norton save en restore lijkt mij wel wat, maar mag je dat op meerdere computers draaien of moet je de software vaker aanschaffen. Het moet wel legaal zijn geen opmerkingen van kan wel maar niet legaal.
Rechtstreeks uit de: End User License Agreement.
You may:
A. use one copy of the Software on a single computer. If a greater number of copies and/or number of
computers is specified within the Documentation or the applicable transaction documentation from the
authorized distributor or reseller from which You obtained the Software, You may use the Software in
accordance with such specifications;
B. make one copy of the Software for back-up or archival purposes, or copy the Software onto the hard
disk of Your computer and retain the original for back-up or archival purposes;
C. use the Software on a network, provided that You have a licensed copy of the Software for each
computer that can access the Software over that network;
D. permanently transfer all of Your rights in the Software granted under this License Agreement to
another person or entity, provided that You retain no copies of the Software and the transferee agrees to
the terms of this License Agreement. Partial transfer of Your rights under this License Agreement shall
not be permitted. For example, if the applicable documentation grants You the right to use multiple
copies of the Software, only a transfer of the rights to use all such copies of the Software would be valid;
and
E. use the Software in accordance with any additional permitted uses which may be set forth below.
You may not, nor may you permit any other person to:
A. sublicense, rent or lease any portion of the Software;
B. reverse engineer, decompile, disassemble, modify, translate, make any attempt to discover the source
code of the Software or create derivative works from the Software;
C. use the Software as part of a facility management, timesharing, service provider or service bureau
arrangement; or
D. use the Software in any manner that is not permitted pursuant to this License Agreement.
You may:
and
arrangement; or
[ Voor 9% gewijzigd door Verwijderd op 02-07-2007 02:39 ]
