[OSX10.4.9] Na update airport crashes
  • 288 views sinds 30-01-2008
  • Floor-is
  • Laatst online: 22:04
Sinds de laatste update van OSX heb ik een klein probleem. Mijn airport crashed namelijk telkens. Gezien ik het zonder bekabeling in mijn huis moet stellen heb ik wat minder mogelijkheid tot prettig werken door dit gedoe.
Uit de console kan ik het volgende achterhalen:
Mar 19 19:02:44 PussyLounge crashdump[225]: airport crashed
Mar 19 19:02:44 PussyLounge crashdump[225]: crash report written to: /Users/FD/Library/Logs/CrashReporter/airport.crash.log
Uit de crashlog blijkt het volgende:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
===== Monday, March 19, 2007 6:57:16 PM Europe/Amsterdam =====
Host Name:      PussyLounge
Date/Time:      2007-03-19 19:02:43.915 +0100
OS Version:     10.4.9 (Build 8P2137)
Report Version: 4
Command: airport
Path:    /System/Library/PrivateFrameworks/Apple80211.framework/Resources/airport
Parent:  launchd [1]
Version: ??? (???)
PID:    224
Thread: 0
Exception:  EXC_BAD_ACCESS (0x0001)
Codes:      KERN_PROTECTION_FAILURE (0x0002) at 0x00000006
Thread 0 Crashed:
0   com.apple.CoreFoundation        0x908272b7 CFGetTypeID + 17
1   com.apple.SystemConfiguration   0x91422ccc _SCCopyDescription + 48
2   com.apple.CoreFoundation        0x90815fea _CFStringAppendFormatAndArgumentsAux + 5639
3   com.apple.CoreFoundation        0x908148dc _CFStringCreateWithFormatAndArgumentsAux + 122
4   com.apple.SystemConfiguration   0x91417bc0 SCLog + 84
5   airport                         0x00009822 0x1000 + 34850
6   airport                         0x00002ad0 0x1000 + 6864
7   airport                         0x00003f1f 0x1000 + 12063
8   airport                         0x0000459b 0x1000 + 13723
9   com.apple.CoreFoundation        0x9083e385 __CFMachPortPerform + 136
10  com.apple.CoreFoundation        0x9082e62d CFRunLoopRunSpecific + 2904
11  com.apple.CoreFoundation        0x9083f188 CFRunLoopRun + 60
12  airport                         0x000043ca 0x1000 + 13258
13  airport                         0x00002956 0x1000 + 6486
14  airport                         0x0000287d 0x1000 + 6269
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x00000001  ebx: 0x908272b4  ecx: 0xbfffec70  edx: 0x91422c9c
  edi: 0x0000000a  esi: 0x00000001  ebp: 0xbfffdfd8  esp: 0xbfffdfb0
   ss: 0x0000001f  efl: 0x00010282  eip: 0x908272b7   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
Daar zit nog een heleboel meer info aan vast, maar ik weet niet hoe nuttig die zal zijn. ;)
Ter background, heb de volgende hints opgevolgd:
http://www.macosxhints.co...hp?story=2004011205473937
  • Reboot, total power-down (uit, powercable verwijderen, batterij eruit) en weer aan
  • Verify disk permissions, paar files repaired
  • Verify disk
  • Heb nog 30GB ruimte op de disk, dus dat zou het ook niet mogen zijn
  • Alle USB rommel eruit, firewirekabels eruit etc. etc.
Wat ik niet heb gedaan:
  • Clear system cache/user cache (geen idee hoe :D)
  • Application enhancer uitzetten (tenzij uitzetten == verwijderen zou ik niet weten hoe, kan wel de progs die het draait uitzetten, maar dat helpt niks)
  • SafeBoot mode opstarten: heb ik helaas nu de tijd niet voor.
  • Reset system firmware, ben ik te huiverig voor op het moment
  • Check the hard drive for bad blocks -> heb ik niet
  • Take out 3rd party RAM -> heb ik niet
  • Opties als: archive and reinstall en dergelijke vind ik het een beetje te vroeg voor
Iemand een vergelijkbaar probleem of een uberhint?
Bericht hierboven
Floris schreef op maandag 19 maart 2007 @ 19:38:Iemand een vergelijkbaar probleem of een uberhint?
Combo update installeren, lost soms vreemde problemen op!
EDIT: Linkje
[ Voor 18% gewijzigd door Verwijderd op 19-03-2007 19:46 ]
  • Daedalus
Daedalus
Moderator Apple Talk
Keep tryin'
Je kunt de 10.4.9 Combo update (Intel) proberen.
