[php]sort array (multi dimensies)
  • 100 views sinds 30-01-2008
Hoi ik wil een array sorten. Met array_multisort kom ik er niet echt uit. Ben bang
dat er niet een hele snelle oplossing is en dat ik wat vernuftiger moet gaan aanpakken.
Ik wil dus dat array 0 1 2 3 worden gesorteerd alfabetisch op [company_name]
Deze:
Array (
[0] => Array ( [idprofile] => 59 [nlgb] => 1 [isEnglish] => [company_name] => aaaaa )
[1] => Array ( [idprofile] => 86 [nlgb] => 1 [isEnglish] => [company_name] => dddddd)
[2] => Array ( [idprofile] => 22 [nlgb] => 1 [isEnglish] => [company_name] => bbbbb )
[3] => Array ( [idprofile] => 8 [nlgb] => 1 [isEnglish] => [company_name] => ccccc )
Moet dus deze worden:
Array (
  • crisp
  • Laatst online: 09:01
crisp
Devver
Pixelated
usort()
als je indices belangrijk zijn eventueel uasort()
[ Voor 38% gewijzigd door crisp op 26-02-2007 23:33 ]
Intentionally left blank
Funcie in "comments" werkt:
/ Based on the other notes given before.
// Sorts an array (you know the kind) by key
// and by the comparison operator you prefer.
// Note that instead of most important criteron first, it's
// least important criterion first.
// The default sort order is ascending, and the default sort
// type is strnatcmp.
// function multisort($array[, $key, $order, $type]...)
function multisorteer($array)
for($i = 1; $i < func_num_args(); $i += 3)
$key = func_get_arg($i);
$order = true;
if($i + 1 < func_num_args())
$order = func_get_arg($i + 1);
$type = 0;
if($i + 2 < func_num_args())
$type = func_get_arg($i + 2);
switch($type)
case 1: // Case insensitive natural.
$t = 'strcasenatcmp($a[' . $key . '], $b[' . $key . '])';
break;
case 2: // Numeric.
$t = '$a[' . $key . '] - $b[' . $key . ']';
break;
case 3: // Case sensitive string.
$t = 'strcmp($a[' . $key . '], $b[' . $key . '])';
break;
case 4: // Case insensitive string.
$t = 'strcasecmp($a[' . $key . '], $b[' . $key . '])';
break;
default: // Case sensitive natural.
$t = 'strnatcmp($a[' . $key . '], $b[' . $key . '])';
break;
uasort($array, create_function('$a, $b', 'return ' . ($order ? '' : '-') . '(' . $t . ');'));
return $array;
$vacsArr = multisorteer($vacsArr, "'company_name'", true, 0);
