wat zijn dit voor gevalletjes?
  • 288 views sinds 30-01-2008
  • The System
  • Laatst online: 22-09 17:04
wat zijn dit voor dingen?
en kan ik dit als upgrade voor m'n bestaande pc gebruiken?
http://www.arbor.com.tw/sbc/pisa-663-l.jpg
thanx
system
  • shadax
typisch geval van een:
PISA-663Half-size PISA-based Pentium-II CPU Card
with Flat Panel / CRT AGP SVGA, Fast Ethernet and DiskOnChip socket
Description
The PIA-663 is a compact Pentium® -II based single board computer based on Intel's 443BX chipset, allowing processor speeds of up to 500 MHz. Mounted flat on the rear side of the board, the Pentium-II processor occupies only a minimum of space. The high speed Ethernet interface and Chips 69000 Flat Panel display controller make the board is very well suited for high end embedded applications requiring high speed display handling and data transfer.
Ultra DMA HDD support
Ultra DMA doubles the current burst data transfer rate to 33 megabytes (MB) per second. Ultra DMA "widens" the path to the hard drive by transferring twice as much data per clock cycle.
10/100 Mbps Networking
A PCI-based Intel 10BASE-T/100BASE-TX Ethernet controller is optionally included for high speed networking.
Flat Panel SVGA interface
The C&T 69000 Flat Panel / CRT display controller integrates 2 MB high speed SDRAM frame buffer memory, resulting in uncompromised performance and much less power consumption than a standard external memory solution.
DiskOnChip®2000
The PIA-663's SSD socket accommodates a DiskOnChip® 2000, a new generation of high performance single-chip Flash Disks up to 144 MB.
Watchdog Timer
A 6-level Watchdog Timer can invoke an NMI or RESET the CPU when your application loses control over the system.
Specifications
CPU : Intel Pentium-II, 233-450 MHz, slot-1 on backside for flat installation of Pentium-II. 66~100 MHz FSB
Chipset : Intel 82443 BX, 82371 EB (PIIX4E)
BIOS : Y2K compliant AWARD Flash supports NCR SCSI, Green&Soft Off function
Green Function : power saving options supported in BIOS. DOZE / STANDBY / SUSPEND modes, ACPI & APM
Secondary Cache : on Pentium II
DRAM Memory : up to 512 MB of SDRAM in two 168-pin DIM sockets
Bus Interface : PCI and ISA, complies with PICMG standard
Data Bus : 32-bit
Bus Speeds : PCI - 33.3 MHz, ISA - 8.3 MHz,
DMA Controllers : 8237 x 2
DMA Channels : 7
Interrupt Controllers : 8259 x 2
Interrupt Levels : 15
PCI Enhanced IDE with Ultra DMA : supports two ports and up to four hard drives or Enhanced IDE devices. Supports PIO mode 3/4 and Bus-Master. Ultra DMA transfer rates of 33 MB/sec, Multiword DMA Mode 2 transfer
Watchdog Timer : generates a system reset or interrupt when your application loses control over the system. The timer interval is:
1, 2, 10, 20, 110 and 220 seconds .
Real-time Clock : Dallas 12B887 (or compatible)
with lithium battery backup for 10 years of data retention. CMOS data backup of BIOS setup and BIOS default.
Keyboard and Mouse Connectors :
6-pin mini DIN for PS/2 mouse
6-pin mini DIN for PS/2 keyboard
5-pin internal header for AT Keyboard
High Speed Multi I/O
Chipset : Winbond W83977TF-AW
Serial Ports : one external high speed RS-232 port, one internal high speed RS-232/485 port (jumper selectable). Both with 16C550 UART and 16 byte FIFO.
USB : two onboard USB ports (12 Mb/s and 1.5 Mb/s)
SIR Interface : 5-pin IrDA TX/RX header
Floppy Disk Drive Interface : supports up to two floppy drives, 5Œ " (360 KB or 1.2 MB) and 3œ " (720 KB, 1.44 MB or 2.88 MB). BIOS enabled/disabled
Bi-directional Parallel Port : supports SPP, EPP and ECP
Flat Panel/ CRT PCI SVGA Interface
Chipset : C&T 69000 with 2 MB integrated SDRAM
BIOS : combined with system BIOS
Bus : 32-bit PCI local bus
Display : CRT and Flat Panel TFT/DSTN/EL (simult.)
Connectors : 15-pin external connector for CRT monitor and 50-pin internal box header for Flat Panel
10BASE-T / 100BASE-TX Ethernet
Chipset : Intel 82558A
Protocol : IEEE 802.3, IEEE 802.3U
Transfer Rate : high-speed data transfer on the PCI BUS using four DMA channels. Full Duplex 10 BASE-T and 100BASE-TX ,
NWay, Auto-Negotiation capability
Compatibillity : backward compatible with the former 82557 Ethernet controller based net modules
Connector : RJ-45 on bracket
Flash Disk DiskOnChip®2000
Package : Single Chip Flash Disk in 32-pin DIP JEDEC
Capacity : 1-144 MByte
Data Reliability : ECC/EDC error correction
Memory Window : 8 KByte
Environmental and Power
Power Requirements : +5 V (4.75 ~5.25 V) @ 12 A ( 266 MHz CPU),
+12 V @ 20 mA
CPU Power : onboard PWM switching power supply that autodetects CPU core voltage
Board Dimensions : 185 mm x 127 mm
Board Weight : 0.25 Kg.
Operating Temperature: 0 to 55°C
Ordering Information
PIA-663DVL : Half-size PISA-based Pentium-II CPU Card
with Flat Panel /CRT SVGA incl 2 MB SDRAM,
  • The System
dat had ik ook gezien alleen het zegt me niets ;)
  • Kaj.
Kaj.
1 LED is niet genoeg
Dat is een complete computer, weliswaar zonder drives.
Dit soort dingen vind je in kabelkrant-installaties en dergelijke.
Of je zoiets als upgrade kan gebruiken; nee.
Je betaalt er een aardige smak geld voor, en dit soort dingen passen niet in een standaard moederbord.
  • SiGNe
  • Registratie: Juli 1999
  • Laatst online: 18-06 00:01
SiGNe
Ook hoi!
Dit vindt je vaak als Teminal computer.
De programma's staan op terminal servers en die worden via het netwerk in het geheugen van de terminal geladen.
Niet?
[Specs]
  • MNM(tm)
  • Laatst online: 04-09-2025
GAAF DING!!! Is 'tie te koop???
...With a touch of magic¿
