Cisco 2800 koppelen aan ISDN-30 PRI
  • 170 views sinds 30-01-2008
Ik wil een Cisco 2851 router koppelen aan het PSTN (ISDN30/PRI middels H323 protocol)
Het werkt nog niet .!?!
Kan iemand helpen?
Mvg, Marty
VG1008001#sh run
Building configuration...
Current configuration : 4500 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname VG1008001
boot-start-marker
boot-end-marker
card type e1 0 1
logging buffered 51200 warnings
no aaa new-model
resource policy
network-clock-participate wic 1
ip subnet-zero
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice-card 0
dspfarm
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 1
h225 timeout tcp establish 5
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31
description E1 koppeling naar PSTN
controller E1 0/1/1
pri-group timeslots 1-31 service mgcp
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.219.4.29 255.255.252.0
load-interval 30
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.219.4.29
interface Serial0/1/0:15
no ip address
isdn incoming-voice voice
no cdp enable
interface Serial0/1/1:15
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.219.4.1
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit any
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0:15
cptone NL
voice-port 0/1/1:15
cptone NL
ccm-manager mgcp
no ccm-manager fax protocol cisco
mgcp call-agent 10.219.4.13 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode cisco
no mgcp timer receive-rtcp
mgcp profile default
dial-peer voice 1 pots
tone ringback alert-no-PI
description Outgoing PSTN calls for 0.T
destination-pattern 0T
direct-inward-dial
port 0/1/0:15
forward-digits all
dial-peer voice 1008001 voip
description VG1008001-VS1008001
preference 1
destination-pattern 8..
voice-class codec 1
session target ipv4:10.219.4.13
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1008002 voip
description VG1008001-VS1008002
preference 2
voice-class codec 1
no vad
banner login ^C
^C
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password test
login
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
VG1008001#sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(3f), RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 18-Aug-06 18:47 by alnguyen
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
VG1008001 uptime is 6 days, 4 hours, 1 minute
System returned to ROM by reload at 07:58:57 UTC Fri Apr 20 2007
System image file is "flash:c2800nm-spservicesk9-mz.124-3f.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco 2851 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FHK1045U05F
2 Gigabit Ethernet interfaces
62 Serial interfaces
2 Channelized E1/PRI ports
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102
VG1008001#
  • Equator
  • Laatst online: 20-10 17:05
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Ja dag :w
Je config dumpen met de melding: hij doet het niet is dus niet de bedoeling hier.
Wat werkt er niet, wat heb je al gedaan om het op te lossen..
Suc6
