Bottleneck, Compabiliteitsprobleem?
  • 85 views sinds 30-01-2008
Hallo, Ik heb een probleem met de computer van een vriend van me, waarvan ik denk dat het of een bottleneck, of een compabiliteitsprobleem is, hier volgt de setup:
System Information
Time of this report: 5/8/2007, 15:18:44
Machine name: PCMISCHA
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Dutch (Regional Setting: Dutch)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 11/18/05 09:25:04 Ver: 08.00.10
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 212MB used, 2249MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ASUS Extreme AX600XT-TD
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor (0x3E50)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_3E50&SUBSYS_001E1043&REV_00
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug en Play-monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6683 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/15/2007 03:57:34, 267776 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n.v.t.
Mini VDD: ati2mtag.sys
Mini VDD Date: 3/15/2007 03:57:15, 1986560 bytes
Device Identifier: {D7B71EE2-7D10-11CF-E869-1420A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x3E50
SubSys ID: 0x001E1043
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio rear output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_08800000&REV_0905
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5233 (English)
WHQL Logo'd: Yes
Date and Size: 3/16/2006 13:24:06, 4249088 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio rear input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI-mapper (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable-software (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Muis
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Toetsenbord
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-hoofdhub
| Vendor/Product ID: 0x8086, 0x2658
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 9/2/2004 14:00:00, 57600 bytes
| Driver: usbd.sys, 9/2/2004 14:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standaardtoetsenbord (101/102 toetsen) of Microsoft Natural PS/2-toetsenbord
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 9/2/2004 14:00:00, 53760 bytes
| Driver: kbdclass.sys, 9/2/2004 14:00:00, 25216 bytes
+ Toestenbordstuurprogramma voor Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:03:48, 40840 bytes
+ Microsoft PS/2-muis
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 9/2/2004 14:00:00, 23552 bytes
+ Stuurprogramma voor muis van Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: LAN-verbinding - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 100.4 GB
Total Space: 117.2 GB
File System: NTFS
Model: Maxtor 6Y120M0
Drive: D:
Model: LITE-ON DVD SOHD-167T
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Dutch), 9/2/2004 14:00:00, 49536 bytes
Drive: E:
Model: AOPEN DUW1608/ARR
Drive: G:
Model: SCSIVAX DVD/CD-ROM SCSI CdRom Device
System Devices
Name: Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
Device ID: PCI\VEN_8086&DEV_266F&SUBSYS_80A61043&REV_03\3&11583659&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\intelide.sys, 5.01.2600.2180 (Dutch), 8/4/2004 02:56:36, 5632 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Dutch), 9/2/2004 14:00:00, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 9/2/2004 14:00:00, 95360 bytes
Name: Intel(R) 82801FB/FBM SMBus Controller - 266A
Device ID: PCI\VEN_8086&DEV_266A&SUBSYS_80A61043&REV_03\3&11583659&0&FB
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_2668&SUBSYS_814E1043&REV_03\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 17:07:18, 138752 bytes
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2666
Device ID: PCI\VEN_8086&DEV_2666&SUBSYS_00000000&REV_03\3&11583659&0&E3
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (Dutch), 9/2/2004 14:00:00, 68224 bytes
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2664
Device ID: PCI\VEN_8086&DEV_2664&SUBSYS_00000000&REV_03\3&11583659&0&E2
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2662
Device ID: PCI\VEN_8086&DEV_2662&SUBSYS_00000000&REV_03\3&11583659&0&E1
Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2660
Device ID: PCI\VEN_8086&DEV_2660&SUBSYS_00000000&REV_03\3&11583659&0&E0
Name: Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Device ID: PCI\VEN_8086&DEV_265C&SUBSYS_80A61043&REV_03\3&11583659&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 9/2/2004 14:00:00, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 9/2/2004 14:00:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (Dutch), 8/4/2004 03:03:24, 76288 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 9/2/2004 14:00:00, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 9/2/2004 14:00:00, 7168 bytes
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
Device ID: PCI\VEN_8086&DEV_265B&SUBSYS_80A61043&REV_03\3&11583659&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 9/2/2004 14:00:00, 20480 bytes
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
Device ID: PCI\VEN_8086&DEV_265A&SUBSYS_80A61043&REV_03\3&11583659&0&EA
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
Device ID: PCI\VEN_8086&DEV_2659&SUBSYS_80A61043&REV_03\3&11583659&0&E9
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
Device ID: PCI\VEN_8086&DEV_2658&SUBSYS_80A61043&REV_03\3&11583659&0&E8
Name: Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Device ID: PCI\VEN_8086&DEV_2651&SUBSYS_26011043&REV_03\3&11583659&0&FA
Name: Intel(R) 82801FB LPC Interface Controller - 2640
Device ID: PCI\VEN_8086&DEV_2640&SUBSYS_00000000&REV_03\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (Dutch), 9/2/2004 14:00:00, 36352 bytes
Name: Intel(R) 915G/P/GV PCI Express Root Port - 2581
Device ID: PCI\VEN_8086&DEV_2581&SUBSYS_00000000&REV_04\3&11583659&0&08
Name: Intel(R) 915G/P/GV Processor to I/O Controller - 2580
Device ID: PCI\VEN_8086&DEV_2580&SUBSYS_00000000&REV_04\3&11583659&0&00
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_D3\3&11583659&0&F0
Name: Intel(R) PRO/100 VE Network Connection
Device ID: PCI\VEN_8086&DEV_1064&SUBSYS_80F81043&REV_03\4&23C0B1C&0&40F0
Driver: C:\WINDOWS\system32\DRIVERS\e100b325.sys, 8.00.0011.0000 (Dutch), 6/22/2004 08:32:34, 154112 bytes
Driver: C:\WINDOWS\system32\Prounstl.exe, 7.00.0009.0000 (English), 6/16/2004 16:20:00, 122880 bytes
Driver: C:\WINDOWS\system32\e100b325.din, 9/3/2003 15:32:52, 5110 bytes
