problem ..
  • 113 views sinds 30-01-2008
#--- Team Information --------------------------------------------------------
Team = "Nijmegen Eendracht Cowbinatie"
TeamHome = "www.nec-nijmegen.nl/"
TeamID = 263
# Use team logo? Specify full URL to *.gif or *.jpg image.
LogoURL="http://www.nec-nijmegen.nl/website/images/new/NEC_small.gif"
#UseLogo = 1 # Do not use team logo.
UseLogo = 1 # Use team logo. Must specify full URL in LogoURL.
#--- Input Options -----------------------------------------------------------
# Logfile name format information. This script does not correctly support
# formats other than YYYYMMDD. The logs in this example are kept in a
# subdirector called "logrc5", which can be configured in the proxy's ini.
# This script does require that daily logfile rotation is enabled. Other
# rotation time periods are not yet supported. LogDir should end in a "/".
LogDir = "c:/proxyfiles/ "
LogPre = "/pproxyrc520010207-22" # For rc5pkeyYYYYMMDD
LogSuf = "log" # For rc5pkeyYYYYMMDD.log
# The personal proxy can read compressed log files after they have been
# rotated. If you have this proxy option enabled and want to use ppstats,
# configure the following settings. The defaults are for UNIX gzip. Command
# that unzips the logfile to stdout without deleting the file is required.
#ProcessZipLogs = 0 # Ignore zipped log files.
ProcessZipLogs = 1 # Unzip and process all log files.
LogZipSuf = "log.gz" # For rc5pkeyYYYYMMDD.log.gz
LogTmpSuf = "log.tmp" # For rc5pkeyYYYYMMDD.log.tmp
LogDecompressor = "gzip -d -c" # Command line zip decompressor.
# Maximum number of days to read log files. A value of zero means
# read all available log files without limit. A value of 365 would mean
# only read back blocks done in the last year and ignore anything older.
MaxDays =175
#--- Output Options ----------------------------------------------------------
# Full path to output file location. This should end in a "/".
HtmlDir = "/inetpub/wwwroot/rc5/stats/"
# Full URL of output web file location. This should end in a "/".
HtmlRoot = "212.187.29.199/inetpub/wwwroot/rc5/stats"
# Realitive path to icon folder from htmldir and htmlroot. Default should work
# fine for most cases. This should end in a "/". If you haven't copied
# this folder from the zip distribution to your htmldir now is a good time.
IconDir = "icons/"
# HTML output filenames. You should configure IIS to use index.html as a
# default document, or rename the index.html's to default.htm
htmlteam = "index.html"
htmlexec = "exec.html"
htmlmail = "byemail.html"
htmlhost = "byhost.html"
htmlos = "byos.html"
htmlcpu = "bycpu.html"
htmlver = "byver.html"
htmlfull = "byfull.html"
htmldomain = "bydomain.html"
htmlhour = "byhour.html"
htmldate = "bydate.html"
htmlweek = "byweek.html"
htmlmonth = "bymonth.html"
htmlyear = "byyear.html"
htmldayofweek = "bydaywk.html"
htmlindvemail = "index.html"
htmlemailhist = "emailhist.html"
htmlhostsbyemail = "emailhosts.html"
htmlindvhost = "index.html"
htmlhosthist = "hosthist.html"
htmlemailsbyhost = "hostemails.html"
# Cascading style sheet filename. Will be created by ppstats for you.
css = "ppstats.css"
# All ip addresses from the proxy log files are converted to DNS names and
# then cached for a user defined amount of time. A value of zero means refresh
# on every run. This cache file is saved in your workingdir. If you run
# ppstats on a server with a slow internet connection, use a large cachedays.
CacheFile = "rc5-dns.cache" # DNS cache filename to be created.
CacheDays = 30 # Days to store cache before refreshing.
# GIF based chart options. Be sure to specify the full or relative path to the
# specially compiled GNUplot program with GIF support. Config and data files
# are create by ppstats for you.
GNUPlot = "\gnu\gp371w32\pgnuplot.exe" # Path to GNUplot executable.
GNUPlotconfig = "gnuplot.ini" # GNUplot config file.
GNUPlotdata = "plot.data" # GNUplot data file.
