Ik zit er aan te denken om dit moederbord te nemen, gunstig geprijst en het verhaal van ddr & ddrII / AGP & PCIe slots spreekt me erg aan.. en de rest van de specs zijn niet onaardig imo
CPU
- LGA 775 for Intel Core 2 Extreme / Core 2 Duo / Pentium XE / Pentium D / Pentium 4 / Celeron D, supporting Quad Core
Kentsfield processors
- FSB 1066/800/533 MHz
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
Chipset
- Northbridge: VIA PT880 Ultra
- Southbridge: VIA VT8237A
Memory
- Dual Channel DDR/DDRII memory technology
- 2 x DDRII DIMM slots
- Supports DDRII667/533
- Max. capacity: 2GB
- 2 x DDR DIMM slots
- Supports DDR400/333/266
BIOS
- 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
Audio
- 7.1 CH Windows Vista Premium Level HD Audio (ALC888 Audio Codec)
LAN
- VIA PHY VT6103
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN
Slots
- 4 x PCI slots
- 1 x PCI Express Graphics slot
- 1 x AGP 8X slot
Connector
- 2 x Serial ATA 1.5 Gb/s connectors, support RAID (RAID 0, RAID 1, and JBOD) and Hot Plug functions
- 2 x ATA133 IDE connectors (support 4 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- 1 x HDMI_SPDIF header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O
HD 8CH I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Serial Port: COM1
- 1 x Parallel Port (ECP/EPP Support)
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x RJ-45 LAN Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Hybrid Booster
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Support CD
- Drivers, Utilities, AntiVirus Software (Trial Version)
Accessories
- Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 100 cables
- 1 x SATA data cable (optional)
- 1 x SATA 1 to 1 power cables (optional)
- 1 x HDMI_SPDIF cable (optional)
Hardware Monitor
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Form Factor
- ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
Heeft er iemand ervaring met dit bord?
En ik wilde eigenlijk weten welke borden er nog meer een beetje aan te raden zijn waar je dus ddr/ddrII & PCIe & AGP slots hebt.. beetje netjes in de prijs enzo
CPU
Chipset
Memory
BIOS
- 4Mb AMI BIOS
- AMI Legal BIOS
Audio
LAN
- VIA PHY VT6103
Slots
- 4 x PCI slots
- 1 x AGP 8X slot
Connector
- 1 x IR header
- 1 x Game header
- CD in header
Rear Panel I/O
HD 8CH I/O
Hybrid Booster
- ASRock U-COP
Support CD
Accessories
Hardware Monitor
- CPU Quiet Fan
Form Factor
