[ADSL] xDSL Linestate down
  • 1.610 views sinds 30-01-2008
  • Pinjataaa
  • Laatst online: 26-10 22:53
Mensen,
Sinds 2 dagen maak ik gebruik van TweakDSL via het BBned netwerk.
Dit was een overstap van KPN 3Mbit naar Tweak 8Mbit.
Nu wordt telkens mijn verbinding verbroken met een melding in de logs: xDSL linestate down.
Ik haal 7Mbit van de 8 omdat ik een +/- 3km van de centrale woon.
Gegevens uit mijn modem (Speedtouch 716 Wireless met firmware 6.1.9.6)
Link Information
Uptime: 0 days, 0:06:38
Modulation: G.992.5 Annex A
Bandwidth (Up/Down) [kbps/kbps]:    1.021 / 6.943
Data Transferred (Sent/Received) [MB/MB]:   41,57 / 158,78
Output Power (Up/Down) [dBm]:   12,0 / 19,0
Line Attenuation (Up/Down) [dB]:    24,0 / 45,5
SN Margin (Up/Down) [dB]:   10,0 / 6,0
Vendor ID (Local/Remote):   TMMB / BDCM
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote):  0 / 0
Loss of Power (Local/Remote):   0 / 0
Loss of Link (Remote):  0
Error Seconds (Local/Remote):   1.391 / 0
FEC Errors (Up/Down):   0 / 0
CRC Errors (Up/Down):   27 / 999
HEC Errors (Up/Down):   133 / 203
En gegevens speedtouch log:
Recorded Events
    Time    Message
Info    01:45:41 (since last boot)  FIREWALL event (1 of 2): enabled rules
Info    01:45:41 (since last boot)  VOIP: Send REGISTER
Info    01:45:41 (since last boot)  xDSL linestate down
Info    01:45:41 (since last boot)  GRP Default destination is not routed anymore via gateway 84.245.10.1
Warning     01:45:41 (since last boot)  DHCC IP address 84.245.10.2 deleted: ok
Info    01:40:24 (since last boot)  UPnP action 'DeletePortMapping' from ip=192.168.1.64 (Success)
Info    01:40:24 (since last boot)  FIREWALL event (1 of 1): deleted rules
Info    01:40:24 (since last boot)  UPnP action 'AddPortMapping' from ip=192.168.1.64 (Success)
Info    01:40:24 (since last boot)  FIREWALL event (1 of 1): created rules
Info    01:39:04 (since last boot)  VOIP: Recv 200 OK
Info    01:39:04 (since last boot)  VOIP: Send REGISTER
Info    01:39:04 (since last boot)  VOIP: Recv 401 Unauthorized
Info    01:39:04 (since last boot)  GRP Default destination is routed via gateway 84.245.10.1
Warning     01:39:04 (since last boot)  DHCC lease ip-address 84.245.10.2 bound to intf Internet
Warning     01:39:04 (since last boot)  DHCC IP address 84.245.10.2 (255.255.255.0) set on intf Internet: ok.
Info    01:39:02 (since last boot)  FIREWALL event (1 of 2): disabled rules
Ligt dit nu 100% zeke aan de kabel of kan het ook aan mijn modem liggen?
Of komt dit doordat mijn internet nog maar net overgeschakeld is?
Op internet kon ik geen duidelijke antwoorden vinden, dus probeer ik het toch maar dmv got :)
Danku!
[ Voor 1% gewijzigd door Pinjataaa op 31-01-2007 20:17 . Reden: Code is wat duidelijker.. ]
  • bjck
  • Laatst online: 03-01 20:09
Pinjataaa schreef op woensdag 31 januari 2007 @ 20:14:
Mensen,
Kan zowel aan je kabel of je modem liggen, maar modem is niet aannemelijk. Laatste firmware er wel in zitten?
Aansluiting van je modem optimaal/netjes en bij de hoofdaansluiting gedaan? Dus geen verleng kabels naar je modem toe, geen aftakkingen voor de splitter etc?
Een onderschrift moet altijd zinvol zijn.
  • Pinjataaa
Bedankt voor je antwoord.
Ik heb de nieuwe firmware geinstalleerd.
Ook zijn alle kabels zo kort mogelijk (niet langer dan 30 cm)..
Ik heb trouwens wel een lichte ruis in mijn telefoonlijn.. mijn vader hoort dit niet maar k hoor het wel goed.