GNUPlotoutput = "plot.gif" # Output GIF filename.
# The page counter component. See the documentation section above for details
# on how to obtain and use the Count.cgi program. To change the color of the
# displayed count number, change the prgb parameter. Note that you may have to
# do a 'echo "1" > rc5.dat' in your Counter/data folder for this to work. You
# can specify a different hit counter program by changing the counter variable.
#UseCounter = 0 # Do not use the hit counter.
UseCounter = 1 # Use the hit counter.
Counter = "/cgi-bin/Count.cgi?ft=0|tr=1|trgb=000000|srgb=00FF00|prgb=993333|md=8|dd=D|comma=T|df=rc5.dat"
# The By Host information page is sometimes not particularly practical for
# very large teams. You can display this section and ppstats will not record
# blocks submitted by host in any manner. The combined output file size and
# execution time will decrease substantially.
#ShowByHost = 0 # Do not show the By Host section.
ShowByHost = 1 # Show the By Host section.
#--- Format Options ----------------------------------------------------------
# GIF based chart line style option. The default width is 520 and the
# default height is 400. 800 by 600 is nice for people with large monitors.
# Any value of 1 or less will disable the nth-day average feature.
#ChartLineStyle = 1 # Impulses style. Not useful with nth day average.
ChartLineStyle = 2 # Lines style.
#ChartLineStyle = 3 # Linespoints style.
ChartWidth = 520 # GIF image width.
ChartHeight = 400 # GIF image height.
DayAverage = 21 # Days of nth-day average.
# Days to track up/down movement.
MovementDays = 1# Maximum number of rows to show per category page.
MaxRows = 100
# Number of days to display on the history pages.
DaysHist = 6
# Number of days to display for individual block history.
BlockHistory = 21
# Use header and/or footer banners?
UseHeaderBanner = 0 # Do not use header banner.
#UseHeaderBanner = 1 # Use header banner.
#UseFooterBanner = 0 # Do not use footer banner.
UseFooterBanner = 1 # Use footer banner.
# Consolidate numbers in hosts? ie, host12.myisp.com -> host?.isp.com
# See rc5-domain.cons for a list of domains you wish to manual consolidate.
# See rc5-ip.cons for a list of ip addresses you wish to manual consolidate.
# For instance, an entry in rc5-domain.cons like slashdot.org will consolidate
# the hosts [url="http://www.slashdot.org,"]www.slashdot.org,[/url] ftp.slashdot.org, and slashdot.org into
# ?.slashdot.org Some more examples are provided. Entries in rc5-domain.cons
# and rc5-ip.cons are processed regardless whether or not ConsHosts is
# enabled. Note that rc5-domain.cons works from the right, rc5-ip.cons the
# left. Note that the last entry in each array does not have a comma after it.
#ConsHosts = 0 # Do not consolidate hosts.
ConsHosts = 0 # Consolidate hosts.
# Last Seen column on the By Hosts page options. Times are defined in
# seconds. Colors are in RGB format, do not append a pound sign "#" to
# the front of the color string. Warning times should be less than
# Critical times. See default settings for examples on how to set these.
#ColorLastSeen = 0 # Do not color last seen.
ColorLastSeen = 1 # Color last seen column.
LastSeenWarningTime = 86400 # 24*60*60 default 24 hours warning time.
LastSeenCriticalTime = 604800 # 7*24*60*60 default 7 days critical time.
LastSeenWarningColor = "888800" # Dark yellow.
LastSeenCriticalColor = "BB0000" # Bright red.
# Category displacement colors for moving up or down in rank since
# yesterday. Defaults are green for up, red for down.
MoveUpColor = "009900" # Green
MoveDownColor = "990000" # Red
# Insert META REFRESH tag in html files? Refresh period in seconds.
#UseMetaRefresh = 0 # Do not use META REFRESH tag.
UseMetaRefresh = 1 # Use META REFRESH tag.
MetaRefreshPeriod = 900 # Refresh after this number of seconds.
