Zeer vaag probleem... voeding?
  • 168 views sinds 30-01-2008
Sorry voor de vage topic omschrijving, maar ik weet amper hoe ik dit moet omschrijven...
Voorts paste ik deze post van een engelstalig forum waar ik eerst heb gepost, hoop dat dit geen probleem is...
So here goes:
It all started some 4 months ago. My PC wouldn't start when I'd press the power button. After some tinkering, I found out (by accident) that it would start if I left the plug out of the socket for some time. Whenever I was done with working on the PC (always late at night), I'd unplug it. In the morning, I'd put the plug back in and it would usually boot.
Now, some time later (couple of weeks, can't remember exactly), the problem got worse. My PC wouldn't even start in the morning. I'd put the plug back in, as usual, hit the power button, and all I'd hear was this little beep (which I always hear, it's a signal that my fan is running too slow (normal, since it's only just starting) and nothing else, system wouldn't start. If I tried to press the power button again--and this is important--I wouldn't even hear that beep.
I tried various things at this stage, and again, mostly by luck, I found out a way to work around this. Whenever I pulled the plug out for a short time (around 10-15 seconds), and then put it back in, it would give me the beep again, and USUALLY, it would boot up fine from there. If it didn't boot, I repeated this a couple of times and it would work. Later on, when I opened up my case, I found out those 10-15 seconds coincide with the time it takes for the little LED-power-Indicator on my motherboard to go out.
Later on (again some weeks, can't remember), it got worse: I would have to try A LOT of times (the pull out the plug for 15 seconds procedure, I mean) before my PC would start.
Some things that COULD be related to this problem:
- Sometimes, after my PC would start, I'd get a message (during boot) that "overclocking was failed" and that I'd have to revert to default settings. (this isn't the exact message, of course).
I have never overclocked anything in my life, so I don't know where this comes from...
- Sometimes, after my PC would start, I'd get a message that I needed to insert proper boot media (you know, that message you see when you forgot to take out a floppy from your drive). So I check my BIOS settings, to find out my boot devices were still in correct order (floppy, harddisk, cdrom drive). But when I checked the hard disk order, they were reversed (I have two hard disks). When I'd switch the order (the one with Windows on it back to the first spot), my PC would boot. So why does my PC sometimes switch the order of my hard disks?
- Sometimes, my PC would shut down during booting, or when just into Windows. If I got through the first 5 minutes in Windows, I'd know I'd be fine. Lately though, my PC just randomly shuts down (this doesn't happen a lot, maybe 6 times during the past few weeks). Again, I do not know if this is related to the problem I describe at the beginning...
So there you have it...
I'll give you my (most important) specs, just in case...
Asus P5P800 motherboard
1024 (2x512) MB of DDR-RAM (PC3200/DDR400)
Intel Pentium IV 550 S775 (3,4 Ghz)
Radeon 9800Pro 128MB (AGP)
Maxtor 160GB Plus 9 S-ATA
some months before I began having these problems, I had my system put into a new case (Nexus Breeze), which includes a Nexus 500W PSU. At the same time, I let them put in another S-ATA disk.
  • TEAMIKKE
Ik zou het toch echt ff vertalen. Na de 2e alinea ben ik al opgehouden omdat het erg vervelend te lezen is zo.
  • Jazzper
  • Laatst online: 01:00
Jazzper
BB4E^Guerilla
3 1e ingevingen
1. RAM gaar?
2. voeding niet goed genoeg (stabiel/zwaar/etc)
3. condensatoren bad, maar dat lijkt me niet bij een nieuw bord
webstek // Urenwerk - horlogeblog // mijn fotogear en beste fotos // Instagram @jazzper_nl
  • Aetje
  • Laatst online: 18-12-2025
Aetje
Troubleshooting met HAMERRR
Denk dat je mobo of PSU een automatische beveiliging in schakelt. Trek alle stekers ns los en plug ze weer in, probeer minimaal te booten (Geen CDRom/floppy enzo). Kijk ook de connectors van je mobo naar de front panel eens na.
Wil dit allemaal niet baten, probeer een andere PSU.
Eventueel ook de CPU-heatsink connectie ns nakijken, eventueel beetje thermal paste invoegen.
[ Voor 14% gewijzigd door Aetje op 28-02-2007 17:40 ]
Forget your fears...
...and want to know more...
Ik vermeld nog even dat ik nu niks meer kan nakijken aan mn PC, hij is nu binnen voor reparatie. Ik post dit om te kijken of het een gekend probleem is (en iemand meteen kan zeggen waar het aan ligt).
Ik meen me te herinneren dat ik tijdens de maanden dat ik dit probleem heb mn RAM eens getest had (Memtest) en dit bleek in orde te zijn.
PC zelf is uit 2004, in juni 2006 heb ik het hele systeem over laten zetten in een Nexus Breeze kast met 500W Nexus voeding... In de winkel dachten ze meteen aan de voeding, maar dit lijkt me toch raar (goed merk, zo nieuw nog...)
Hij is sinds gisteren binnen, ik wacht maar af...
  • M. Mulder
  • Laatst online: 14-10 15:07
M. Mulder
DPC: Team TFC
Je moet ergens beginnen, dus zal ik eerst memtest laten lopen d.m.v. een floppy.
Zijn de testen goed (geen error), dan PC starten met alle kaarten eruit, behalve videokaart of heb je onboard?
Ander videokaart proberen, met nog steeds alles eruit !
Geef feedback als je dit hebt gedaan.
De BIOS even op default settings zetten !!!
MEESTAL IS HET WEL DE VOEDING 8) , OOK ALS IS HET EEN NIEUWE 8)7
[ Voor 9% gewijzigd door M. Mulder op 28-02-2007 17:47 ]
Ik hoop inderdaad dat het de voeding is, daar zit nog garantie op namelijk.
Probleem is wel dat de avond voor de dag dat ik em weg deed het probleem ineens verdwenen was (echt typisch)... Maar ik woon in Belgie en dit was een van de weinige dagen dat ik em naar Nederland kon brengen, dus toch maar weggebracht (had ook nog vantevoren gebeld of het zin had of niet, ze zeiden van wel). Dus in de winkel zien ze nu waarschijnlijk geen symptomen :|
  • dangerpaki
  • Laatst online: 09-10 16:10
volgens mij is gewoon je moederbord gaar
of je voeding kan niet goed aanslaan, hij krijgt niet goed door dat ie moet opstarten ofzo.
  • dion_b
  • Laatst online: 21:44
dion_b
say Baah
This is a Dutch language forum...
Daarnaast hebben we zoiets als een Hangen & Opstarten troubleshooter. Die lijk je niet bepaald volledig doorgenomen te hebben. Begin daar eens mee :o
Oslik, blyat! Oslik!
