Probleem met de processor?
  • 45 views sinds 30-01-2008
  • ZeroVince
Het volgende komt uit mijn debug analysis van een minidump:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
Debugging Details:
   NOTE:  This is a hardware error.  This error was reported by the CPU
   via Interrupt 18.  This analysis will provide more information about
   the specific error.  Please contact the manufacturer for additional
   information about this error and troubleshooting assistance.
   This error is documented in the following publication:
      - IA-32 Intel(r) Architecture Software Developer's Manual
        Volume 3: System Programming Guide
   Bit Mask:
       MA                           Model Specific       MCA
    O  ID      Other Information      Error Code     Error Code
   VV  SDP ___________|____________ _______|_______ _______|______
   AEUECRC|                        |               |              |
   LRCNVVC|                        |               |              |
      6         5         4         3         2         1
   3210987654321098765432109876543210987654321098765432109876543210
   1011001000000000000000000100000000000000000000000000100000000000
VAL   - MCi_STATUS register is valid
        Indicates that the information contained within the IA32_MCi_STATUS
        register is valid.  When this flag is set, the processor follows the
        rules given for the OVER flag in the IA32_MCi_STATUS register when
        overwriting previously valid entries.  The processor sets the VAL
        flag and software is responsible for clearing it.
UC    - Error Uncorrected
        Indicates that the processor did not or was not able to correct the
        error condition.  When clear, this flag indicates that the processor
        was able to correct the error condition.
EN    - Error Enabled
        Indicates that the error was enabled by the associated EEj bit of the
        IA32_MCi_CTL register.
PCC   - Processor Context Corrupt
        Indicates that the state of the processor might have been corrupted
        by the error condition detected and that reliable restarting of the
        processor may not be possible.
BUSCONNERR - Bus and Interconnect Error   BUS{LL}_{PP}_{RRRR}_{II}_{T}_err
        These errors match the format 0000 1PPT RRRR IILL
   Concatenated Error Code:
   _VAL_UC_EN_PCC_BUSCONNERR_0
   This error code can be reported back to the manufacturer.
   They may be able to provide additional information based upon
   this error.  All questions regarding STOP 0x9C should be
   directed to the hardware manufacturer.
BUGCHECK_STR:  0x9C_IA32_GenuineIntel
DEFAULT_BUCKET_ID:  DRIVER_FAULT
PROCESS_NAME:  Idle
LAST_CONTROL_TRANSFER:  from 806e7bf7 to 804f9d1b
Betekent dit dat mijn processor een fout veroorzaakt heeft? Of.. .dat software of hardware een fout veroorzaakt heeft die de processor niet op kan lossen? Iemand anders die ernaar gekeken heeft zei dat hij dacht dat het waarschijnlijk een defecte processor, defect moederboard, of defect geheugenmodule betrof.. Dit leek me daarom wel het toepasselijke subforum voor deze vraag! ;)
Met linkjes naar: originele minidump (dmp) & volledige debug analysis (txt)
IA-32 Intel(r) Architecture Software Developer's Manual Volume 3: System Programming Guide
  • Jimbolino
  • Laatst online: 30-09 00:32
Jimbolino
troep.com
ehm,
- wat was je aan het doen,
- wat voor hardware heb je
- wat is je probleem?
ik neem aan dat dit je een bsod kreeg en de minidump daarvan analyseert.
Aangezien ik "DRIVER_FAULT" zie staan, vermoed ik dat je daar eesrst eens naar moet kijken.
Uit een minidump kun je meestal niet concluderen welke hardware/software er kapot is, dit zul je toch echt zelf uit moeten zoeken.
Wat ik uit je crosspost (Wat kan ik opmaken uit deze minidump?) op kan maken, is dat je waarschijnlijk je geheugen eens moet memtesten.
Als je steeds verschillende BSOD's krijgt, kan dat duiden op kapot geheugen (of andere kapotte hardware)
[ Voor 25% gewijzigd door Jimbolino op 09-03-2007 01:20 ]
The two basic principles of Windows system administration:
For minor problems, reboot
For major problems, reinstall
  • Mentalist
  • Laatst online: 28-09 17:25
Mentalist
[avdD]
Waarom crosspost je dit probleem?
Omdat totaal niet duidelijk is of het wel aan PMG zou liggen zou ik dit voortzetten in WOS. Als je hardware (Processor, Moederbord of Geheugen) wilt gaan verwisselen om te testen wat er stuk is en je loopt daarbij tegen problemen aan kan je terugkomen in PMG ;).
Verstuurd vanaf mijn Computer®
