PowerDNS
Ik wil graag een secundary dns slave opzetten alleen ik kan geen gebruik maken van mysql replication?! Heeft iemand enig idee hoe dit kan via powerdns. De master server is ook een PowerDNS bak!
Het schijnt via PowerDNS replication te kunnen alleen via google heb ik niks kunnen vinden iemand ideeen?
  • lammert
  • Laatst online: 18-09 18:58
Niets gevonden met Google :+ sure....
Uit de PowerDNS manual:
Chapter 13. Master/Slave operation & replication
PDNS offers full master and slave semantics for replicating domain information. Furthermore, PDNS can benefit from native database replication.
13.1. Native replication
Native replication is the default, unless other operation is specifically configured. Native replication basically means that PDNS will not send out DNS update notifications, nor will react to them. PDNS assumes that the backend is taking care of replication unaided.
MySQL replication has proven to be very robust and well suited, even over transatlantic connections between badly peering ISPs. Other PDNS users employ Oracle replication which also works very well.
To use native replication, configure your backend storage to do the replication and do not configure PDNS to do so.
