Configuratie PIX 501
  • 142 views sinds 30-01-2008
Ik heb de volgende configuratie gemaakt naar aanleiding van de example die Cisco geeft op haar eigen website.
pix# sh running
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxx encrypted
passwd xxxxx encrypted
hostname pix
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 101 permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside xxx.xxx.xxx.50 255.255.255.248
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool pptp-pool 10.1.1.1-10.1.1.50
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.49 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-pptp
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
vpdn group 1 accept dialin pptp
vpdn group 1 ppp authentication pap
vpdn group 1 ppp authentication chap
vpdn group 1 ppp authentication mschap
vpdn group 1 client configuration address local pptp-pool
vpdn group 1 pptp echo 60
vpdn group 1 client authentication local
vpdn username xxxxxx password *********
vpdn enable outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxxxx
: end
De clients achter de pix krijgen een dhcp adres uit het 192.168.1.0/24 netwerk en de clients buiten het netwerk die een vpn connectie maken krijgen een adres uit de pool 10.1.1.1-50. De accesslist zorgt ervoor dat ip verkeer mogelijk is van 10.1.1.0/24 naar 192.168.1.0/24.
Echter ik mis iets. Het is gelukt om van buiten het netwerk een vpn connectie te maken naar de pix. Ik krijg netjes een 10.1.1.1 adres. Hoe moet ik echter de clients benaderen die in het 192.168.1.0/24 adres zitten? Mijn computer weet natuurlijk de route niet. Als ik een statische route maak op mijn werkstation dat 192.168.1.0/24 netwerk via 10.1.1.1 moet lopen werkt het niet.
Kan ik de vpn adressen uit de pool niet gewoon adressen uit het 192.168.1.0/24 meegeven en geen acceslist toepassen?
[ Voor 1% gewijzigd door Verwijderd op 12-07-2007 13:54 . Reden: ssh werkt, ca certificate maken ! ]
  • Powermage
  • Laatst online: 15-10 21:23
Jou PC zal de pix als default router gaan zien wanneer hij naar een 192 adres gaat connecten, en de pix weet de weg wel te vinden.
Join the club
Ja dat dacht ik dus ook, aangezien "use default gateway on remote network" standaard staat aangevinkt onder windows XP.
Nadat ik vpn connectie heb gemaakt, probeer ik te telnetten naar 192.168.1.1 (=de pix, wat lukt als ik binnen het netwerk zit), maar dit lukt dus niet.
Ik heb ook even geprobeerd met 2 werkstations buiten het netwerk om een vpn connectie te maken en dit lukt op allebei. Ze hebben respectievelijk het adres 10.1.1.1 en 10.1.1.2 gekregen. Elkaar pingen op deze adressen werkt niet.
  • paella
  • Laatst online: 20-10 19:26
Beide VPN connecties zitten op de outside interface en hebben dus beide seclevel 100. Die mogen standaard niet met elkaar praten. Volgens mij dan. :)
er is een command, same-security-traffic permit intra-interface
[ Voor 33% gewijzigd door paella op 26-06-2007 12:40 ]
No production networks were harmed during this posting
ok, vpn connecties onderling mogen niet met elkaar praten vanwege een bepaalde security level, duidelijk.
Maar waarom kan ik vanaf mijn vpn connectie niet naar mijn inside network (192.168.1.0/24) pingen, connecten etc.
Ik vermoed dat het aan de 2 volgende regels ligt
Alleen zo wordt het voorbeeld ook gegeven op de cisco website (http://cisco.com/en/US/pr...ple09186a0080143a5d.shtml. Zij gebruiken alleen 10.1.1.0/24 als inside network en als "vpn pool" gebruiken ze 192.168.1.1-50, maar dit moet verder niet uitmaken, lijkt me).
Ik zit helaas nu niet op locatie, dus ik kan nu niet experimenteren op de pix. Ik hoop dat iemand zo op het eerste gezicht kan zien, wat ik fout heb in mijn config.
  • paella
Draai je productie? Zoniet, zet eens een icmp debug aan.
Die access-list gebruik je voor je NAT0, niet als "echte" access rule. Zou het kunnen dat je dus geen rule heb dat je van je VPN naar je inside mag? Dat is tenslotten en lager seclevel en mag dus niet.
(ik moet er weer een beetje inkomen :))
[ Voor 7% gewijzigd door paella op 26-06-2007 12:50 ]
boosdoener? Lijkt er op dat pix niet helemaal goed kan omgaan met de volgorde van natting. Hij wil de vpn pool gelijk natten naar outside adres voordat hij het eerst naar een inside adres heeft genat.
ik denk dat ik
vervangen moet met
nat (inside) 1 192.168.1.0 255.255.255.0 0 0
Ik moet helemaal inkomen, ik werkte normaal gewoon op ios. pix heeft net iets andere commands ervaar ik.
[ Voor 74% gewijzigd door Verwijderd op 26-06-2007 14:09 ]
Verwijderd schreef op dinsdag 26 juni 2007 @ 13:13:
ik denk dat ik
vervangen moet met
Gisteravond op colo geweest. Dit verhielp het probleem. Iedereen thanks.
kan ik mijn 'vpn pool' (10.1.1.1-10.1.1.50) gelijk inside ip addressen meegeven? Nu worden deze eerst genat d.m.v.
ik heb namelijk een sip server in mijn 192.168.1.0/24 netwerk staan en die werkt niet helemaal lekker met NAT.
  • Flyduck
  • Laatst online: 28-03-2025
Verwijderd schreef op donderdag 12 juli 2007 @ 12:08:
met de regel "nat (inside) 0 access-list 101" geef je juist op dat er geen NAT plaatsvind, dus beetje vreemde vraag?
Zijn er mensen die deze regel lezen? Graag terugkoppeling gewenst (onopvallend)
[ Voor 99% gewijzigd door Verwijderd op 13-07-2007 14:08 . Reden: even mijn comment buiten beschouwing laten, ben verder aan het inlezen ]
  • bazkar
  • Laatst online: 28-05 17:21
Inderdaad een NAT 0 commando geen aan dat er geen NAT moet plaatsvinden.
Even ter aanvulling op paella:
Het same-security-traffic permit intra-interface commando werkt pas vanaf PixOS 7.0 en dus NIET op een PIX501 of PIX506, deze gaan niet verder dan PixOS 6.3.