[ Voor 29% gewijzigd door Pinjataaa op 01-02-2007 18:04 ]
  • bjck
Meldt het gewoon aan bij je ISP, wellicht zit er iets niet helemaal lekker op de centrale na de overstap bijvoorbeeld.
  • Pinjataaa
Heb ik gedaan, maar hier krijg je veel eerder antwoord dan van een ISP.
En het zou leuk zijn als ik het zelf (dus sneller) op zou kunnen lossen.
Ik zal wel gewoon even wachten dan :)
  • Murcielago
  • Laatst online: 24-09 00:49
Test ook ff zonder splitter. Misschien is die niet helemaal jofel.
Hoe meld je het bij de ISP dan? Lijkt mij dat als je belt dat dat sneller gaat dan hier wachten op iemand. Tenzij je mailt natuurlijk.
PSN: djmurcielago
  • Hurricane
  • Laatst online: 24-10 15:29
Hurricane
Alles is anders dan het lijkt!
Hieraan te zien zit je echt op de grens van de lijn:
Je mag maximaal 6dB SN Margin hebben om de lijn goed te laten werken. Zit hij daar dus onder (6 of lager) dan word de lijn verbroken en krijg je de bovenstaande foutmelding. Misschien toch eens gaan denken aan een iets tragere lijn. Dan zal hij niet meer zo'n slechte SN Margin hebben en dus niet meer verbreken. Als ik zo na de verdere waardes kijk hierboven dan lijkt het wel dat je verder dan 3 km van de centrale zit. Hoe weet jij dat je op die afstand zit? Volgens de waarden hierboven zit je op zo'n 4km of misschien nog wel iets verder. Maarja dat hoeft niet altijd te kloppen.
  • Pinjataaa
Murcielago schreef op donderdag 01 februari 2007 @ 19:02:
Probeer jij TweakDSL maar aan de lijn te krijgen..
Hurricane schreef op donderdag 01 februari 2007 @ 19:09:
Ik weet niet meer waar ik dit getal weg gehaald heb, maar ik ben er wel zeker van
TweakDSL heeft mij verteld dat deze snelheid te halen was vanaf mijn postcode..... ;(
Kan deze SN Margin ook liggen aan een slechte knooppunt in de meterkast?
Edit: (pcdb.bbned.nl)
Resultaat pcdb.bbned.nl (postcodecheck bbned)
ADSL is beschikbaar.
ADSL2+ is beschikbaar.
Linesharing is beschikbaar.
Dit is een BBned locatie.
Centrale: Ls
De afstand van de locatie tot aan de centrale bedraagt circa 3389 meter.
[ Voor 15% gewijzigd door Pinjataaa op 01-02-2007 20:28 . Reden: Centrale gegevens ]
  • Hurricane
Hurricane
Zou kunnen dat het daar aan ligt. Probeer het modem eens zonder andere dingen ertussen rechtstreeks op de ISRA te zetten met goede kabels en kijk dan nog eens naar de SN Margin.
Zet je DM even aan als je wil.
  • Pinjataaa
Oke, ik heb de splitter weg gehaald.
Nu heb ik de volgende gegevens:
Link Information
Uptime: 0 days, 0:01:03
Bandwidth (Up/Down) [kbps/kbps]: 1.021 / 7.015
Data Transferred (Sent/Received) [KB/KB]: 13,00 / 20,00
Line Attenuation (Up/Down) [dB]: 23,5 / 45,5
SN Margin (Up/Down) [dB]: 10,5 / 6,0
Loss of Signal (Local/Remote): 4 / 0
Error Seconds (Local/Remote): 14.244 / 0
CRC Errors (Up/Down): 98 / 17
HEC Errors (Up/Down): 356 / 9
In 1 minuut al zoveel errors ;(
DM? Wat mag ik daar onder verstaan?
Edit: ik heb nog een probleem gevonden. De telefoon gaat over ookal zit er niets op mijn telefoon lijn!
[ Voor 10% gewijzigd door Pinjataaa op 01-02-2007 21:32 ]
  • bjck
Pinjataaa schreef op donderdag 01 februari 2007 @ 20:47:
Dat is normaal met een analoge lijn.
  • Pinjataaa
Heb nu een ZyXEL prestige 2602R en mn verbinding valt niet meer weg, het draait nu al 4 uur
  • Hurricane
Hurricane
En op welke waardes traint je Zyxel?
  • Pinjataaa
Hurricane schreef op vrijdag 02 februari 2007 @ 17:55:
Ik kan het niet goed uitlezen, lijkt wel of deze modem in 2 minuten in elkaar is gezet.
