Mails komen niet aan via linux mailserver en mail phpfunctie
We zijn al geruime tijd bezig met het opzetten van de mailserver op onze webserver met plesk.
nu is het zo dat de mails via de mail() functie wel in gmail aankomen maar niet in de gewone mail.
we hebben verschillende dingen veranderd waaronder voor het weekend de spf records.
De headers zien er momenteel als volgt uit:
De ene keer ziet hij er zo uit:
Delivered-To: herodias@gmail.com
Received: by 10.114.24.16 with SMTP id 16cs41125wax;
        Tue, 1 May 2007 01:00:17 -0700 (PDT)
Received: by 10.82.113.6 with SMTP id l6mr13558605buc.1178006417197;
        Tue, 01 May 2007 01:00:17 -0700 (PDT)
Return-Path: <root@ppu002.local>
Received: from PPU002.local (vcadirect.nl [85.17.142.65])
        by mx.google.com with ESMTP id c24si2321879ika.2007.05.01.01.00.15;
Received-SPF: neutral (google.com: 85.17.142.65 is neither permitted nor denied by best guess record for domain of root@ppu002.local)
Received: (qmail 5794 invoked by uid 0); 1 May 2007 09:57:51 +0200
Date: 1 May 2007 09:57:51 +0200
Message-ID: <20070501075751.5791.qmail@PPU002.local>
Subject: jezus christus
en de andere keer
Received: by 10.114.24.16 with SMTP id 16cs41168wax;
        Tue, 1 May 2007 01:01:27 -0700 (PDT)
Received: by 10.66.254.2 with SMTP id b2mr142160ugi.1178006486667;
        Tue, 01 May 2007 01:01:26 -0700 (PDT)
Return-Path: <root@vcadirect.nl>
        by mx.google.com with ESMTP id y34si3007891iky.2007.05.01.01.01.26;
Received-SPF: pass (google.com: domain of root@vcadirect.nl designates 85.17.142.65 as permitted sender)
Date: Tue, 01 May 2007 01:01:26 -0700 (PDT)
Message-Id: <4636f3d6.19428a3f.657e.ffff83c1SMTPIN_ADDED@mx.google.com>
Received: (qmail 5805 invoked from network); 1 May 2007 09:59:02 +0200
Received: from localhost (HELO vcadirect.nl) (127.0.0.1)
  by localhost with SMTP; 1 May 2007 09:58:56 +0200
zonder wat te veranderen.
hebben jullie wellicht nog ideeen?
alvast hartelijk dank!
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
De eerste heb je als verzender 'root@PPU002.local' staan, de tweede daarintegen 'root@vcadirect.nl', daar lijkt me de eerste niet goed :)
Ik gok dat of je hostname niet goed staat in /etc/hosts of je instellingen van postfix/exim/sendmail nog op dat rare .local adres staan.
God, root, what is difference? | Talga Vassternich | IBM zuigt
moto-moi schreef op dinsdag 01 mei 2007 @ 10:34:
Zou je mij wellicht bondig kunnen beschrijven waar ik die hosts kan vervangen. zo'n vermoeden had ik namelijk al.
Verwijderd schreef op dinsdag 01 mei 2007 @ 10:44:
vi /etc/hosts; welkom op een UNIX based OS =)
vi /etc/hosts
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1 vcadirect.nl vcadirect localhost.localdomain localhost
172.16.142.65 vcadirect.nl vcadirect PPU002
Hostname staat nu indd goed maar kwa mail functionaliteit maakt het niks uit , mails blijven nergens aankomen bijhalve Gmail
[ Voor 19% gewijzigd door Verwijderd op 01-05-2007 10:52 ]
Even voor de duidelijkheid. dataneger hoort bij mij ;-)
Begin eens met het beschrijven wat voor mailserver je gebruikt op wat voor unix release, wat voor log/fout meldingen je krijgt in je logfiles en je configuratie files + beschrijving van jullie mailserver setup zijn ook handig.
License key number PLSK.*****************
Operating system Linux 2.6.9-42.0.10.ELsmp
Plesk version psa v8.1.1_build81070322.16 os_CentOS 4.2
Hostname vcadirect.nl
MTA = Qmail (sendmail)
wat voor meldingen in welke log files zoek je R3boot ?
Meldingen van een mailtje wat verstuurd wordt. Eventuele foutmeldingen van je MTA zijn ook handig (die worden, als 't goed is, het blijft qmail, gelogged naar syslog). Tevens, de daadwerkelijke configuratie files van je MTA kunnen ons laten zien wat voor configuratie je gebruikt.
  • lier
  • Laatst online: 17-10 15:25
lier
MikroTik nerd
Verwijderd schreef op dinsdag 01 mei 2007 @ 10:51:
vi /etc/hosts
Moet je op je externe adres niet uitgaan van de FQDN ?
Ik zou in ieder geval PPU002.vcadirect.nl bij het externe IP adres verwachten.
