WHERE-Statement
  • 44 views sinds 30-01-2008
  • Vincent Veeger
  • Laatst online: 06-10 00:49
using DAO/Jet on .dbf files,
I got the following WHERE statement in a large SELECT-statement:
WHERE fonds.codnr LIKE '%%port.mabelcode2'
It should be valid if field codnr in table fonds for example contains "0000123" and field mabelcode2 in table port contains "123" (both fields of type chr)
Problem is that '%%port.mabelcode2' does not translate into "%123".
If I remove the quotes it generates a syntax error. If I change '%%port.mabelcode2' into '%%123' it works (valid record).
How can I use the contents of field "mabelcode2" as the "seed" in the LIKE-statement?
  • P.O. Box
probeer eens
LIKE CONCAT('%%', port.bruinsmacode2);
of
LIKE '%%' & port.bruinsmacode2
of
LIKE '%%' + port.bruinsmacode2
[ Voor 5% gewijzigd door P.O. Box op 30-03-2007 14:36 ]
  • whoami
  • Laatst online: 00:31
Als je je vraag op verschillende fora stelt, mag je wel minstens de moeite doen om 'm hier in het nederlands neer te zetten.
https://fgheysels.github.io/