Driver: C:\WINDOWS\system32\IntelNic.dll, 3.00.0006.0000 (English), 4/19/2004 17:12:54, 19456 bytes
Driver: C:\WINDOWS\system32\e100bmsg.dll, 6/21/2004 14:22:08, 24576 bytes
Name: ASUS Extreme AX600XT-TD- Secondary
Device ID: PCI\VEN_1002&DEV_3E70&SUBSYS_001F1043&REV_00\4&37AD8B77&0&0108
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6683 (Dutch), 3/15/2007 03:57:15, 1986560 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0010 (English), 3/15/2007 03:14:00, 49152 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 3/15/2007 04:32:36, 41136 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 8/23/2006 23:26:56, 2096 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 1/10/2007 19:32:44, 929 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 1/10/2007 19:32:44, 655842 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativdkxx.vp, 8/23/2006 23:26:56, 2096 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6683 (English), 3/15/2007 03:57:34, 267776 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0337 (English), 3/15/2007 03:10:28, 356352 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 3/15/2007 03:50:19, 26112 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0489 (English), 3/15/2007 03:40:10, 2820544 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0010.0148 (English), 3/15/2007 03:29:47, 1315712 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 3/7/2007 00:04:53, 143676 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dat, 3/15/2007 03:29:32, 3107788 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 3/15/2007 03:47:52, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 3/15/2007 03:14:43, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 17:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4163 (English), 3/15/2007 03:48:39, 450560 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4162 (English), 3/15/2007 03:49:59, 114688 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2516 (English), 3/15/2007 03:50:39, 122880 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0020 (English), 3/15/2007 03:50:27, 114688 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2511 (English), 3/15/2007 03:50:12, 42496 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0054 (Dutch), 3/15/2007 03:16:14, 258048 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 2/16/2007 19:04:14, 7072 bytes
Driver: C:\WINDOWS\system32\ATIDEMGX.dll, 2.00.2629.37759 (Dutch), 3/15/2007 03:58:38, 315392 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.6458 (English), 3/15/2007 03:19:32, 5402624 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 3/15/2007 03:55:38, 307200 bytes
Device ID: PCI\VEN_1002&DEV_3E50&SUBSYS_001E1043&REV_00\4&37AD8B77&0&0008
Name: VAX347S SCSI Controller
Device ID: PCI\VAX347S\0000
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 9/2/2004 14:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 9/2/2004 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 9/2/2004 14:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 9/2/2004 14:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 9/2/2004 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 9/2/2004 14:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 Dutch Final Retail 9/2/2004 14:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 9/2/2004 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 Dutch Final Retail 9/2/2004 14:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 164352 bytes
dinput8.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 186880 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 9/2/2004 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 Dutch Final Retail 9/2/2004 14:00:00 395264 bytes
joy.cpl: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 69632 bytes
gcdef.dll: 5.01.2600.0000 Dutch Final Retail 9/2/2004 14:00:00 77312 bytes
pid.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 35328 bytes
dsound.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 72192 bytes
dmusic.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 82432 bytes
system.dll: 1.00.3705.6018 English Final Retail 5/7/2007 18:38:36 1179648 bytes
system.dll: 1.01.4322.2032 English Final Retail 5/7/2007 19:21:41 1224704 bytes
dx7vb.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 9/2/2004 14:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 9/2/2004 14:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 24576 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 9/2/2004 14:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 9/2/2004 14:00:00 498205 bytes
mciqtz32.dll: 6.05.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 35328 bytes
mpg2splt.ax: 6.05.2710.2732 English Final Retail 8/17/2005 22:02:16 165376 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 9/2/2004 14:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 279040 bytes
qdvd.dll: 6.05.2600.2709 Dutch Final Retail 6/29/2005 03:56:46 385536 bytes
qedit.dll: 6.05.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 562688 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 9/2/2004 14:00:00 733696 bytes
quartz.dll: 6.05.2600.2709 Dutch Final Retail 6/29/2005 03:56:46 1291776 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 9/2/2004 14:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 9/2/2004 14:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 9/2/2004 14:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 9/2/2004 14:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 9/2/2004 14:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 9/2/2004 14:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 9/2/2004 14:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 9/2/2004 14:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 9/2/2004 14:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 204800 bytes
ks.sys: 5.03.2600.2180 Dutch Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 Dutch Final Retail 8/4/2004 01:03:38 130048 bytes
ksuser.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 01:03:14 4096 bytes
stream.sys: 5.03.2600.2180 Dutch Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 Dutch Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 Dutch Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 Dutch Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 4352 bytes
msdvbnp.ax: 6.05.2710.2732 English Final Retail 8/17/2005 23:56:52 58368 bytes