Verder zou ik vcadirect.nl en vcadirect niet aan zowel je externe als je interne IP adres koppelen (al is het alleen voor de overzichtelijkheid).
Ga maar eerst eens kijken of je de log file(s) van je mail server kan vinden, als je deze bekijkt zal er misschien iets meer duidelijk worden.
/usr/local/psa/var/log/maillog en maillog.processed
May 1 03:57:04 mail pop3d: Connection, ip=[127.0.0.1]
May 1 03:57:04 mail pop3d: LOGOUT, ip=[127.0.0.1]
May 1 03:57:04 mail imapd-ssl: Connection, ip=[127.0.0.1]
May 1 03:57:04 mail imapd-ssl: 1177984624.788413 LOGOUT, ip=[127.0.0.1], rcvd=12, sent=310, maildir=/
May 1 03:57:04 mail imapd: Connection, ip=[127.0.0.1]
May 1 03:57:04 mail imapd: 1177984624.791185 LOGOUT, ip=[127.0.0.1], rcvd=12, sent=308, maildir=/
May 1 04:02:01 mail qmail-queue[3652]: mail: all addreses are uncheckable - need to skip scanning (by deny mode)
May 1 04:02:01 mail qmail-queue[3652]: scan: the message(drweb.tmp.y0Kizv) sent by root@PPU002.local to root@PPU002.local should be passed without checks, $
May 1 04:02:01 mail qmail: 1177984921.782337 new msg 6964651
May 1 04:02:01 mail qmail: 1177984921.782463 info msg 6964651: bytes 6144 from <root@ppu002.local> qp 3654 uid 0
May 1 04:02:01 mail qmail: 1177984921.790197 starting delivery 213: msg 6964651 to remote root@ppu002.local
May 1 04:02:01 mail qmail: 1177984921.790327 status: local 0/10 remote 1/20
May 1 04:02:01 mail qmail: 1177984921.803141 delivery 213: failure: Sorry,_I_couldn't_find_any_host_named_ppu002.local._(#5.1.2)/
May 1 04:02:01 mail qmail: 1177984921.803315 status: local 0/10 remote 0/20
Bedoelen jullie deze ? dit is een stukje log van vandaag 1 mei , tijd van de server staat niet goed zo te zien :)
Lier: ik heb de hosts file nooit aangepast dit wordt automaties standaard door plesk aangemaakt
  • hamsteg
  • Laatst online: 17-10 18:47
hamsteg
Species 5618
Zie reactie boven die van jou van Lier, 2de regel.
Niet quoten, zorgvuldige reacties volgens de regels worden zo weggewerkt: *knip*, reactie op geknipte reactie.
ik heb de hostname verandert in ppu002.vcadirect.nl , hierdoor is me hosts file verandert in -->
172.16.142.65 ppu002.vcadirect.nl ppu002 PPU002
  • lier
lier
MikroTik nerd
Verwijderd schreef op dinsdag 01 mei 2007 @ 12:24:
Maak er eventueel het volgende van:
127.0.0.1       localhost
Draai je ook bind op de server ?
ok hosts file aangepast , en ja ik draai Bind op de server
nieuwe hosts file is
127.0.0.1 localhost
  • lier
lier
MikroTik nerd
Doe een restart van Bind en test of het mailen nu wel goed gaat.
hoe restart ik Bind deze zit namelijk in Plesk en vind ik niet terug als losse functie in /etc/init.d/
ik kan wel plesk restarten maar weet niet of dat genoeg is
Een andere naam voor bind (Berkeley Internet Name Domain) is named (Name Daemon). Je zou dus /etc/init.d/named restart moeten kunnen doen.
Bind restarted indd met /etc/init.d/named restart
maar helaas werkt daardoor de mail functie nog niet !
iemand nog andere suggesties ?
  • lier
lier
MikroTik nerd
Post dan nog eens wat uit de mail.log (en heb je ook een mail.err ?).
lier schreef op dinsdag 01 mei 2007 @ 13:58:
Hij draait qmail, en dat logt in zn eigen, cryptische, formaat wat totaal incompatible is met de standaard maillogs.... Zie ook de log output hierboven
hmmz mail.err kan ik niet locaten ! ik zal ffe door de logs heen zoeken of ik nieuwe errors krijg !
ik kan geen mail error log vinden , iemand een idee waar die zou kunnen staan of hoe die heet
[ Voor 32% gewijzigd door Verwijderd op 01-05-2007 15:25 ]
  • Pim.
  • Registratie: Mei 2001
  • Laatst online: 07-08 06:58
Pim.
Aut viam inveniam, aut faciam
OK topicstarter en dataneger,
Jullie krijgen nu ongeveer alles voorgekauwd en om heel eerlijk te zijn heb ik grote twijfels bij dit topic. Ik stel voor dat jullie iets meer zelf het werk doen en de search gebruiken.
"The trouble with quotes from the Internet is that you can never know if they are genuine." - Elvis Presley | Niet met me eens ? DM ME
