[Ubuntu/Dapper] security.ubuntu.com onbereikbaar
  • 121 views sinds 30-01-2008
  • ERIKvanPAASSEN
  • Laatst online: 20-09-2025
Bij het installeren van bijvoorbeeld apache2 middels apt-get krijg ik een foutmelding:
user@intraserver:~$ sudo apt-get install apache2
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  apache2: Depends: apache2-mpm-worker (= 2.0.55-4ubuntu2) but 2.0.55-4ubuntu2.1 is to be installed or
                    apache2-mpm-prefork (= 2.0.55-4ubuntu2) but it is not going to be installed or
                    apache2-mpm-perchild (= 2.0.55-4ubuntu2) but it is not going to be installed
E: Broken packages
Bij apt-get update:
29
30
31
user@intraserver:~$ sudo apt-get update
Get:1 http://nl.archive.ubuntu.com dapper Release.gpg [189B]
Get:2 http://nl.archive.ubuntu.com dapper-updates Release.gpg [191B]
Get:3 http://nl.archive.ubuntu.com dapper-backports Release.gpg [191B]
Hit http://nl.archive.ubuntu.com dapper Release
Hit http://nl.archive.ubuntu.com dapper-updates Release
Hit http://nl.archive.ubuntu.com dapper-backports Release
Hit http://nl.archive.ubuntu.com dapper/main Packages
Hit http://nl.archive.ubuntu.com dapper/restricted Packages
Hit http://nl.archive.ubuntu.com dapper/main Sources
Hit http://nl.archive.ubuntu.com dapper/restricted Sources
Hit http://nl.archive.ubuntu.com dapper/universe Packages
Hit http://nl.archive.ubuntu.com dapper/universe Sources
Hit http://nl.archive.ubuntu.com dapper-updates/main Packages
Hit http://nl.archive.ubuntu.com dapper-updates/restricted Packages
Hit http://nl.archive.ubuntu.com dapper-updates/main Sources
Hit http://nl.archive.ubuntu.com dapper-updates/restricted Sources
Hit http://nl.archive.ubuntu.com dapper-backports/main Packages
Hit http://nl.archive.ubuntu.com dapper-backports/restricted Packages
Hit http://nl.archive.ubuntu.com dapper-backports/universe Packages
Hit http://nl.archive.ubuntu.com dapper-backports/multiverse Packages
Hit http://nl.archive.ubuntu.com dapper-backports/main Sources
Hit http://nl.archive.ubuntu.com dapper-backports/restricted Sources
Hit http://nl.archive.ubuntu.com dapper-backports/universe Sources
Hit http://nl.archive.ubuntu.com dapper-backports/multiverse Sources
Err http://security.ubuntu.com dapper-security Release.gpg
  Could not connect to security.ubuntu.com:80 (82.211.81.138), connection timed out
Fetched 3B in 2m0s (0B/s)
Failed to fetch http://security.ubuntu.com/ubuntu/dists/dapper-security/Release.gpg  Could not connect to security.ubuntu.com:80 (82.211.81.138), connection timed out
W: Some index files failed to download, they have been ignored, or old ones used instead.
Kan iemand mij vertellen hoe ik dit kan verhelpen? Ik draai Ubuntu Dapper.
  • Jk_W
Jk_W
I Think...
Als je http://security.ubuntu.com in je browser intikt, merk je dat hij idd niet werkt. De server zal wel tijdelijk down zijn.
Onderhoud of een crash. :)
  • ERIKvanPAASSEN
Jk_W schreef op zaterdag 10 februari 2007 @ 14:33:
Ok, dan wacht ik maar even. :P Wel stom dat ik hier zelf niet aan heb gedacht. 8)7
Ik verdacht gelijk m'n eigen server, omdat ik net een verse install had gedaan.
EDIT:
sudo apt-get update is inmiddels gelukt.
Met mijn ene Ubuntu Dapper-bak kan ik wel gewoon downloaden van security.ubuntu.com, maar die andere nog steeds niet dus:
Error http://security.ubuntu.com dapper-security/main apache2-mpm-prefork 2.0.55-4ubuntu2.1
Could not connect to security.ubuntu.com:80 (82.211.81.238), connection timed out
EDIT2:
Maar weer eens m'n DNS-settings nagekeken en wat bleek, die waren teruggesprongen. |:( Zeker de eerste keer op cancel geklikt bij het instellen ofzo. Maar hij doet het nu dus. ;)
[ Voor 63% gewijzigd door ERIKvanPAASSEN op 10-02-2007 15:40 ]