Schoonmaken van de system/user cache kan met een programma als OnyX.
Opstarten in de SafeBoot mode doe je door de computer opnieuw op te starten met [shift] totdat je het grijze Apple logo ziet met dat wieltje. Zie ook Mac OS X: Starting up in Safe Mode.
Resetten van de system firmware stelt ook niet zoveel voor. Dit doe je door de computer aan te zetten terwijl je [cmd]+[opt]+[p]+[r] ingedrukt houdt. Deze toetscombinatie moet je ingedrukt houden totdat je voor de tweede keer de 'boing' hoort. Zie ook Resetting your Mac's PRAM and NVRAM
“You know what I've noticed Hobbes? Things don't bug you if you don't think about them. So from now on, I simply won't think about anything I don't like, and I'll be happy all the time!” | 宇多田ヒカル \o/
  • Floor-is
Daedalus schreef op maandag 19 maart 2007 @ 19:49:
Beide: Done, hielp niet :/
Ga ik zo doen, dan update ik weer.
Okay, firmware reset is gelukt. Opstarten duurde hierdoor een stuk langer ;)
Safemode opstarten disabled mijn Airport compleet (kan hem ook niet aanzetten in prefs), dus ik denk dat ik maar weer moet opstarten in "normal mode" om het te testen...
update: Helpt ook niet.
Heb inmiddels mijn modem ook gereset, nog een keer opgestart: weer "Could not connect" terwijl het modem een onbeveiligd WLAN netwerk heeft opgezet. :/
update3:
Inmiddels krijg ik wel een andere foutmelding, hopelijk is het een verbetering ;)
Mar 20 00:06:08 PussyLounge /System/Library/PrivateFrameworks/Apple80211.framework/Resources/airport: Error: WirelessAssociate2() = 88001006 for open network "ZyXEL" after prompt
Mac OS X Version 10.4.9 (Build 8P2137)
2007-03-20 00:08:08 +0100
[ Voor 26% gewijzigd door Floor-is op 20-03-2007 00:09 . Reden: nasty typo, updates ]
Bericht hierboven
  • Daedalus
Daedalus
Keep tryin'
Dat is in ieder geval een verbetering :P
Wat je nog kunt doen: de AirPort voorkeuren (com.apple.airport.preferences.plist) weggooien. Deze vind je onder /Library/Preferences/SystemConfiguration.
Daarnaast kun je in de Systeemvoorkeuren bij Netwerk onder "Toon" kies je Airport. Vervolgens kies je bij "Verbind standaard met" de optie Voorkeursnetwerken. Daarna moet je alle netwerken die daar staan verwijderen. Klik op "Pas nu toe". Hierna kun je "Verbind standaard met" weer terugzetten op wat het eerst stond.
Kijk wat je nu krijgt als je verbinding maakt. Eventueel kun je dat ook via de Terminal doen. Ga daarvoor naar /System/Library/PrivateFrameworks/Apple80211.framework/Resources:
$ cd /System/Library/PrivateFrameworks/Apple80211.framework/Resources
Vervolgens kun je als volgt met een netwerk verbinden:
$ ./airport -A
  • Floor-is
Daedalus schreef op dinsdag 20 maart 2007 @ 11:19:
Het einde der verbetering is in zicht vrees ik. Gisteren uiteindelijk de installCD's erin gepropt en de hele bende opnieuw geinstalleerd (met behoud van useraccounts). Het werkte toen tot mijn notebookje in sleepmode kwam...
Verwijderd en direct geprobeerd, hielp niet. :/
Is helemaal leeg, hoewel ik "automatic" (uiteraard) niet verwijderd krijg.
$ ./airport -A
Dan krijg ik terug:
PussyLounge:/System/Library/PrivateFrameworks/Apple80211.framework/Resources FD
$ ./airport -A
Network Name (SSID):  ZyXEL
En in Console zie ik het volgende:
Mar 20 20:00:10 PussyLounge ./airport: Error: WirelessAssociate() = 88001006 for "<data> 0x5a7958454c".
Ik ga nog eens rebooten, wellicht dat dat helpt. Dadelijk dus weer een update :)
Bericht hierboven
  • Floor-is
Het helpt allemaal dus niet. Ik ben bang dat ik ofwel een programma heb geinstalleerd (cq gedeinstalleerd) dat de boel verknald heeft of dat ik een kapot stuk hardware ergens heb.
