Duel Core optimiser ?
  • 59 views sinds 30-01-2008
hey
ik heb net Vista geinstalleert, effe opnieuw Duel Core optimiser er opgezet voor m'n X2 4200
word geinstalleert in map : ProgramFiles>AMD>DuelCoreOptimiser
zie deze 3 bestanden:
http://img126.imagevenue....e=96473_AMD_123_674lo.jpg
click op de .EXE
ik zie m'n muis heel even in een zandlopertje(of in vista zo'n raal rondje) en muis is weer normaal
nu staat in de ReadMe(word hier onder gepost) dat er in m'n system tray een AMD logo moet staan, maar die zie ik dus niet :o
weet iemand wat ik moet doen om de optimiser goed aan het werk te krijgen ?
bedankt
W
Download Locatie:
http://www.amd.com/us-en/...,30_182_871_14098,00.html
ReadMe:
November 9, 2006
---General Description---
AMD Dual-Core Optimizer utility synchronizes Time Stamp Counter (TSC) MSRs on AMD Dual-Core Processors.
---Improvement and Fixes---
Version 1.1.1
* AMD Dual-Core Optimizer’s driver has been WHQL tested and signed by Microsoft Corporation.
Version 1.1.0
* 4x4 “Gaming Mode” added.
Version 1.0.0
* This is the initial release.
---Usage Notes---
* Run setup.exe for a full uninstall/install.
* On 4x4 Systems, right click on the AMD logo system tray icon and select “Gaming Mode” in order to turn “Gaming Mode” on/off.
---Known Issues---
* Using AMD Dual-Core Optimizer while running on ATI Radeon Xpress on-board graphics will cause system to lock up while running HCT stress test. The problem has been identified as an ATI graphics driver issue, and an updated version of the ATI graphics driver will be available sometime in the future to remedy this problem.
* Reports of Blue Screen crash when used with MS Hotfix from KB Article 896256.
* Going into “Gaming Mode” in Windows Vista will create a “cmd” window briefly.
---System Requirements---
* Microprocessor: AMD Athlon™ 64 X2 Dual-Core Processors
This software installs and operates under the following operating systems
* Microsoft® Windows® XP
* Microsoft Windows XP Professional x64 Edition
* Microsoft Windows Server 2003 32-bit
* Microsoft Windows Server 2003 64-bit
* Microsoft Windows Vista Beta 2
Operating systems NOT supported are:
* Microsoft® Windows® NT 4.0
* Microsoft Windows 98 Gold
* Microsoft Windows 95 OSR2
* Microsoft Windows 3.x
weet niemand het ?
  • McKaamos
McKaamos
Master of the Edit-button
Er staat "on 4x4 systems".
4x4 is quadcore ;)
Voor zover ik weet hebben Dualcore systemen die gamingmode optie niet en krijgen dus ook geen tray icon.
En by the way, kicken binnen 24 uur is niet toegestaan hier ;)
[ Voor 17% gewijzigd door McKaamos op 01-08-2007 22:17 ]
  • 430xlkod
  • Laatst online: 05-07-2025
Deze moet je gewoon 1 maal instaleren en dan niks doen, hij wordt namelijk op de achtergrond gedraaid ;). Geen zorgen maken dus, en gaan met die banaan.
@ hierboven, dat programma werkt op elke CPU met 2 of meer cores.
En AMD heeft tot nu toe alleen maar dual-cores dus lijkt me sterk wat jij daar zegt ;).
EDIT:
Kicken binnen een half urr ! :o :o :o
[ Voor 7% gewijzigd door 430xlkod op 01-08-2007 22:44 ]
beetje offtopic:
is er ook zoiets voor intel??? :D
  • skelleniels
  • Laatst online: 10-10 23:53
Verwijderd schreef op woensdag 01 augustus 2007 @ 22:45:
beetje offtopic:
Waarom zou je zoiets willen voor intel? Core 2 duo werkt perfect in games.b
http://specs.tweak.to/16567
  • mad_max234
  • Laatst online: 06-12-2025
mad_max234
AMD Athlon II M320
McKaamos schreef op woensdag 01 augustus 2007 @ 22:16:
4x4 is quadcore ;)
4X4 is FX quad-father systeem , en geen quad core. (in ieder geval nu nog niet, met de k10 wel :) )
  • Abbadon
  • Laatst online: 13-10 11:36
Binnen een half uur kicken met 'Weet niemand het?' is echt zó vreselijk fout hier :X
Je zult ook geen system tray icon zien omdat je daar maar één ding mee kunt doen en dat is gaming mode aan of uit zetten op een 4x4 (dus een systeem met twee AMD dualcore FX cpu's).
