Iptables redirect werkt niet.
  • 120 views sinds 30-01-2008
Ik ben inmiddels alweer 2 uur aan de gang om aankomende verbindingen van 26 en 587 naar internet 25 door te verwijzen in iptables. Dit lukt met geen mogelijkheid.
Dit is mijn iptables config:
# Firewall configuration written by system-config-securitylevel
# Manual customization of this file is not recommended.
*filter
:FORWARD ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:RH-Firewall-1-INPUT - [0:0]
:OUTPUT ACCEPT [0:0]
-A FORWARD -o eth0 -j LOG --log-level 7 --log-prefix BANDWIDTH_OUT:
-A FORWARD -i eth0 -j LOG --log-level 7 --log-prefix BANDWIDTH_IN:
-A OUTPUT -o eth0 -j LOG --log-level 7 --log-prefix BANDWIDTH_OUT:
-A INPUT -i eth0 -j LOG --log-level 7 --log-prefix BANDWIDTH_IN:
-A INPUT -j RH-Firewall-1-INPUT
-A FORWARD -j RH-Firewall-1-INPUT
-A RH-Firewall-1-INPUT -i lo -j ACCEPT
-A RH-Firewall-1-INPUT -p icmp --icmp-type any -j ACCEPT
-A RH-Firewall-1-INPUT -p 50 -j ACCEPT
-A RH-Firewall-1-INPUT -p 51 -j ACCEPT
-A RH-Firewall-1-INPUT -p udp -d 224.0.0.251 --dport 5353 -j ACCEPT
-A RH-Firewall-1-INPUT -p udp -m udp --dport 631 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 22022 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 237 --state NEW -j ACCEPT
# -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 236 -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 443 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 26 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 587 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 110 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 143 --state NEW -j ACCEPT
# -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 993 -j ACCEPT -A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 995 -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 25 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 60000 -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 10001 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 10024 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -p tcp -m state -m tcp --dport 80 --state NEW -j ACCEPT
-A RH-Firewall-1-INPUT -j REJECT --reject-with icmp-host-prohibited
COMMIT
# Generated by webmin
*mangle
:INPUT ACCEPT [0:0]
:PREROUTING ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
COMMIT
# Completed
*nat
COMMIT
# Completed
Om de redirect te bewerktstelligen heb ik voortdurent dit commando gebruikt:
iptables -A PREROUTING -t nat -p tcp -m tcp --dport 26 -j REDIRECT --to-ports 25
iptables -A PREROUTING -t nat -p tcp -m tcp --dport 587 -j REDIRECT --to-ports 25
Bij beide commando's krijg ik de volgende response:
iptables: No chain/target/match by that name
Ik snap er niets van? En ik moet dit voor morgenochtend regelen. Is er iemand met meer verstand van zaken die me een zet in de goede richting kan geven?
  • Confusion
  • Laatst online: 01-07 21:46
Confusion
Fallen from grace
REDIRECT is geen geldige target voor -j, omdat er geen chain met die naam is en het geen 'speciale' naam is?
Wie trösten wir uns, die Mörder aller Mörder?
Iptables newbie:
en dat betekent dat?? Chain aanmaken/onder andere chain plaatsen??
  • CyBeR
CyBeR
Heb ik 't nou goed en wil je een lokale mail daemon op meerdere poorten beschikbaar maken? Dat is veel handiger te doen door de betreffende daemon op meerdere poorten te laten listenen...
Dan zou ik postfix dus naast poort 25 op meerdere poorten moeten laten luisteren? Hoe gaat dat in zijn werk? Ik kan wel van alles vinden over het veranderen van de listen port, maar niets over het toevoegen van een extra poort.
  • CyBeR
CyBeR
Ik heb het al gevonden! Om postfix op zowel poort 26 als 25 te laten luisteren moet je de volgende regel toevoegen aan /etc/postfix/master.cf:
26 inet n - - - - smtpd