psisdecd.dll: 6.05.2715.3011 English Final Retail 10/9/2006 16:12:14 235008 bytes
psisrndr.ax: 6.05.2715.3011 English Final Retail 10/9/2006 16:12:30 224256 bytes
mpeg2data.ax: 6.05.2710.2732 English Final Retail 8/17/2005 23:56:52 62976 bytes
msvidctl.dll: 6.05.2715.3011 English Final Retail 10/9/2006 16:15:52 1669632 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 9/2/2004 14:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 Dutch Final Retail 9/2/2004 14:00:00 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2709
WST Renderer,0x00800000,1,1,WSTRenderer.ax,6.05.2710.2732
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2709
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2709
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2709
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2710.2732
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2715.3011
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Microsoft TV Caption Decoder,0x00600000,1,0,MSTVCapn.dll,5.01.2715.3011
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2709
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2709
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2709
VBI Codec,0x00600000,1,4,VBICodec.ax,6.05.2710.2732
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2710.2732
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2709
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2709
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2709
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2709
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2709
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2715.3011
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2709
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2709
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2709
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
CBVA Filter,0x00200000,1,1,CBVAFilter.dll,5.01.2700.2180
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2709
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2709
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2709
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WST Pager,0x00800000,1,1,WSTPager.ax,6.05.2710.2732
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2710.2732
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2710.2732
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2715.3011
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2709
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2709
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2709
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2709
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2709
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2709
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2709
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2709
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2709
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2709
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2709
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2709
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2709
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM streaming-gegevenstransformaties:
Microsoft Kernel akoestische echo-opheffing,0x00000000,0,0,,
Microsoft Kernel GS Wavetable-synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS-synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM-audiodecoder,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2709
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV-codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2709
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2709
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2709
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2709
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2709
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2709
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2709
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2709
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2709
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2709
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2709
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2709
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2709
Audio Capture Sources:
Realtek HD Audio rear input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2709
Microsoft GS Wavetable-software,0x00200000,1,0,quartz.dll,6.05.2600.2709
WDM streaming-opnameapparaten:
Realtek HD Audio rear input,0x00200000,1,1,,5.03.2600.2180
,0x00000000,0,0,,
WDM streaming-opbouwprincipeapparatuur:
,0x00000000,0,0,,
Realtek HD Audio rear output,0x00200000,2,1,,5.03.2600.2180
BDA Network Providers:
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.05.2710.2732
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2710.2732
WDM streaming-mixer-apparatuur:
Microsoft Kernel Wave-audiomixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2715.3011
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2715.3011
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2715.3011
Audio Renderers:
Realtek HD Audio rear output,0x00200000,1,0,quartz.dll,6.05.2600.2709
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2709
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2709
DirectSound: Realtek HD Audio rear output,0x00200000,1,0,quartz.dll,6.05.2600.2709
WDM-streaming systeemapparaten:
Realtek HD Audio rear input,0x00200000,6,1,,5.03.2600.2180
Realtek HD Audio rear output,0x00200000,14,1,,5.03.2600.2180
Ik denk dat het de videokaart is, misschien een vreemd iets, maar ik heb dit systeem al 9x opnieuw geinstalleerd, omdat hij na 1 maand alweer ernstige kuren begon te vertonen, en als ik na dat het systeem opnieuw geinstalleerd is, de ATi Drivers installeer, begint hij al instabieler te worden met vreemde errors, van niet gevonden bestanden, daarna is door de winkel het volgende vervangen:
Moederbord
Harde schijf
Processor
Voeding
Geheugen
maar hij bleef de zelfde fouten vertonen...
  • Turkish
  • Laatst online: 30-09 08:55
Turkish
zhé germans
Hangen en Opstartproblemen troubleshooter
Met zo'n output alleen kunen we natuurlijk niets. Post in een goede topicstart ook je volledige specs, want dit lijkt echt nergens op
'When you're not paying for the product, you are the product!'
