Printer stopte met printen. Spool probleem?
  • 45 views sinds 30-01-2008
  • honey
  • Laatst online: 09-09 20:15
[Ik kreeg geen reacties op mijn post op een Amerikaans forum, daarom is het in het Engels. Hopelijk weten jullie wat er aan de hand is.]
I encountered a problem with my Epson R2400 on a Windows XP Pro computer.
My print didn’t complete, a few inches at the bottom wasn’t printed. Well, since it was a test, I didn’t care that much. After some editing I wanted to print another page, but nothing happened. The printer didn’t start and I could see in the pop-up printer-window ‘finish’ the job within a second (the blue progress bar). I tried some new attempts, but failed (I heared the printer a few seconds). If I remember correctly, I saw once the error message: “Unable to connect printer”.
I rebooted, checked all cables, but nothing seems to help. I can see the ink status, so I guess the printer is connected to the computer.
Fortunately I could print when I changed in the properties – Advanced window:
“Spool print documents …” to “Print directly to the Printer”
What has happened, and how can I correct it?
  • Snake
  • Laatst online: 07-03-2024
Snake
Los Angeles, CA, USA
Heb minste wat je kan doen is de post vertalen.
Going for adventure, lots of sun and a convertible! | GMT-8
  • Exorcist
Exorcist
Uitdrijvûrrrr!
Waarschijnlijk is er toch wat gebufferd. Al geprobeerd je drivers te deinstalleren en alles opnieuw te installeren?
Daarnaast is GoT een Nederlands forum, en dien je ook in Nederlands te posten. Beetje lui? ;)
  • dion_b
  • Laatst online: 14:13
dion_b
say Baah
Honestly, if you can't bring up the effort to translate your post into Dutch, why do you expect others to go out of their way to help you here? It shows a certain contempt for the users of this forum.
That aside, this sounds suspiciously like a software problem. You don't mention which drivers you are using, or what happens if you try others. How about starting there...
If all else fails, you may open a topic here, but please do so in Dutch - and respecting everything mentioned in the GoT House Rules - in particular regarding your own effort, and making that clear in your topic start.
Oslik, blyat! Oslik!
