Brandproces mislukt
  • 144 views sinds 30-01-2008
  • GekkeCoen
  • Laatst online: 20-02-2025
Ik probeer .iso bestanden te branden op een DVDtje maar bij een Verbatim DVD-R kapt hij hem af op een brandsnelheid van 4x. Ik krijg dit logbestand:
Coen Keijzer
1C82-0000-19E5-MAAX-4006-****-****
Windows XP 6.0
AMD64
Wow64Process
WinAspi: -
ahead WinASPI: File 'C:\Program Files (x86)\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2-11-2004 12:54:32
NT-SPTI used
Nero Version: 7.5.9.0
Internal Version: 7, 5, 9, 0
Recorder: <TSSTcorp CD/DVDW SH-S183A>Version: SB03 - HA 1 TA 0 - 7.5.9.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <VS3055L TYX534D >Version: 1.0 - HA 1 TA 1 - 7.5.9.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : Keijzer iaStor Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CD/DVDW SH-S183A iaStor Port 0 ID 1 DMA: Off
CdRomPeripheral : VS3055L TYX534D 1.0 aehg6m6a Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CD/DVDW SH-S183A F: CDRom0
VS3055L TYX534D G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2045MB (2094976kB)
Free physical memory: 953MB (976348kB)
Memory in use : 53 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.8.2007
DVD-image branden
9:32:36 #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
9:32:36 #2 Text 0 File Burncd.cpp, Line 3451
Turn on Disc-At-Once, using DVD media
9:32:36 #3 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2295061 (510:00.61, 4482MB)
9:32:36 #4 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
9:32:36 #5 Text 0 File DlgWaitCD.cpp, Line 2903
Recorder: TSSTcorp CD/DVDW SH-S183A, Media type: DVD-R
Disc Manufacturer: TYG03 -
Disc Application Code: 64, Disc Physical Code: 193
9:32:36 #6 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
9:32:36 #7 Text 0 File ThreadedTransferInterface.cpp, Line 821
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1)
2 indices, index0 (150) not provided
original disc pos #0 + 2295062 (2295062) = #2295062/510:0.62
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2294912 blocks [F: TSSTcorp CD/DVDW SH-S183A]
9:32:36 #8 Text 0 File ThreadedTransferInterface.cpp, Line 1024
Prepare [F: TSSTcorp CD/DVDW SH-S183A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4700286976, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 2295062 | 2294912 | 0x00
0 | 1 | 1 | 0x41 | 2295062 | 2294912 | 0x00
2295062 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
9:32:36 #9 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
9:32:36 #10 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
9:32:36 #11 Text 0 File Burncd.cpp, Line 4278
Cache writing successful.
9:32:36 #12 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
9:32:36 #13 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 4x (5.540 kB/sec)
9:32:36 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2743
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
9:32:36 #15 Text 0 File DVDR.cpp, Line 3058
Recording mode: Sequential Recording Mode
9:32:36 #16 Text 0 File DVDR.cpp, Line 3214
Start write address at LBA 0
DVD high compatibility mode: Yes
9:32:36 #17 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
9:32:57 #18 Text 0 File Cdrdrv.cpp, Line 1292
09:32:57.087 - F: TSSTcorp CD/DVDW SH-S183A : Queue again later
9:43:37 #19 SPTI -1114 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x5C 00 00 00 00 00 00 00 0C 00 00 00
Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29
Buffer x00000000: Len xc
9:43:37 #20 SPTI -1064 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1064)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x21
Sense Qual: 0x00
CDB Data: 0x2A 00 00 01 1D 20 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 21
Buffer x00000000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:43:37 #21 CDR -1064 File Writer.cpp, Line 299
Invalid block address
9:43:37 #22 Text 0 File DVDR.cpp, Line 3434
EndDAO: Last written address was 72991
9:43:37 #23 Phase 38 File dlgbrnst.cpp, Line 1746
Burn process failed at 4x (5.540 kB/sec)
9:43:37 #24 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
9:43:41 #25 Text 0 File Cdrdrv.cpp, Line 10467
DriveLocker: UnLockVolume completed
9:43:41 #26 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Ik gebruik Nere 7 Ultra Edition maar ImgBurn werkt ook niet. Hij blijft elke keer hangen op bijvoorbeeld 4%, 8% of 11%.
Ik gebruik Windows Vista Home Premium x64 en ik heb een Samsung SH-S183A brander. Wie kan mij helpen?
Had een soortgelijk probleem (weliswaar met XP, SH-182A en Arita DVD-R), kwam zelfs niet verder dan 1%, heb nieuwe firmware voor de Samsung opgehaald en geïnstalleerd en alles werkte weer
  • GekkeCoen
Ik heb al de nieuwste firmware, geprobeerd om de firmware nogmaals te installeren maar geen resultaat. Hij blijft weer hangen bij 3%, zowel bij Nero en ImgBurn.
Kan het liggen aan Vista Home Premium 64bits?
  • hevling
  • Laatst online: 11:47
Is het wel de juiste versie van Nero dat met vista kan samenwerken?
Zorg ervoor dat je zeker de laatste versie van Nero hebt. (Tip: gebruik Nero cleanup tool maar vergeet je key niet.)
