ERROR Met branden
  • 113 views sinds 30-01-2008
I 19:29:46 ImgBurn Version 2.3.2.0 started!
I 19:29:46 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 2)
I 19:29:46 Total Physical Memory: 1.047.776 KB - Available: 494.268 KB
I 19:29:46 Initialising SPTI...
I 19:29:46 Searching for SCSI / ATAPI devices...
I 19:29:56 Found 1 DVD-ROM and 1 DVD±RW/RAM!
I 19:31:43 Operation Started!
I 19:31:43 Source File: E:\Tweaknews\Nieuwsgroepcompleet\Zodiac_2007_nzb\ZODIAC-J4F.ISO
I 19:31:43 Source File Sectors: 2.263.152 (MODE1/2048)
I 19:31:43 Source File Size: 4.634.935.296 bytes
I 19:31:43 Source File Volume Identifier: DVD_ZODIAC
I 19:31:43 Source File Implementation Identifier: DVD Shrink
I 19:31:43 Source File File System(s): ISO9660; UDF (1.02)
I 19:31:43 Destination Device: [3:1:0] TSSTcorp CD/DVDW SH-S162L TS01 (F:) (ATA)
I 19:31:43 Destination Media Type: DVD+R (Disc ID: RICOHJPN-R03-04) (Speeds: 4x; 8x; 12x; 16x)
I 19:31:43 Destination Media Sectors: 2.295.104
I 19:31:43 Write Mode: DVD
I 19:31:43 Write Type: DAO
I 19:31:43 Write Speed: MAX
I 19:31:43 Link Size: Auto
I 19:31:43 Test Mode: No
I 19:31:43 BURN-Proof: Enabled
I 19:31:43 Filling Buffer... (40 MB)
I 19:31:44 Writing LeadIn...
I 19:32:05 Writing Image... (LBA: 0 - 2263151)
W 19:42:52 Failed to Write Sectors 2140704 - 2140735 - Write Error
W 19:42:52 Retrying (1 of 20)...
W 19:42:52 Retry Failed - Invalid Address For Write
W 19:42:52 Retrying (2 of 20)...
W 19:42:52 Retrying (3 of 20)...
W 19:42:52 Retrying (4 of 20)...
W 19:42:52 Retrying (5 of 20)...
W 19:42:52 Retrying (6 of 20)...
W 19:42:52 Retrying (7 of 20)...
W 19:42:52 Retrying (8 of 20)...
W 19:42:52 Retrying (9 of 20)...
W 19:42:52 Retrying (10 of 20)...
W 19:42:52 Retrying (11 of 20)...
W 19:42:52 Retrying (12 of 20)...
W 19:42:52 Retrying (13 of 20)...
W 19:42:52 Retrying (14 of 20)...
W 19:42:52 Retrying (15 of 20)...
W 19:42:52 Retrying (16 of 20)...
W 19:42:52 Retrying (17 of 20)...
W 19:42:52 Retrying (18 of 20)...
W 19:42:52 Retrying (19 of 20)...
W 19:42:52 Retrying (20 of 20)...
E 19:43:56 Failed to Write Sectors 2140704 - 2140735 - Write Error
I 19:43:56 Synchronising Cache...
I 19:43:57 Closing Track...
I 19:44:00 Finalising Disc...
Iemand een idee hoe je dit op kunt lossen ?
  • Michael Knight
  • Laatst online: 11-10 22:46
Michael Knight
Moderator Consumentenelektronica
KITT, I need you buddy!
Wat heb je zelf al gedaan om dit op te lossen?
Slechte image?
Slechte disc?
(Zeldzame) retrogames en meer --> Aangeboden op V&A
Ik heb het met 3 ander img ook geprobeerd. Werkt ook niet onder tussen 10 dvd verfikt. Deden het eerst altijd goed. En zo in eenkeer kreeg ik dat bericht.
  • Michael Knight
Michael Knight
Toevallig een nieuwe batch DVD`s?
Probeer ook even met een DVD-RW :)
Misschien is je lens vuil... maak je brander open als je zeker weet dat het nergens anders aan kan liggen...
  • N0MAD
  • Laatst online: 15-07-2024
dubbelpost ERROR Met branden Failed to Write Sectors Write Error
Het is blijkbaar een dringend probleem.
  • Saturnus
Lagere (laagste eventueel) snelheid branden?
  • Sprite_tm
  • Laatst online: 09:19
Sprite_tm
Semi-Chinees
Dubbel en zoiets hoort daar niet. Verder is je topicstart ver onder de maat; we zijn hier geen helpdesk.
Relaxen und watchen das blinkenlichten. | Laatste project: Ikea Frekvens oog
