[Win2003] NTbackup geeft error ffffffff
  • 253 views sinds 30-01-2008
  • calobain
  • Laatst online: 21-10 16:54
Op het werk zitten we met een probleem: er kunnen geen backups meer gemaakt worden van de data-schijf middels NTbackup.
Wanneer dit toch geprobeerd wordt, geeft NTbackup in het report aan:
Backup Status
Operation: Backup
Active backup destination: File
Media name: "BAMBI_31jan07.bkf created 31/01/2007 at 15:09"
Volume shadow copy creation: Attempt 1.
Timeout before function completed
Error returned while creating the volume shadow copy: 0xffffffff.
Error returned while creating the volume shadow copy:ffffffff
Aborting Backup.
The operation did not successfully complete.
En in de Eventlog verschijnen de volgende events:
Event Type: Error
Event Source: VSS
Event Category: None
Event ID: 8193
Date: 01/02/2007
Time: 08:55:45
User: N/A
Computer: BAMBI
Description:
Volume Shadow Copy Service error: Unexpected error calling routine CoCreateInstance. hr = 0x80040154.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 2d 20 43 6f 64 65 3a 20 - Code:
0008: 42 55 45 43 58 4d 4c 43 BUECXMLC
0010: 30 30 30 30 33 32 38 37 00003287
0018: 2d 20 43 61 6c 6c 3a 20 - Call:
0020: 42 55 45 43 58 4d 4c 43 BUECXMLC
0028: 30 30 30 30 37 30 39 36 00007096
0030: 2d 20 50 49 44 3a 20 20 - PID:
0038: 30 30 30 30 35 37 35 32 00005752
0040: 2d 20 54 49 44 3a 20 20 - TID:
0048: 30 30 30 30 32 32 32 34 00002224
0050: 2d 20 43 4d 44 3a 20 20 - CMD:
0058: 76 73 73 61 64 6d 69 6e vssadmin
0060: 20 6c 69 73 74 20 77 72 list wr
0068: 69 74 65 72 73 20 20 20 iters
0070: 2d 20 55 73 65 72 3a 20 - User:
0078: 45 54 45 44 45 5c 61 64 ETEDE\ad
0080: 6d 69 6e 69 73 74 72 61 ministra
0088: 74 6f 72 20 20 20 20 20 tor
0090: 2d 20 53 69 64 3a 20 20 - Sid:
0098: 53 2d 31 2d 35 2d 32 31 S-1-5-21
00a0: 2d 32 33 36 38 32 39 38 -2368298
00a8: 37 30 38 2d 31 36 36 32 708-1662
00b0: 30 30 39 32 34 32 2d 31 009242-1
00b8: 38 37 36 30 33 35 35 38 87603558
00c0: 37 2d 35 30 30 20 20 20 7-500
Event Type: Error
Event Source: VSS
Event ID: 20
Date: 01/02/2007
Time: 08:55:45
User: N/A
Computer: BAMBI
Description:
Volume Shadow Copy Service error: A critical component required by the Volume Shadow Copy service is not registered. This might happened if an error occurred during Windows setup or during installation of a Shadow Copy provider. The error returned from CoCreateInstance on class with CLSID {faf53cc4-bd73-4e36-83f1-2b23f46e513e} and Name VSSEvent is [0x80040154].
Data:
0010: 30 30 30 30 33 32 38 31 00003281
De machine is als volgt:
2x opteron 270 met 8GB ram
2x raptor in mirror voor Windows
4x 250GB in raid 10 welke moeten worden gebackuped naar een systeem van externe hdd's.
Windows 2003 Standard Server x64 als een DC
SQL 2000 server
WSUS
IIS (voor een soort van intrantesite/applicatie)
Een klein CRM pakket, deze maakt gebruik van een eigen instantie van MS SQL.
Wat ik heb geprobeert:
  1. Een aantal uren over het web gezworven en nog geen werkende oplossing tegengekomen.
  2. Hotfix WindowsServer2003-KB903234-x64-ENU.exe en WindowsServer2003-KB891957-x64-ENU.exe geïnstalleerd.
  3. msxml opnieuw geïnstalleerd (t/m v6)
  4. Diverse .dll's opnieuw geregistreerd.
regsvr32 ole32.dll
regsvr32 vss_ps.dll
Vssvc /Register
regsvr32 /i swprv.dll
regsvr32 /i eventcls.dll
regsvr32 es.dll
regsvr32 stdprov.dll
regsvr32 vssui.dll
regsvr32 msxml.dll
regsvr32 msxml3.dll
regsvr32 msxml4.dll
Dit alles heeft nog steeds geen oplossing geboden, daarom vraag ik jullie om wat bruikbare inbreng.
ps. Meld het even als ik wat ben vergeten in de TS.
[ Voor 0% gewijzigd door calobain op 01-02-2007 10:07 . Reden: typo ]
tja gewoon blijven googlen. Die error geeft genoeg terug.
Aangezien je het over een eigen sql instance hebt (je zal wel msde bedoelen), kijk hier ff naar: The Volume Shadow Copy Service cannot create shadow copies on a computer that is running an x64-based version of Windows Server 2003 and a 32-bit version of SQL Server 2000
Het commando waarnaar ze referen is vssadmin list writers
Zoek verder even op die clsid in je registry, met een beetje geluk kan je achterhalen welke writer je mist.
[ Voor 10% gewijzigd door Verwijderd op 01-02-2007 13:01 ]
  • calobain
De hotfix heeft helaas niet het gewenste effect gehad.
En heb nog even verder gezocht op het clsid, maar die komt honderden keren voor in het regeister en kan heel veel zijn :|
het commando vssadmin list writers geeft trouwens helemaal geen output.
  • KatirZan
  • Laatst online: 22-10 17:00
KatirZan
Wandelende orgaanzak
Waarom op een belangrijke server NTBackup gebruiken :?
Als ik jou was zou ik toch naar een ander pakket gaan kijken (wij gebruiken veritas, werkt super ;) )
Verder : probeer NTBackup eerst eens te verwijderen en daarna opnieuw te installeren, dit lost vaak heel wat problemen op ;)
Wabbawabbawabbawabba
  • Gunner
Gunner
Invincibles
KatirZan schreef op vrijdag 02 februari 2007 @ 10:09:
NTbackup is een gestripte versie van Veritias Backup Exec ;)
  • KatirZan
KatirZan
Gunner schreef op vrijdag 02 februari 2007 @ 10:13:
Mja, daar kom ik dus ook net achter, kan wel zien dat het vrijdag is :O
Ach, wij draaien hier Veritas Backup Exec.... meer in te stellen etc...
Maar ik blijf bij mijn oplossing hierboven ;) NTBackup deinstalleren en opnieuw installeren ;)
  • calobain
KatirZan schreef op vrijdag 02 februari 2007 @ 10:17:
Je bedoelt deïnstalleren via de Control Panel --> Add/Remove Programs --> Add/Remove Windows Components? Daar zie ik iig geen NTBackup optie staan. Dus ik neem dan ook aan dat deze niet op die manier weer te installeren is.
Maar goed, ik heb meer het idee dat het iets is in de richting van vss.
Maar waarom zou je een duur programma aanschaffen terwijl NTBackup voldoet?
[ Voor 5% gewijzigd door calobain op 02-02-2007 11:22 ]