  • GekkeCoen
thomasvdw schreef op dinsdag 14 augustus 2007 @ 13:58:
Ik Nero geupdated naar de nieuwste versie maar nog steeds is het probleem niet opgelost. Dit staat in het log bestand:
Coen Keijzer
1C82-0000-19E5-MAAX-4006-9855-****
Windows XP 6.0
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder: <TSSTcorp CD/DVDW SH-S183A>Version: SB03 - HA 1 TA 0 - 7.10.1.0
CD-ROM: <VS3055L TYX534D >Version: 1.0 - HA 1 TA 2 - 7.10.1.0
CdRomPeripheral : KI2727C ZUG814T 2.0B a7ispjze Port 4 ID 0 DMA: Off
CdRomPeripheral : VS3055L TYX534D 1.0 alruxx2q Port 5 ID 0 DMA: Off
TSSTcorp CD/DVDW SH-S183A F: CdRom0
VS3055L TYX534D G: CdRom2
KI2727C ZUG814T H: CdRom1
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Free physical memory: 1001MB (1025136kB)
Memory in use : 51 %
Use Inquiry : 1
14.8.2007
DVD-image branden
15:18:10 #1 Text 0 File SCSIPTICommands.cpp, Line 424
15:18:10 #2 Text 0 File Burncd.cpp, Line 3508
15:18:10 #3 Text 0 File DlgWaitCD.cpp, Line 307
Last address to be written: 2294911 (509:58.61, 4482MB)
15:18:10 #4 Text 0 File DlgWaitCD.cpp, Line 319
15:18:10 #5 Text 0 File DlgWaitCD.cpp, Line 2972
15:18:10 #6 Text 0 File DlgWaitCD.cpp, Line 493
15:18:10 #7 Text 0 File ThreadedTransferInterface.cpp, Line 793
original disc pos #0 + 2294912 (2294912) = #2294912/509:58.62
15:18:10 #8 Text 0 File ThreadedTransferInterface.cpp, Line 995
DAO infos:
MCN: ""
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4699979776, ISRC ""
DAO layout:
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2294912 | 2294912 | 0x00
2294912 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
15:18:10 #9 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
15:18:10 #10 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
15:18:10 #11 Phase 24 File dlgbrnst.cpp, Line 1762
15:18:10 #12 Text 0 File Burncd.cpp, Line 4413
15:18:10 #13 Phase 25 File dlgbrnst.cpp, Line 1762
15:18:10 #14 Phase 36 File dlgbrnst.cpp, Line 1762
15:18:11 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2721
15:18:11 #16 Text 0 File DVDR.cpp, Line 3225
15:18:11 #17 Text 0 File DVDR.cpp, Line 3381
15:18:11 #18 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0
15:18:11 #19 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
15:18:26 #20 Text 0 File Cdrdrv.cpp, Line 1352
15:18:26.402 - F: TSSTcorp CD/DVDW SH-S183A : Queue again later
15:29:06 #21 SPTI -1114 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x29
Sense Qual: 0x00
Buffer x06d10080: Len xc
15:29:06 #22 SPTI -1064 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x21
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 83 A0 00 00 20 00 00 00
Buffer x1d280780: Len x10000
15:29:06 #23 CDR -1064 File Writer.cpp, Line 303
15:29:06 #24 Text 0 File DVDR.cpp, Line 3783
EndDAO: Last written address was 33695 (839Fh)
15:29:06 #25 Phase 38 File dlgbrnst.cpp, Line 1762
15:29:07 #26 Text 0 File SCSIPTICommands.cpp, Line 261
15:29:11 #27 Text 0 File Cdrdrv.cpp, Line 11185
15:29:11 #28 Text 0 File SCSIPTICommands.cpp, Line 424
Existing drivers:
Registry Keys:
  • Reptile209
  • Laatst online: 09:05
Reptile209
- gers -
Gaat het ook mis op 1x in plaats van 4x? Lukt het met een ander merk DVD's misschien wel? Staan er in je eventlog meldingen (onder System) rond de tijd dat het branden mislukt? Kijk eens bij de fabrikant of die wellicht een (vista) driver voor deze brander heeft: misschien ligt het aan de standaard Nero of Vista drivers.
Kijk ook eens in dit draadje: Probleem met Samsung sh-s183A voor meer tips. ;)
Is nota bene de eerste hit bij [google=TSSTcorp CD/DVDW SH-S183A Nero burning failed]...
[ Voor 33% gewijzigd door Reptile209 op 14-08-2007 18:53 ]
Zo scherp als een voetbal!
  • GekkeCoen
Reptile209 schreef op dinsdag 14 augustus 2007 @ 18:49:
De optie 1x ipv 4x kan ik niet vinden, 4x is de minimun snelheid. In me eventlog staan inderdaad foutmeldingen, deze zijn van gister. Toen had ik nog niet de nieuwste firmware geinstalleerd:
Het stuurprogramma heeft een controllerfout gevonden in \Device\CdRom0.
Dit lijkt verholpen te zijn door een firmware update.
Ik heb het net nog eens geprobeerd maar hij mislukte weer, bij 2% al.
