[Debian] Azureus - java self signed certificate
  • 400 views sinds 30-01-2008
Het lukt me niet om een self signed certificate te maken met Azureus.
De bedoeling is om een beveiligde verbinding te maken met azsmrc of Swing web interface om zo Azureus te bedienen.
De software (die relevant zijn denk ik):
- Azureus 2.5.0.4
- Sun Java 1.5 update 11
- OpenSSL 0.9.8c 05 Sep 2006
De foutmelding van Azureus:
Certificate creation failed
1179597106175
Invalid keystore format
De uitgebreide foutmelding (console) van Azureus:
[alert] Alert:3:Certificate creation failed
1179599286038
DEBUG::Sat May 19 20:28:06 CEST 2007::org.gudy.azureus2.ui.swt.auth.CertificateCreatorWindow$createDialog$1::handleEvent::244:
java.io.IOException: Invalid keystore format
at sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:632)
at java.security.KeyStore.load(KeyStore.java:1150)
at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.loadKeyStore(SESecurityManagerImpl.java:526)
at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.loadKeyStore(SESecurityManagerImpl.java:504)
at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.addCertToKeyStore(SESecurityManagerImpl.java:753)
at org.gudy.azureus2.core3.security.impl.SESecurityManagerBC.createSelfSignedCertificate(SESecurityManagerBC.java:96)
at org.gudy.azureus2.core3.security.impl.SESecurityManagerImpl.createSelfSignedCertificate(SESecurityManagerImpl.java:627)
at org.gudy.azureus2.core3.security.SESecurityManager.createSelfSignedCertificate(SESecurityManager.java:103)
at org.gudy.azureus2.ui.swt.auth.CertificateCreatorWindow$createDialog$1.handleEvent(CertificateCreatorWindow.java:232)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1097)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3226)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2898)
at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.<init>(SWTThread.java:134)
at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.createInstance(SWTThread.java:68)
at org.gudy.azureus2.ui.swt.mainwindow.Initializer.<init>(Initializer.java:106)
at org.gudy.azureus2.ui.swt.Main.<init>(Main.java:80)
at org.gudy.azureus2.ui.swt.Main.main(Main.java:180)
Google geeft weinig informatie over de foutmeldingen.
Andere java versie gij (GNU libgcj) version 4.1.2 helpt niet
De Azureus plugin asmrc mekkert wel dat SSL not supported is, maar ja, het lukt me ook niet om een self signed certificate te maken.
Met '/usr/lib/j2sdk1.5-sun/bin/keytool -genkey -alias green -keypass green'
en 'keytool -selfcert -alias green' lukt het wel om een certificaat te maken.
Maar hoe gebruik ik die eventueel in Azureus ?
Iemand nog een idee waar het aan kan liggen ?
