[SunOS 5.8] LP daemon geeft meldingen in terminal
  • iMars
  • Laatst online: 15-10 13:52
iMars
Full time prutser
Ik heb een kort vraagje. De LP daemon geeft meldingen als ik ingelogd ben via SSH.
Message from lp on testbak (???) [ Thu Jun 14 11:23:49 ] ...
Subject: Problem with printer jd-b3220-3
The printer jd-b3220-3 has stopped printing for the reason given below.
Fix the problem and bring the printer back on line.
Printing has stopped, but will be restarted in a few minutes;
issue an enable command if you want to restart sooner.
Unless someone issues a change request
        lp -i jd-b3220-3-796 -P ...
to change the page list to print, the current request will be reprinted from
the beginning.
The reason(s) it stopped (multiple reasons indicate repeated attempts):
exec exit fault
Als ik naar mijn /etc/syslog.conf kijk
29
30
31
32
#ident  "@(#)syslog.conf    1.5 98/12/14 SMI"   /* SunOS 5.0 */
# Copyright (c) 1991-1998 by Sun Microsystems, Inc.
# All rights reserved.
# syslog configuration file.
# This file is processed by m4 so be careful to quote (`') names # that match m4 reserved words.  Also, within ifdef's, arguments # containing commas must be quoted.
*.err;kern.notice;auth.notice           /dev/sysmsg
*.err;kern.debug;daemon.notice;mail.crit    /var/adm/messages
*.alert;kern.err;daemon.err         operator
*.alert                     root
*.emerg                     *
# if a non-loghost machine chooses to have authentication messages # sent to the loghost machine, un-comment out the following line:
#auth.notice            ifdef(`LOGHOST', /var/log/authlog, @loghost)
mail.debug          ifdef(`LOGHOST', /var/log/syslog, @loghost)
# non-loghost machines will use the following lines to cause "user"
# log messages to be logged locally.
ifdef(`LOGHOST', ,
user.err                    /dev/sysmsg
user.err                    /var/adm/messages
user.alert                  `root, operator'
user.emerg                  *
Ik had de volgende 3 regels:
*.alert                     root
*.emerg                     *
... veranderd in:
#*.alert;kern.err;daemon.err            operator
#*.alert                        root
#*.emerg                        *
Vervolgens heb ik de syslog daemon gestopt, en weer gestart
/etc/init.d/syslog stop
/etc/init.d/syslog start
Maarrrrrr, de meldingen blijven in beeld komen.
Kijk ik ergens overheen? Doe ik iets verkeerd?
Koop hier mijn P1 reader :)
  • iMars
iMars
Full time prutser
Niemand? O-)
  • iMars
iMars
Full time prutser
:'( :'( :'( echt niemand?
  • iMars
iMars
Full time prutser
Update, ik heb onderstaand code tijdelijk uitgezet, maar nog steeds kwamen de meldingen binnen
ifdef(`LOGHOST', ,
user.emerg                    *
Ik heb tijdelijk de syslog daemon helemaal uitgezet, en ook dan blijven de meldingen komen. Dus kennelijk is het helemaal niet de syslog, maar een andere daemon die deze meldingen uitspuugt.
In de printer configuratie (/etc/printers.conf) bekeken, maar daar staat nergens iets van meldingen wegschrijven naar een logbestand of naar het scherm.
Heeft (n)iemand een suggestie voor mij?
  • deadinspace
  • Laatst online: 14-10 18:32
deadinspace
The what goes where now?
webmail schreef op donderdag 14 juni 2007 @ 11:52:
Aan de username te zien is het inderdaad niet syslogd die write aanroept, maar iets dat als user lp draait. Misschien dat lpr of lpd dat zelf doen?
Ik zou zeggen: kijk eens in je lpr of lpd configuratie.
  • iMars
iMars
Full time prutser
:'( hopeloos wordt ik er van. Ik kan helemaal niks vinden in de printer configuratie, behalve de printers die ingesteld zijn :'(