Je kan niet eens zien hoe snel je verbinding is :p dus ik weet het niet
  • Murcielago
lijkt me duidelijk
PSN: djmurcielago
  • Pinjataaa
Als je goed leest zie je dat dat de waardes zijn van de speedtouch 716 :)
  • Murcielago
Pinjataaa schreef op zaterdag 03 februari 2007 @ 00:47:
My mistake. :+
PSN: djmurcielago
  • Pinjataaa
Waar hij wel om vroeg moet zijn: SN Margin (Up/Down) [dB]: 9,5 / 8,0
Dit geeft hij aan met de Zyxel modem.
  • Hurricane
Hurricane
Je ziet dat de SN Margin nu boven de 6 ligt dus dan blijft je modem in sync. Als de waardes iets slechter worden dan zal hetzelfde gebeuren als met de Speedtouch.
  • Pinjataaa
Maar de up moet toch boven de 10 blijven? Of maakt dat verder niets uit?
  • Pinjataaa
Ik heb een lange tijd geleden gemailt naar TweakDSL.
Ze kwamen (zonder met mij te overleggen) tot de conclusie dat ze mijn verbinding maar 50% langzamer zouden maken.
Ik ontdek opeens dat ik nog maar 4Mbit heb ipv de 8Mbit waar ik voor betaal!!
  • Hurricane
Hurricane
En wat is nu je SN Margin? Waarschijnlijk een stuk beter dan bij 8Mbit.
  • TheJoxer
  • Laatst online: 25-10 09:33
TheJoxer
Nou ja, dat dus....
Wat ik opzich wel vreemd vind is dat jij meld dat de line down gaat. Dat wil dus zeggen een Loss of Line.
Echter is daar in jou Speedtouch stats niks van te zien ..
Ik gok een brak modem.
Tevens vind ik de 45dB Attennuation ook errug veel.
Ik weet op welke afstand je modem staat ten opzichte van je IS/RA punt (hoofdpunt waar je tel lijn binnenkomt).
Daar moet je eens even op gaan testen. Tevens zorgen dat er GEEN aftakkingen naar andere aansluitpunten in je huis gaan VOOR je splitter. (parallelbekabeling).
  • Pinjataaa
Mijn waardes zijn nu:
Link Information
Uptime: 0 days, 8:00:28
Bandwidth (Up/Down) [kbps/kbps]:    1.021 / 4.095
Data Transferred (Sent/Received) [MB/GB]:   568,69 / 12,97
Output Power (Up/Down) [dBm]:   12,0 / 15,0
Line Attenuation (Up/Down) [dB]:    23,5 / 46,5
SN Margin (Up/Down) [dB]:   11,0 / 12,5
Error Seconds (Local/Remote):   1.256 / 0
CRC Errors (Up/Down):   54 / 1.419
HEC Errors (Up/Down):   25 / 649
Maar dan kan ik er toch nog wel 6Mbit uit halen? Dan zal de margin ongeveer op 8 of 9 zitten.
Ik heb mijn IS/RA ingang zelfs opnieuw gesoldeerd en aangesloten. De kabeltjes daavan zijn 10cm. Echt zo kort mogelijk.
Hoe kan ik het beste gaan testen?
Oja dat Loss of Line is ook raar, het modem gooit telkens zijn logs weer leeg als die het signaal is kwijt geraakt.
@ Hurricane: 4Mbit werkt misschien wel beter, maar 50% verlies is wel heel extreem!!!
[ Voor 11% gewijzigd door Pinjataaa op 08-02-2007 00:43 ]
  • Hurricane
Hurricane
Tsja misschien wel maar een continu wegvallende verbinding zou ik ook niet willen. Wat ik wel van je gegevens aflees is dat je op meer de die 3km zit wat je in je eerste post aangeeft. Mail me even als je wilt.
  • Pinjataaa
Oké ik heb een mailtje gestuurd.
Op internet heb ik een formule gevonden waarmee je de afstand kan berekenen.