Heb zojuist nagenoeg alles gebackupped, weet alleen niet hoe ik bepaalde (geinstalleerde) software kan backuppen... Dus dat ga ik eerst uitzoeken.
UPDATE
Na een redelijk geniale ingeving van CyBeR op IRC eens een ander modem gepakt: werkt gelijk 8)7
[ Voor 14% gewijzigd door Floor-is op 20-03-2007 21:47 ]
Bericht hierboven
  • Daedalus
Daedalus
Keep tryin'
Je wilt toch niet zeggen dat je continue op het verkeerde draadloze netwerk zat :P
  • Floor-is
Nee, ik heb mijn ZyXEL vervangen voor een Speedtouch die ik nog had liggen. :)
Mijn airport crashte ergens op en het lijkt er op dat dit niet was op hetgeen we allemaal dachten: software... Maar op externe hardware die raere signalen aan het afgeven was ofzo :P
Geleerde les: vervang je actieve netwerkcomponenten eens als het uitzichtloos lijkt ;)
[ Voor 62% gewijzigd door Floor-is op 20-03-2007 22:27 ]
Bericht hierboven
  • aem kei
  • Laatst online: 18:17
Ik heb net hetzelfde probleem met mijn macbook pro.
Ik gebruik een Belkin Pre-N router.
Sinds de update 10.4.9 crashed mijn airport zeer vaak.
vermits ik ook een switcher ben heb ik niet zoveel ervaring met Mac :)
Aan de router ligt het alleszinds niet want mijn X-box werkt wel perfect via de router en mijn andere Laptops ook.
een IBM R52 en Packard bell.
Dus het is effectief een probleem met de Mac...
Wie kan me helpen?
Kwestie van een topic te kapen >:)
  • fZeroNewbie
  • Laatst online: 14-08-2024
fZeroNewbie
believe the reggie(revo)lution
kijk eerst ff in je log files (over deze mac -> meer info -> software -> system.log) vaak geeft dit al een richting waar je het probleem moet zoeken.
Komt het probleem alleen voor als je op de accu werkt of ook als ie aan netstroom hangt. Het is namerlijk een irritante gewoonte van de macbook (pro) om de wireless er continu uir te gooien als je op de accu werkt.
aem kei schreef op woensdag 21 maart 2007 @ 20:52:
Wie kan me helpen?
Update deinstalleren misschien..?
  • kaassouffle
  • Laatst online: 17-10 16:14
kaassouffle
Medewerker v/d Maand
info genoeg in dit topic? Wat heb je er al van geprobeerd? wat zijn de uitkomsten?
  • aem kei
fZeroNewbie schreef op donderdag 22 maart 2007 @ 00:25:
Thx voor de hulp...
Het komt inderdaad meer voor op accu dan op netwtroom wel het gebeurd wel...
Ik heb zoals gevraagd het log bestand gelezen en ik moet eerlijk tot mijn schaamte toegeven dat ik er niet zoveel kan van uitmaken...
Dit zag me er wel iets uit om te bekijken dacht ik? maar ik ben dan ook niet zeker... Omwille van de abnormal hangup.
[ Voor 30% gewijzigd door aem kei op 20-01-2021 10:00 ]
  • Wim Leers
  • Laatst online: 10-10 16:49
Misschien OT, maar toch wel relevant denk ik: nadat ik naar 10.4.9 had geüpdatet, had ik veel betere ontvangst dan tevoren. Dit met een MacBook Pro CD (dus 802.11g) en een Linksys WRT54G rev8.
  • aem kei
het spul blijft hier crashen...
super irri probleem dat langs geen enkele kant op te lossen is...
het meest vervelende is dat het enkel dit onderdeeltje is. Alles werkt prima!
behalve mijn Airport :'(
  • BCC
  • Laatst online: 22:02
BCC
Ik heb mijn dezelfde problemen met 10.4.10 en heb een nieuw topic geopend:
BCC in "\[OSX10.4.10] Na update airport crashes"
[ Voor 186% gewijzigd door BCC op 13-07-2007 21:31 ]
Ja ik heb hetzelfde met de macbook. Nooit problemen met WiFi, maar gisteren dus de update gedraaid en vandaag al stuk of 5 crashes gehad. Wat ik ervan op Google zag is dat het optreed als je op de batterij werkt. Als je via de adapter werkt zouden de crashes niet komen. Ik kan dat niet verifeeren. Heb dat nog niet geprobeerd. Ik ga verder trouwens ook niet proberen dit op te lossen. Apple komt wel met een update binnenkort mag ik hopen.