#--- Color Configuration -----------------------------------------------------
# Color configuration settings. Several examples have been provided.
# Simply uncomment the section you want to use or modify, and comment
# out the rest. Do not append a pound sign "#" to the front. Must
# be in RRGGBB format.
# Original Distributed.Net theme, as far as I remember.
#backgroundcolor = "000000" # black
#linkbarcolor = "1144AA" # blue
#linkbartitlefontcolor = "FFFFFF" # white
#sectiontitlebarcolor = "AAAAAA" # light gray
#sectiontitlefontcolor = "000077" # dark blue
#sectionlowlightcolor = "000000" # black
#sectionhighlightcolor = "808080" # gray
#sectionnotefontcolor = "FF0000" # red
#historycolor = "A0A0A0" # light gray
#avehistorycolor = "1144CC" # blue
#ndayhistorycolor = "6688FF" # light blue
#textcolor = "FFCC66" # gold
#linkcolor = "BBBBBB" # light gray
#visitedlinkcolor = "BBBBBB" # light gray
#activelinkcolor = "BBBBBB" # light gray
#fontstyle = "Arial, Verdana, Helvetica"
# Current Distributed.Net theme, more or less.
backgroundcolor = "FFFFFF" # white
linkbarcolor = "EEEEEE" # light gray
linkbartitlefontcolor = "000000" # black
sectiontitlebarcolor = "770000" # dark red
sectiontitlefontcolor = "FFFFFF" # white
sectionlowlightcolor = "EEEEEE" # light gray
sectionhighlightcolor = "FFFFEE" # light yellow
sectionnotefontcolor = "000000" # black
historycolor = "770000" # dark red
avehistorycolor = "333399" # blue
ndayhistorycolor = "3333FF" # light blue
textcolor = "000000" # black
linkcolor = "993333" # red
visitedlinkcolor = "333399" # blue
activelinkcolor = "999999" # gray
# GNOME theme (by Kevin Pesce kpesce@netscape.net)
#backgroundcolor = "EEEEE0" # light gray
#linkbarcolor = "CCCCC0" # light gray
#linkbartitlefontcolor = "330000" # dark red
#sectiontitlebarcolor = "BBBBB0" # light gray
#sectiontitlefontcolor = "552222" # dark red
#sectionlowlightcolor = "EEEEE0" # light gray
#sectionhighlightcolor = "DDDDD0" # light gray
#sectionnotefontcolor = "330000" # dark red
#historycolor = "888880" # gray
#avehistorycolor = "666660" # gray
#ndayhistorycolor = "333330" # dark gray
#textcolor = "330000" # dark red
#linkcolor = "770000" # red
#visitedlinkcolor = "600000" # dark red
#activelinkcolor = "600000" # dark red
# Slashdot.org theme (by Kevin Pesce kpesce@netscape.net)
#backgroundcolor = "FFFFFF" # white
#linkbarcolor = "CCCCCC" # light gray
#linkbartitlefontcolor = "003333" # dark green
#sectiontitlebarcolor = "006666" # dark green
#sectiontitlefontcolor = "FFFFFF" # white
#sectionlowlightcolor = "CCCCCC" # light gray
#sectionhighlightcolor = "EEEEEE" # light gray
#sectionnotefontcolor = "333333" # dark gray
#historycolor = "225555" # dark green
#avehistorycolor = "005522" # green
#ndayhistorycolor = "006600" # light green
#textcolor = "333333" # dark gray
#linkcolor = "006666" # green
#visitedlinkcolor = "003333" # dark green
#activelinkcolor = "003333" # dark green
# Themes.org theme (by Kevin Pesce kpesce@netscape.net)
#linkbarcolor = "000000" # black
#linkbartitlefontcolor = "F6DB91" # light brown
#sectiontitlebarcolor = "000000" # black
#sectiontitlefontcolor = "F6DB91" # light brown
#sectionhighlightcolor = "303030" # dark gray
#sectionnotefontcolor = "9EFFA6" # lime green
#historycolor = "A7A7A7" # light gray
#avehistorycolor = "9EFFA6" # lime green
#ndayhistorycolor = "F6DB91" # light brown
#textcolor = "FFFFFF" # white