Dit is Line Attenuation (down) / 13.9 => 46,5/13,9= 3,35KM
  • Rogerrr
  • Laatst online: 06-01-2022
Ik heb ook hetzelfde probleem. Bij mij vliegt de verbinding er ook vaak uit voor een aantal seconden, dan is de DSL verbinding niet meer beschikbaar. Ik heb helaas gekozen voor speedlinq en dan heb je echt helemaal niets aan de helpdesk, dus ik hoop het op deze manier voor elkaar te krijgen. Ik maak gebruik van het KPN abonnement en heb de Speedtouch 706 (incl. VOIP). De modem staat wl een stukje verwijderd van waar de lijn binnenkomt (dit is helemaal beneden, 3 verdiepingen lager, in de meterkast), er zit alleen helemaal niets tussen behalve momenteel de splitter die ik erbij heb gekregen. Hieronder staan een aantal gegevens, ik hoop dat iemand mij verder kan helpen.
29
30
31
32
33
34
35
DSL Connection
Link Information
Uptime: 0 days, 0:07:31
Bandwidth (Up/Down) [kbps/kbps]: 1.029 / 10.789
Data Transferred (Sent/Received) [KB/KB]: 276,00 / 484,00
Output Power (Up/Down) [dBm]: 12,0 / 18,0
Line Attenuation (Up/Down) [dB]: 8,0 / 19,0
SN Margin (Up/Down) [dB]: 12,5 / 8,5
Error Seconds (Local/Remote): 108 / 0
CRC Errors (Up/Down): 66 / 205
HEC Errors (Up/Down): 1.195 / 127
Gebeurtenislog (deze log wordt elke keer gewist zodra er weer een nieuwe connectie is)
29
00:01:00 (since last boot) SNTP No Server(s) configured, check configuration
00:00:48 (since last boot) VOIP: Send REGISTER
00:00:48 (since last boot) xDSL linestate down
00:00:48 (since last boot) GRP Default destination is not routed anymore via gateway 89.220.75.1
00:00:48 (since last boot) DHCC IP address 89.220.75.203 deleted: ok
00:00:45 (since last boot) SNTP No Server(s) configured, check configuration
00:00:30 (since last boot) SNTP No Server(s) configured, check configuration
00:00:27 (since last boot) VOIP: Recv 200 OK
00:00:27 (since last boot) VOIP: Send REGISTER
00:00:27 (since last boot) VOIP: Recv 401 Unauthorized
00:00:27 (since last boot) GRP Default destination is routed via gateway 89.220.75.1
00:00:27 (since last boot) DHCC lease ip-address 89.220.75.203 bound to intf Internet
00:00:27 (since last boot) DHCC IP address 89.220.75.203 (255.255.255.0) set on intf Internet: ok.
00:00:25 (since last boot) FIREWALL event (1 of 1): disabled rules
Alvast bedankt voor de hulp!
  • Murcielago
Wegvallende verbinding? Test eens direct op het isra, mogelijk is je kabel te lang. Vooral nu je er drie verdiepingen vandaan zit.
PSN: djmurcielago
  • Rogerrr
Als het goed is heeft het toch te maken met de SN Margin (Up/Down) [dB]: 12,5 / 8,5? Dan zal ik de modem even beneden aansluiten en dan kijken wat voor een SN Margin (Up/Down) ik daar heb.
Las ook iets over een tool waarmee je de SN Margin kunt aanpassen zodat je modem niet steeds opnieuw wil verbinden, weet iemand hier iets van?
Edit 16:46: Gaat toch moeilijk worden om mijn modem beneden neer te hangen in de meterkast, daar is namelijk geen stopcontact (hoe stom het ook klinkt). Beneden komt alleen alles binnen en dat wordt hierboven pas gesplitst (stroom e.d.). Ik heb nu wel de splitter beneden in de kast zitten en dit heeft dezelfde resultaten als zonder splitter, namelijk:
SN-marge (verzenden/ontvangen) [dB]: 12,0 / 8,5
Het enige wat veranderd is, is dat het verzenden met 0,5 omlaag is gegaan.
[ Voor 42% gewijzigd door Rogerrr op 22-03-2007 16:46 ]
  • Murcielago
Dus net zoveel storing. Maar de afstand die jij probeert te overbruggen wordt niet ondersteund. Probeer eens een verlengsnoer erbij te halen.
PSN: djmurcielago
  • Pinjataaa
Ik heb nu nog steeds dat hij weleens weg wil vallen. Ik ben er eigenljik wel zeker van dat het door mijn modem komt want alle waardes zijn meer dan goed.
