt Link [LNED] enabled at IRQ 18
ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [LNED] -> GSI 18 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:02:00.0 to 64
ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUB0] -> GSI 21 (level, low) -> IRQ 21
PCI: Setting latency timer of device 0000:00:02.0 to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:02.0: irq 21, io mem 0xdfdff000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 10 ports detected
3w-9xxx: scsi0: AEN: WARNING (0x04:0x0008): Unclean shutdown detected:unit=0.
scsi0 : 3ware 9000 Storage Controller
3w-9xxx: scsi0: Found a 3ware 9000 Storage Controller at 0xdffff000, IRQ: 18.
3w-9xxx: scsi0: Firmware FE9X 3.08.02.005, BIOS BE9X 3.08.00.002, Ports: 8.
NFORCE-MCP61: IDE controller at PCI slot 0000:00:06.0
NFORCE-MCP61: chipset revision 162
NFORCE-MCP61: not 100% native mode: will probe irqs later
NFORCE-MCP61: 0000:00:06.0 (rev a2) UDMA133 controller
    ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
Probing IDE interface ide0...
scsi 0:0:0:0: Direct-Access     AMCC     9650SE-8LP DISK  3.08 PQ: 0 ANSI: 5
SCSI device sda: 2499911680 512-byte hdwr sectors (1279955 MB)
sda: Write Protect is off
sda: Mode Sense: 23 00 00 00
SCSI device sda: write cache: enabled, read cache: disabled, doesn't support DPO or FUA
 sda: sda1 sda2 < sda5 sda6 sda7 >
sd 0:0:0:0: Attached scsi disk sda
hda: AOPEN DVD1648/AAP, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
libata version 2.20 loaded.
hda: ATAPI 48X DVD-ROM drive, 512kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Attempting manual resume
kjournald starting.  Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
input: PC Speaker as /class/input/input1
input: PS2++ Logitech Wheel Mouse as /class/input/input2
Adding 2000052k swap on /dev/sda6.  Priority:-1 extents:1 across:2000052k
EXT3 FS on sda5, internal journal
loop: loaded (max 8 devices)
device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised: dm-devel@redhat.com
EXT3 FS on sda1, internal journal
r8169: eth0: link up
15x330 SW38
  • CyBeR
CyBeR
Ik vind dat een interessante. Die staat namelijk bij mijn kernel voor een 3Ware 8000 wel aan.
  • Centauriprime
CyBeR schreef op vrijdag 24 augustus 2007 @ 09:42:
Bedankt.
Klopt maar ik heb een 9650SE-8LP, die gebruikt de 3w-9xxx.
15x330 SW38
  • BoAC
  • Laatst online: 10-10 15:06
BoAC
Memento mori
Kun je even je complete .config posten?
Van je nieuwe kernel bedoel ik dan ;)
[ Voor 43% gewijzigd door BoAC op 24-08-2007 11:10 ]
  • Centauriprime
BoAC schreef op vrijdag 24 augustus 2007 @ 11:07:
Staat in de start post, onderaan.
15x330 SW38
  • BoAC
BoAC
Memento mori
Sorry niet goed gelezen.
[ Voor 93% gewijzigd door BoAC op 24-08-2007 13:08 ]
  • Centauriprime
Iemand nog een idee??
15x330 SW38
  • Centauriprime
Het is gelukt.
Ik heb dit veranderd.
# CONFIG_BLK_DEV_OFFBOARD is not set
naar
CONFIG_BLK_DEV_OFFBOARD=y
CONFIG_IDEDMA_PCI_AUTO=y
naar
# CONFIG_IDEDMA_PCI_AUTO is not set
CONFIG_IDEDMA_AUTO=y
naar
# CONFIG_IDEDMA_AUTO is not set
[ Voor 88% gewijzigd door Centauriprime op 03-09-2007 18:37 ]
15x330 SW38