#linkcolor = "C4A9CE" # purple
#visitedlinkcolor = "C4A9CE" # pruple
#activelinkcolor = "FFFFFF" # white
# Linux.org theme (by Kevin Pesce kpesce@netscape.net)
#backgroundcolor = "E8E8FF" # light purple
#linkbarcolor = "C02C72" # pink
#linkbartitlefontcolor = "C02C72" # pink
#sectiontitlebarcolor = "7237C0" # purple
#sectionlowlightcolor = "EBE8FF" # light purple
#sectionhighlightcolor = "EBE8FF" # light purple
#sectionnotefontcolor = "000000" # black
#historycolor = "C02C72" # pink
#avehistorycolor = "000088" # blue
#ndayhistorycolor = "0000AA" # blue
#textcolor = "000000" # black
#linkcolor = "0000AA" # blue
#visitedlinkcolor = "0000AA" # blue
#activelinkcolor = "0000AA" # blue
# Team AnandTech colors (by Mika Anderson mika.anderson@home.com)
#linkbarcolor = "E6DAC1" # light brown
#linkbartitlefontcolor = "004828" # hunter green
#sectiontitlebarcolor = "004828" # hunter green
#sectiontitlefontcolor = "E0D4BF" # light brown
#sectionlowlightcolor = "E0E0E0" # light grey
#sectionhighlightcolor = "F0F0F0" # light grey
#historycolor = "004828" # brown
#avehistorycolor = "660000" # dark red
#ndayhistorycolor = "660000" # dark red
#linkcolor = "229900" # green
#visitedlinkcolor = "660000" # dark red
[KeyServer]
ipaddress=us.v27.distributed.net
port=2064
connectperiod=600
connectivity=normal
;bindip= ; IP to talk out to keyserver from
;uuehttpmode=0
; 0=normal,1=uue,2=http,3=http+uue
; 4=socks4,5=socks5,6=genproxy,7=genproxy+uue
;httpproxy=wwwproxy.corporation.com
;httpport=8080
;httpid=
[ports]
;listenaddress= 212.187.29.199 ; IP to accept clients on
port=2064
;port2=23 ; must be root for ports < 1000
;port3=80
testport=3064
timeout=30
[console]
logfileconsole=cons.log
logfileconsolerotation=hourly
consoleverbosity="general stats keyblock server client buffers timestamp attention errlow errsevere"
timestampflags=130
[rc564]
expertmode=1
logfilekeyblock=pproxyrc5
logfilekeyblockrotation=daily
minkeysready=3000
maxkeysready=6000
minkeysdone=100000
maxkeysdone=200000
[desII]
logfilekeyblock=pproxydes
minkeysready=10
maxkeysready=20
maxkeysdone=5
contestclosed=1
[ogr]
logfilekeyblock=pproxyogr
logfilekeyblockrotation=hourly
minkeysready=200
maxkeysready=250
maxkeysdone=50000
[csc]
logfilekeyblock=pproxycsc
minkeysready=10
maxkeysready=20
maxkeysdone=3
contestclosed=1
[misc]
proxymessage="Nijmegen Eendracht Cowbinatie says mooooooooooooooooh!"
pidfile=rc5desproxy.pid
statusperiod=60
periodicperiod=120
;logfilecompressor=logcompressor.sh
[ignoredip]
[allowedip]
  • DSmarty
Er wordt gevraagd om een path, niet een executable zelf!
  • DSmarty
de / weglaten!
  • DSmarty
Misschien helpt het als je hier een "absoluut" pad van maakt.
  • Dutchman!
  • Laatst online: 22:30
# rotation time periods are not yet supported --> rotation op daily dus. LogDir should end in a "/".
LogPre = "pproxyrc5"
LogSuf = "log"
We spend our years as a tale that is told
  • Dutchman!
HtmlRoot = "212.187.29.199/rc5/stats/"
  • crisp
crisp
Devver
Pixelated
Ook voor je GNUplot een absoluut pad aangeven (idd wel met \ ipv / onder windows)
Intentionally left blank
  • pinball
pinball
Electric Monk
Op vrijdag 09 februari 2001 00:32 schreef DSmarty het volgende:
de / weglaten!
20010207-22 ook weglaten! de datum zet proxyper er zelf bij.
[edit]
* pinball moet deze post ook weglaten! & voortaan Dutchman's posts beter lezen :)
Whenever you find that you are on the side of the majority, it is time to reform.
