• simon
  • Laatst online: 20:40
Jep, hij is uit, iig volgens Canon USA:
De updates:
Release notes:
1. Changes from Digital Photo Professional 2.2
Added functions
1-1. Support added for Windows Vista.
1-2. Support was added for EOS-1D Mark III.
1-3. Support added for single-image display for RAW+JPEG images. (*)
The edited content is applied only to RAW images. File moving, copying, or deleting applies to both the RAW image and the JPEG image. Single image display is only used with CR2-type RAW and JPEG images that were shot simultaneously. (The images used with TIFF-type RAW and JPEG images can not be displayed as a single image).
1-4. Enabled thumbnail image rearranging using drag & drop.
1-5. Enabled a frame display in trimmed images in main window or edit image window.
1-6. Added multi-image synchronizing function in edit window.
1-7. Supported multi-page printing in detailed setting printing.
1-8. Enabled a Color Management settings window call function in the detailed setting printing window.
1-9. Enabled images trimmed in DPP to print as trimmed images when they are printed using Easy-PhotoPrint, Easy-PhotoPrint Pro.
1-10. The GPS data can be displayed with other shooting information when the GPS data is added to it.
Changed Functions
1-11. Brought together as collective image adjustments in the tool palette in the main window. Added a noise reduction tab, and allowed noise reduction to be applied to individual images.
1-12. Changed the display method of trimmed images in edit window, edit image window. Images trimmed in DPP are now printed as trimmed images.
1-13. Improved the speed for displaying RAW images in edit window.
1-14. Support added for new Picture Style files. (.pf2)
The extension for the Picture Style files has been changed from ".pse" to ".pf2" Please download the files again. The effect of the files has not been changed.
Modified Functions
1-15. When selecting the detailed setting printing and contact sheet printing, the printing result could become completely white (or in some cases, completely black). But this has been corrected.
DL voor Win: http://beta00.c-wss.com/i...156EN0101/DPP30UPD_EN.exe
DL voor Mac: http://beta00.c-wss.com/i...0114157EN0101/DPP300X.dmg