Link Information
Uptime: 0 days, 12:44:46
Data Transferred (Sent/Received) [MB/GB]: 72,18 / 1,44
Output Power (Up/Down) [dBm]: 12,0 / 15,5
Line Attenuation (Up/Down) [dB]: 24,0 / 46,5
SN Margin (Up/Down) [dB]: 10,5 / 12,5
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 84.552 / 0
CRC Errors (Up/Down): 1.838 / 2.783
HEC Errors (Up/Down): 1.279 / 1.424
  • Rogerrr
Bij mij werkt hij het laatste anderhalf uur prima, toch raar dat hij elke dag zo tot 14 en 17 moeilijk aan het doen is. Dat is volgens mij nu ook niet echt een piek uur.
Een verlengsnoer erbij pakken wordt ook vrij moeilijk, helemaal niets in de buurt. Maar is de SN waarde juist niet de waarde waarmee je kunt meten of het signaal dat binnenkomt sterk genoeg is? Als dit het geval is scheelt het mij weer het aanschaffen van een enorm lang verlengsnoer.
  • Pinjataaa
Line Attenuation moet je bekijken voor de lengte als ik me niet vergis.
Je woont 19,0 / 13.9 = 1.3 km van de centrale.
Dan heb je echt slechte waardes dus dan ligt het probleem wel in je huis, DENK ik
Ook weer een vraag van mijn kant.
k krijg het gevoel dat hij mijn ip kwijt raakt ofzo, zie log file:
Info 21 days 19:56:27 (since last boot) FIREWALL event (1 of 2): enabled rules
Info 21 days 19:56:27 (since last boot) xDSL linestate down
Info 21 days 19:56:26 (since last boot) GRP Default destination is not routed anymore via gateway 84.245.10.1
Warning 21 days 19:56:26 (since last boot) DHCC IP address 84.245.10.*8 deleted: ok
Info 21 days 19:55:58 (since last boot) UPnP action 'DeletePortMapping' from ip=192.168.1.64 (Success)
Info 21 days 19:55:50 (since last boot) UPnP action 'DeletePortMapping' from ip=192.168.1.64 (Success)
Info 21 days 19:55:50 (since last boot) FIREWALL event (1 of 11): deleted rules
Betekend dit dat ik gewoon mijn signaal verlies of is het echt een fout aan de ISP z;n kant
[ Voor 68% gewijzigd door Pinjataaa op 22-03-2007 21:15 ]
  • Hurricane
Hurricane
Volgens mij betekent dit dat je je modem gereset hebt of dat deze uit zichzelf gereset is 21 dagen geleden.
  • Rogerrr
Ik heb niets meer veranderd in de tussentijd en heb ook nog geen downtime gehad. Hoop dat het probleem opgelost is. Kan het zo zijn dat als een lijn pas net is aangelegd dat hij dan nog instabiel is in het begin? Ik heb deze lijn namelijk pas sinds afgelopen dinsdag.
  • Pinjataaa
Rogerrr schreef op vrijdag 23 maart 2007 @ 17:28:
Lijkt me sterk.
  • Pinjataaa
Voor degene die het interesseerd:
Bij mij was het probleem dat de modem de verbinding verbrak doordat de gateway zijn ip refreshed om de 2 á 3 dagen.
TweakDSL heeft mijn ip adres vastgezet aan mijn modem z'n Mac adres.
Ben benieuwd
[ Voor 3% gewijzigd door Pinjataaa op 27-03-2007 12:06 ]
  • RammY
  • Laatst online: 15:10
RammY
Dát!
Pinjataaa schreef op donderdag 22 maart 2007 @ 18:03:
Link Information
Zei je nou echt goed?
Dacht het niet... das echt veeeeeeel te hoog... lange bekabeling als ik het zo zie!
Tevens erg erg erg veel lokale errors (Error Seconds) over CRC en HEC maar niet te spreken.
En dat over een uptime van 12 uur :|
Ga es heeeel snel je bekabeling nakijken!
Deze advertentieplaats is te huur!
  • Pinjataaa
Dat is de afstand tussen mijn huis en de centrale. Ik zit op 3,4 KM
Dat is een normale waarde voor die afstand.
Mijn uptime ga ik nu bekijken, mijn ip is nu vast gezet.
Eerder had k telkens een uptime van max 3 dagen. Dat is ook de release tijd van de gateway
[ Voor 40% gewijzigd door Pinjataaa op 27-03-2007 17:59 ]
  • Rogerrr
Actief: 13 dagen, 15:04:06
Bij mij doet hij het tegenwoordig perfect. Heb niets aangepast, waren waarschijnlijk toch kinderziektes. Bedankt voor de hulp.
