ping via timer
  • 47 views sinds 30-01-2008
Ik wil graag onderstaande voorbeeldcode uit MSDN uitbreiden met een timer die de code elke minuut aftrapt. Wie kan en wil me helpen?
Visual Basic .NET:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
Imports System.Net.NetworkInformation
Imports System.Globalization
Imports System.ComponentModel
Imports System
Imports System.Windows.Forms
Public Class PingClientForm
    Dim WithEvents pingClient As New Ping()
    Private Sub pingClient_PingCompleted( _
        ByVal sender As Object, ByVal e As PingCompletedEventArgs) _
        Handles pingClient.PingCompleted
        ' Check to see if an error occurred.  If no error, then display the
        ' address used and the ping time in milliseconds
        If e.Error Is Nothing Then
            If e.Cancelled Then
                pingDetailsTextBox.Text &= _
                    "Ping cancelled." & Environment.NewLine
            Else
                If e.Reply.Status = IPStatus.Success Then
                        "  " & e.Reply.Address.ToString() & " " & _
                        e.Reply.RoundtripTime.ToString( _
                        NumberFormatInfo.CurrentInfo) & "ms " & _
                        Environment.NewLine
                Else
                        "  " & GetStatusString(e.Reply.Status) & _
                        Environment.NewLine
                End If
            End If
        Else
            ' Otherwise display the error
                "  Ping error." & Environment.NewLine
            MessageBox.Show( _
                "An error occurred while sending this ping. " & _
                e.Error.InnerException.Message.ToString())
        End If
        sendPingButton.Enabled = True
    End Sub
    Private Function GetStatusString(ByVal status As IPStatus) As String
        Select Case status
            Case IPStatus.Success
                Return "Success."
            Case IPStatus.DestinationHostUnreachable
                Return "Destination host unreachable."
            Case IPStatus.DestinationNetworkUnreachable
                Return "Destination network unreachable."
            Case IPStatus.DestinationPortUnreachable
                Return "Destination port unreachable."
            Case IPStatus.DestinationProtocolUnreachable
                Return "Destination protocol unreachable."
            Case IPStatus.PacketTooBig
                Return "Packet too big."
            Case IPStatus.TtlExpired
                Return "TTL expired."
            Case IPStatus.ParameterProblem
                Return "Parameter problem."
            Case IPStatus.SourceQuench
                Return "Source quench."
            Case IPStatus.TimedOut
                Return "Timed out."
            Case Else
                Return "Ping failed."
        End Select
    End Function
    Private Sub sendPingButton_click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles sendPingButton.Click
        addressTextBox.SelectAll()
        If addressTextBox.Text.Length <> 0 Then
            ' Disable the Send button.
            sendPingButton.Enabled = False
                "Pinging " & addressTextBox.Text & _
                " . . ." & Environment.NewLine
            ' Send ping request
            pingClient.SendAsync(addressTextBox.Text, Nothing)
        Else
            MessageBox.Show("Please enter an IP address or host name.")
        End If
        sendPingButton.Update()
    End Sub
    Private Sub cancelPingButton_Click( _
        ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cancelPingButton.Click
        ' Cancel any pending pings.
        pingClient.SendAsyncCancel()
    End Sub
End Class
[ Voor 0% gewijzigd door RobIII op 20-03-2007 22:43 . Reden: Code tags ]
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Beste Jack van Deur,
Zoals je in ons beleid kunt lezen doen we hier niet aan 'quick-fix' oplossingen of 'scriptrequests'; dit soort topics gaan regelrecht op slot. Ik wil je dan ook vriendelijk verzoeken even onze quickstart door te lezen voordat je een nieuw topic opent.
Tot slot: als je code post, gebruik dan [code] tags om het geheel leesbaarder te maken ;)
Desalniettemin; welkom op GoT :w ;)
[ Voor 50% gewijzigd door RobIII op 20-03-2007 22:38 ]
Je eigen tweaker.me redirect
Over mij
