Help for New PC
  • 61 views sinds 30-01-2008
Hi All;
Sorry for not writing in Dutch as I believe good english is better than bad dutch.I am here for studies since 4 months and so dnt know much around here.I am looking to buy a new PC mostly for gaming though not at highest settings.Mostly i will play FPS ones like BF2 etc.And it will be working almost 24/7 downloading etc.A silent one is preferred.
Processor:Intel Core 2 Duo, E6600, Socket 775, Boxed
PSU:Antec NeoHE, 500 Watt, Retail
CASE:AeroCool ExtremEngine 3T, Zwart
RAM:Kingston KVR667D2N5K2/2G, 2048 MB, DDR2, PC5300, 667 MHz
HDD:Hitachi Deskstar T7K500, 500 GB, 7200 RPM, 16 MB, SATA II
MOBO:Asus P5B Deluxe/WiFi-AP,Retail
DVD:NEC AD-7173S, Serial ATA150, Zwart, OEM
DVD:Samsung SH-D163C, S-ATA, Zwart, OEM
GRAPHICS:EVGA Geforce 8800 GTS Superclocked, 320 MB, GDDR3, PCI Express x16
BUDGET:900(+/-200)
I dnt know much of other things.Also I prefer water cooling if it doesnt get out of budget.All advices are welcome :) Is there a chaper alternative withour much difference?
Have a nice day
[ Voor 38% gewijzigd door Verwijderd op 29-05-2007 11:20 ]
  • RoD
RoD
Admin Mobile & FP PowerMod
I think using the Dutch language is required on this forum. If you can read Dutch, I think it's better to start with this: Wat moet ik nemen? Is dit systeem goed? **lezen**
  • stimm
  • Laatst online: 31-07 09:34
Nee hij mag in het engels posten maar wij moeten in het nederlands antwoorden dacht ik :)
(No, he may post in English but we have to answer in dutch)
Intel Core 2 Duo E6600 2x2,40 GHz met 4MB cache + Intel koeler
Moederbord Asus P5B DeluxeWifi/AP met Intel 965 chipset, DDR2, SATA2 en PCI-E 16x
2 GB DDR2 PC6400 800 MHz dual channel TwinMOS
DVD±RW Nec 5170 18x dual layer
320 GB Samsung SATA2
ATI X1950Pro 512MB PCI-E (haalt 5130 in 3DMark06)
Antec Sonata II
Diskettestation
1 jaar garantie als ik me niet vergis
My configuration, 835 euro.
I can tell you the shop I am planning to buy from.
Processor is best at the moment.
Motherboard has installed firewire and wifi. The non-deluxe version costs 50 euro less, but doesn't have those two things. Wifi and firewire cost 30 euro extra if you like, so it only is 20 euro difference. I prefer deluxe, but if you don't need wifi etc its 50 euro less for p5b.
PC6400 from V-Data currently, I would prefer kingston but its 20 euro more. Also, only for overclocking. If you don't need that, take pc5300 kingstons (same price).
Nec is most taken dvd so its decent.
Samsung spinpoint HD's are faster and quieter than other's.
X1950Pro is currently best price/performance, although 7900gs is also good (256mb is I think 50 euro less). I am still deciding which to choose.
Sonata III is better and 10 euros more, take that (I am going to too).
Thanks for all the replies.I have to buy one this week preferraby.Any ideas on how much the cooling might cost?This is part part I have no idea of.Is it possbile to buy a full water cooling system?And how much would it cost?
  • Cio
  • Laatst online: 29-10 19:58
Cio
If silence is a must, then i would recommend a change of PSU, perhaps a fully passive one? Aswell as a case fitted with silencing mats, the antec p180 or antec solo for example. Although more money will mean less noise, the Arctic Freezer Pro should do when not overclocking and is cost effective.
Also, i would go with a 640MB version of the 8800 and a second drive for windows. Perhaps also replace the hitachi with a western digital or samsung drive for less noise during write/seek if you download while sleeping.
Watercooling would be expensive, and the passive chipset combined with a silent case, decent CPU cooler, passive or silent PSU and perhaps aftermarket videocard cooling should be almost as effective when used properly and most likely alot cheaper.
Kinderen zijn net AI; kost veel energie en de helft van de tijd slaan de uitspraken nergens op.
  • Guardian Angel
Guardian Angel
Bejaard en langharig tuig
Ho wacht eens even. De engelse taal spreken betekent niet dat de forumregels ineens niet meer gelden.
RoD in "Help for New PC" Wat moet ik nemen? Is dit systeem goed? **lezen**
ARME AOW’er
Hi I read that.Of course translated to english.It says dont ask general questions If I am right.I have a config and is asking is there a cheaper or better alternative to those.Where is cheaper in Netherland etc.I did read throuh some reviews etc and this is what I chose.But there are more ppl who has more ideas.And also the question is about watercooling if its possible.
If there are any amendments plz let me know.I will change it.But as far as I see it sticks to rules and there are some other similar posts from searches too
Regards
Paul
  • Cio
Cio
Prizes regarding your choices, such as "how much would aircooling cost and how much more would watercooling cost", are at the very least disregarded.
Look up some of the more expensive components via pricewatch, choose the cheapest reliable shop. Compare some options first, we can't advise without full info (and full info is required, this is clearly stated in the sticky)
  • dusty
  • Laatst online: 05:19
dusty
Celebrate Life!
Topic starter kan in het engels praten, echter reacties van de rest worden netjes in het Nederlands verwacht.
[ Voor 6% gewijzigd door dusty op 29-05-2007 18:05 ]
Back In Black!
"Je moet haar alleen aan de ketting leggen" - MueR
  • Thandor
  • Laatst online: 12:46
Thandor
SilverStreak
En zo worden slotjes ook in het Nederlands geplaatst.
Wat moet ik nemen? Is dit systeem goed? **lezen**. Voorgenoemde sticky bevat een aantal eisen waar dit topic niet aan voldoet. Zodoende gaat dit topic op slot.
Pak er eens wat benchmarks en reviews bij. Lees deze en maak op basis daarvan een keuze. Uiteraard kun je ook nog ervaringen op zowel GoT als in de Tweakers.net Productsurvey opzoeken om te kijken of er veel problemen met bepaalde onderdelen voorkomen :) .
