F@H smp client problemen deel II
  • 174 views sinds 30-01-2008
als mijn client klaar is met een wuh dan krijg ik deze errors:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
[19:18:06] Writing local files
[19:18:06] Completed 495000 out of 500000 steps  (99 percent)
[19:31:50] Writing local files
[19:31:50] Completed 500000 out of 500000 steps  (100 percent)
[19:31:50] Writing final coordinates.
[19:31:51] Past main M.D. loop
[19:31:52] Will end MPI now
[19:32:52]
[19:32:52] Finished Work Unit:
[19:32:52] - Reading up to 6048840 from "work/wudata_05.arc": Read 6048840
[19:32:52] - Reading up to 20616920 from "work/wudata_05.xtc": Read 20616920
[19:32:52] goefile size: 0
[19:32:52] logfile size: 346943
[19:32:52] Leaving Run
[19:32:53] - Writing 27114443 bytes of core data to disk...
[19:32:54]   ... Done.
[19:32:54] - Failed to delete work/wudata_05.sas
[19:32:54] - Failed to delete work/wudata_05.goe
[19:32:54] Warning:  check for stray files
[19:32:54] - Shutting down core
[19:34:54]
[19:34:54] Folding@home Core Shutdown: FINISHED_UNIT
[19:34:54]
[19:35:00] CoreStatus = 64 (100)
[19:35:00] Sending work to server
[19:35:00] + Attempting to send results
[19:37:06] + Results successfully sent
[19:37:06] Thank you for your contribution to Folding@Home.
[19:37:06] + Number of Units Completed: 4
[19:39:13] - Preparing to get new work unit...
[19:39:13] + Attempting to get work packet
[19:39:13] - Connecting to assignment server
[19:39:13] - Successful: assigned to (171.64.65.64).
[19:39:13] + News From Folding@Home: Welcome to Folding@Home
[19:39:14] Loaded queue successfully.
[19:39:57] + Closed connections
[19:39:57]
[19:39:57] + Processing work unit
[19:39:57] Core required: FahCore_a1.exe
[19:39:57] Core found.
[19:39:57] Working on Unit 06 [June 28 19:39:57]
[19:39:57] + Working ...
daarna flushed hij het resultaat wel weg maar doet dan niets meer. start dus niet opnieuw op om weer aan een nieuwe wuh te beginnen. na een 10 a 15 ga ik hem dan handmatig heropstarten, zo'n 20 x , en dan draait hij wel weer en ook gewoon heel stabiel.
heb de smp client 2 x draaien op mijn quadcore en heb het op alle 2 de cores. heb er al keertje 1 uitgezet om te kijken of dat het probleem was.
Ding wil gewoon niet doorstarten :(
hij gaat dus gewoon niet verder na * Working ..... load blijft ook op nul staan :(
[ Voor 55% gewijzigd door Verwijderd op 28-06-2007 21:42 ]
updateje
ding dus weer gestopt en na herstart doet hij het nu wel . snap er geen reet van :(
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [June 28 19:46:25]
# SMP Client ##################################################################
                       Folding@Home Client Version 5.91beta
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home Windows SMP Client V1.01
Executable: C:\Program Files\Folding@Home Windows SMP Client V1.01\fah.exe
[19:46:25] - Ask before connecting: No
[19:46:25] - User name: www.onweer-online.nl0Henk (Team 92)
[19:46:25] - User ID: 5E6FDE3852D39614
[19:46:25] - Machine ID: 1
[19:46:25]
[19:46:25] Loaded queue successfully.
[19:46:25]
[19:46:25] + Processing work unit
[19:46:25] Core required: FahCore_a1.exe
[19:46:25] Core found.
[19:46:25] Working on Unit 06 [June 28 19:46:25]
[19:46:25] + Working ...
[19:46:25]
[19:46:25] *------------------------------*
[19:46:25] Folding@Home Gromacs SMP Core
[19:46:25] Version 1.74 (March 10, 2007)
[19:46:25]
[19:46:25] Preparing to commence simulation
[19:46:25] - Ensuring status. Please wait.
[19:46:30] - Starting from initial work packet
[19:46:30]
[19:46:30] Project: 2610 (Run 0, Clone 915, Gen 17)
[19:46:30]
[19:46:32] Assembly optimizations on if available.
[19:46:32] Entering M.D.
[19:46:53] al work packet
[19:46:53]
[19:46:53] Project: 2610 (Run 0, Clone 915, Gen 17)
[19:46:53]
[19:46:57] 10 (Run 0, Clone 915, Gen 17)
[19:46:57]
[19:46:57] Entering M.D.
[19:47:03] Rejecting checkpoint
[19:47:04] ing local files
[19:47:05]
[19:47:05] Writing local files
[19:47:06] Extra SSE boost OK.
[19:47:06] Writing local files
[19:47:06] Completed 0 out of 500000 steps  (0 percent)
maar mijn plezier in deze smp client gaat er zo wel rap af :(
  • Cow_tipping
  • Laatst online: 16-09 11:39
Cow_tipping
On the run for D.B.!
Had ik ook. Met dichtgeknepen billen elke keer als ik de computer moest herstarten en erbij blijven als de unit bijna klaar was om hem na versturen opnieuw op te starten.
“The first principle is that you must not fool yourself, and you are the easiest person to fool.“
