[CASE] Antec Performance One Series
  • 258 views sinds 30-01-2008
  • MikeVM
  • Laatst online: 15-08 15:25
MikeVM
- Baloo -
Afbeeldingslocatie: http://www.electronicsdistributing.com/ANTEC-BigLogo.gif
The Performance One series of cases are functional, efficient and silent. The pinnacle of performance and style, these cases feature the latest in Quiet Computing™ and innovative features for the ultimate experience.
Afbeeldingslocatie: http://www.antec.com/images/160/P180.jpg P180
Colour: Silver
Price: € 115
Voeding : None
Afbeeldingslocatie: http://www.antec.com/images/160/p180b_q.jpg
P180B
Colour: Black
Price: € 120
Voeding : None
Afbeeldingslocatie: http://www.antec.com/images/160/p182_q.jpg
P182
Colour : Gun Metal Black
Price: € 125
Voeding : None
Afbeeldingslocatie: http://www.antec.com/images/160/P182SEfinal.jpg
P182SE
Colour: Chrome
Price: € 170
Voeding : None
Afbeeldingslocatie: http://www.antec.com/images/160/P190_q.jpg
P190
Colour: Black
Price: € 330
Voeding : Neo-Link 1200 Watt
Antec : P180/P180B
Afbeeldingslocatie: http://www.antec.com/images/160/P180.jpgAfbeeldingslocatie: http://www.antec.com/images/160/p180b_q.jpg
Vorig Topic: [CASE] Antec Performance One P180
Antec : P182
Attractive gun metal black finish
Dual chambers structure: The power supply (not included) is located in the lower chamber to isolate heat from the system and lower system noise
Special three-layer side panels and front door (aluminum, plastic, aluminum) dampen system generated noise, making this one of the quietest cases available
0.8mm cold rolled steel for durability used through the majority of the chassis, 1.0mm cold rolled steel around the 4x HDD area
Features:
  • Cable organizers behind motherboard tray minimize cable clutter
  • Double hinge door designed to open up to 270º
  • Rubber grommeted ports on the rear for liquid-cooling tubes allow you to mount external liquid-cooling hardware
Drive Bays & Expanson Slots:
  • External 4 x 5.25”; 1 x 3.5”
  • Internal 6 x 3.5” for HDD
    • Bottom 4 x 3.5” for HDD
    • Mid 2 x 3.5” for HDD
  • 7 Expansion Slots
Cooling System:
  • 1 rear 120mm TriCool™ Fan (standard)
  • 1 top 120mm TriCool™ fan (standard)
  • 1 lower chamber 120mm TriCool™ Fan (standard)
  • 1 front 120mm fan (optional)
  • 1 middle 120mm fan (optional) to cool the VGA
  • External fan control on the rear panel for the top and rear fans in the upper chamber
Motherboard: Up to Standard ATX (12” x 9.6”)
Front-mounted ports:
  • 2 x USB 2.0
  • 1x IEEE 1394 (FireWire®, i.Link®
  • Audio In/Out (HDA & AC’97)
Case Dimensions:
  • 21.3”(H) x 8.1”(W) x 19.9”(D)
  • 52cm (H) x 21cm (W) x 51cm (D)
Reviews:
Antec Video Review
Antec Flash Review
Viperlair.com
The Tech Lounge
Images:
FrontAfbeeldingslocatie: http://www.antec.com/images/400/p182_q.jpg
SideAfbeeldingslocatie: http://www.antec.com/images/400/p182_q_op.jpg
BackAfbeeldingslocatie: http://www.antec.com/images/400/backside/p182_b.jpg
Weetjes:
Voeding:
  • lees dit topic eerst: Welke voeding heb ik nodig? Deel 17
  • koop een voeding met kabels die lang genoeg zijn
  • kies een stille voeding (waarom zou je een stofzuiger van zo een stille kast maken)
CPU cooler:
hier komt een lijstje van alle Cpu Coolers die in deze kast passen
!!! controleer altijd of je Moederbord de Cpucooler toelaat
  • Zalman CNPS9700 LED
  • Tuniq Tower
  • Scyte Infinity
Videokaart
ook hierover hoef je je niet veel zorgen te maken, zelfs de grote 8800 van nvidia passen in deze kast
(indien nodig moet je de middenste HDDcage verwijderen)
(hierdoor verlies je 2HD plaatsen of 1 Fan plaats)
Drive Bays:
als je een fan controller wilt installeren moet je letten op de lengte van de knopjes
je hebt ongeveer 21mm tussen het deurtje en de drivebays
**More cases to come
[ Voor 11% gewijzigd door MikeVM op 06-08-2007 15:18 ]
\\ Baloo \\ Mijn iRacing profiel
  • Thandor
  • Laatst online: 10:08
Thandor
SilverStreak
Enkel wat specificaties van een kast in een topic gooien zal niet veel nut hebben. Informatie over de kast kun je beter kwijt door een Productreview te schrijven :).
