BSOD tijdens install van ATi Catalyst Control Center
  • Demon_Eyez
  • Laatst online: 27-08 09:19
Mijn probleem:
Tijdens het installeren van Ati Catalyst Control Center 7.1, krijg vlak nadat de install begint een fijne BSOD.
Stop 0x000000F4
CRITICAL_OBJECT_TERMINATION
Dit is wat Microsoft ervan zegt:
SYMPTOMS
A computer that is running Microsoft Windows XP or a later operating system stops responding during resume from standby, and you receive the following KERNEL_DATA_INPAGE_ERROR stop error message:
0x000000F4 (0x00000003, Parameter2, Parameter3, Parameter4)
Note Parameter2, Parameter3, and Parameter4 in the stop error may vary.
This problem occurs on a computer in which Windows XP or a later operating system is installed on a hard disk that is configured as a subordinate and no other device is connected to the same IDE controller channel (primary or secondary).
CAUSE
This behavior may occur when you use Windows XP or a later operating system with some motherboards. Microsoft is researching this problem and will post more information in this article when the information becomes available.
RESOLUTION
To resolve this behavior, use one of the following methods:?
* For Parallel Advanced Technology Attachment (PATA) hard disks, configure your disk drive as master only.
* For Serial Advanced Technology Attachment (SATA) hard disks, connect the hard disk cable to a master channel SATA connector on the motherboard.
* Connect another device as a master, such as another disk drive or a CD drive or DVD drive.
* Change your PATA and SATA IDE cable even if the cable does not appear worn.
* Install Windows on a new hard disk because it is possible that your hard disk or your Windows installation may be corrupted.
Nu treed de BSOD bij mij alleen op zodra ik CCC wil instaleren, voor de rest draait echt heel m'n systeem al een zonnetje. (WinXP staat op IDE1 als master btw)
Ik heb inmiddels al van alles gedaan om die BSOD weg te krijgen, maar het mag niet baten
Wat ik heb geprobeerd:
* Zowiezo eerst alle ATi meuk eraf gegooid een een verse Cat 7.1 install gedaan -> BSOD
* Eerst de losse display driver, toen losse WDM driver en dan als laatste de losse CCC geinstalleerd -> BSOD
* Microsoft .Net Framework 1 , 2 en 3 er af gegooid en opnieuw geinstalleerd -> BSOD
Na een reboot na de BSOD staat CCC 7.1 wel op m'n PC, maar werkt niet.
Als ik die dan wil de-instaleren via Add / Remove programs, dan krijg ik direct weer dezelfde BSOD.
Nog vervelender, ATi CCC 6.12 geeft nu ook dezelfde BSOD. Ik krijg dus geen enkele CCC er meer op.
De display en WDM drivers worden wel perfect geinstalleerd, enkel CCC krijg ik er niet op.
Heeft iemand een oplossing of een soortgelijk iets meegmaakt? Ik snap hier echt niets van. Twee maanden geleden heb ik nog CCC 6.12 geinstalleerd en dat ging vlekkeloos.
Mijn systeeminfo:
WinXP SP2
Ati X1900 XT
DFI CFX3200
Opteron 165
Tijdens de installatie draait m'n systeem op stock snelheid
i7-3770K @ 4800 MHz | 2x4096 G.Skill F3-2400C10D-8GTX @ 2400 MHz | Gigabyte Z77X-UD5H-WB WIFI | Asus HD7950 DCU2 met Swiftech Komodo Ful Cover
  • Demon_Eyez
Thanx allemaal, ben er al uit. :z
Microsoft .Net Framework 3 gooide roet in het eten.
.Net 3 eraf en voila, geen BSOD's meer
