Trends usb Dac UD-10 of toch bij mijn Audigy II blijven ?
  • 199 views sinds 30-01-2008
Beste forumleden,
Ik kwam op het htforum een reply tegen van iemand die een Trends dac had aangeschaft en hij was hier zeer tevreden over. Aangezien ik zelf niet megatevreden ben over de dac van mijn Audigy II ben ik mij gaan afvragen of het geluid beter zou worden als ik de Audigy eruit zou gooien.
de dac
Afbeeldingslocatie: http://www.xs4all.nl/~abongers/ud-10front.jpg
Afbeeldingslocatie: http://www.xs4all.nl/~abongers/ud-10back.jpg
Afbeeldingslocatie: http://www.xs4all.nl/~abongers/ud-10inside.jpg
[Description]
There are more and more good quality audio DACs newly released. But, a good audio source is still difficult to find. Trends Audio developed an USB Audio Converter UD-10, which works as an external sound card with various formats of digital output and decoded headphone output. It effectively isolated the serious interference from the noise within the PC case, e.g. the high frequency data signals, the switching-mode power supply and the FAN motors, etc¡K.
On the other hand, UD-10 upgrades your PC to be a hi-end audio source. Thanks to the good power supply handling, the high accuracy clock and the sophisticated digital output circuit, UD-10 makes your PC to behave as a high-end CD transport to work with an external DAC. Yet, the UD-10 and PC couple provides better sound quality, larger storage capacity and more user-friendly interfaces than a CD transport. (Remarks: computer hard disk is far more better than a CD pickup mechanism no matter in speed, stability, error correction, jitter reduction. They are actually the technology of different eras.)
[Features]
In the front panel, there are the USB socket and the headphone socket (can convert to a pair of RCA audio output with the bundled adaptor). The back panel is mainly the digital outputs (optical x1, coaxial x2 (RCA & BNC), AES/EBU x1) and the external power supply socket.
- high-end Burr Brown PCM2704 IC for USB audio conversion
- proprietary dual power regulation circuits design (normal implementations are just directly apply the 5V USB bus power). No matter the power is supplied from the USB bus or from external socket, it is regulated before supply to the related ICs. Dual regulated powers are supplied to digital circuits and analog circuits individually.
- separated digital/analog ground. The digital GND (network) and the analog GND (solid) is totally separated except connected via a ferrite bread in a single point. It effectively reduce interference between digital signals and analog signals.
- Option to use USB bus power [convenient] or external power [better sound] (e.g. AA size rechargeable battery 1.2V x4=5V, don't use normal batteries with 1.2V x4=6V, it would be too high for safety and good sound performance)
- 4pins high accuracy crystal clock (±10ppm)
- applied RS422 driving IC to concurrently drive 4 groups of balance & non-balance digital outputs. Audiophiles can compare the differences between these digital outputs instantly or play for the Bi-DACs or even Quad DACs.
- proprietary impedance matching circuits for AES/EBU(110ohm), Coaxial(75ohm) digital outputs
- applied the specially designed pulse transformers for each AES/EBU and Coaxial outputs to further isolated interference from UD-10 to the external DAC. The most pure, accurate, standard digital signal is then regenerated with minimum interference and jitter.
- plug-and-play without driver installation for most PC operating systems, e.g. Windows 2000, Windows XP, etc…
We applied audiophile grade materials and electronic components, including the high-quality Japanese/Korean precise SMD resistors and capacitors. Besides reducing the space, it also reduces the resident inductance (relative to DIP components). The power filtering and decoupling is using Sanyo OS-CON solid-state electrolyte capacitors. The analog signal decoupling and coupling are using ELNA Silmic electrolyte capacitors and WIMA MKP10 film capacitors…. The case of the device is the stylish iron-gray whole aluminium one.
http://www.trendsaudio.com/EN/Product/USB_Audio_feature.htm
nou was de vraag eigenlijk of er nog meer mensen zijn die ervaring hebben met deze dac en of hij beter presteerd als de Audigy II (ik ben van plan om hem analoog aan te sluiten)
  • sphere
  • Laatst online: 12:32
sphere
Debian abuser
Volgens mij is de ideale PC audio opzet USB naar AES naar DAC naar versterker (liefst balanced). De persoon die die dac heeft gebruikt hem alleen voor transport en niet het analoge gedeelte als ik het goed heb gelezen, maar de DAC van zijn Lyngdorf.
http://stackoverflow.com/questions/1732348/regex-match-open-tags-except-xhtml-self-contained-tags/1732454#1732454
dat klopt idd maar vanwege de mogelijkheden om het apparaatje zelf ook als dac te gebruiken ben ik mij dus af gaan vragen of dat voor mij verbeteringen kan opleveren tov de Audigy II
er zitten tevens ook erg goede chips in zoals de Burr Brown PCM2704 IC
ik had hier ook nog een review van iemand gevonden die hem ook daadwerkelijk als geluidskaart gebruikte maar het zou mooi zijn als iemand met beide kaarten ervaring had
http://www.tnt-audio.com/sorgenti/trendsaudio_ud10_e.html
  • sphere
sphere
Debian abuser
Als je nu de analoge uitgangen gebruikt van de audigy denk ik dat je wel eens last kan hebben van piepjes als je harddisk wat doet? Dat heb ik in ieder geval wel (among other things ;)) en ik -denk- dat als je de muziek digitaal naar buiten duwt dat "piepjes" probleem er niet meer is.
  • sebastius
  • Laatst online: 06-10 22:18
sebastius
Laten we lekker link gaan doen
De PCM2704? Dat is een leuk chipje maar niet speciaal High End hoor :) Denk niet dat je een verschil met je Audigy gaat horen, op eventueel genoemde storingen na, die raak je grotendeels kwijt dacht ik.
Zelfbouw USB Soundcard (met de PCM2707) < ik heb op basis van het broertje (de PCM2707 is identiek aan de 2704 op een aansluiting voor een EEprom na) zelf een USB DAC gemaakt :) Kosten? 10 euro ongeveer :)
[ Voor 9% gewijzigd door sebastius op 31-01-2007 20:57 ]
dat zelfbouwen is een leuk maar alleen niet echt aan mij besteed aangezien mijn soldeer skills niet echt super zijn
@ Sphere
Ik heb idd wel eens last gehad van piepjes maar dit kwam met name door de magnetische golven van mijn vga. Het plaatsen van de geluidskaart in een ander slot verhielp dit probleem gelukkig :)
Maar meestal denk ik toch dat het aan mijn huidige geluidskaart ligt. Ik brand namelijk wel eens een mp3 cd die beter klinkt als ik hem via mijn cd speler afspeel dan via de pc ondanks dat het precies dezelfde bestanden zijn.
  • voodooless
  • Laatst online: 19:49
voodooless
Sound is no voodoo!
Ik heb zelf ook een klein geluidskaartje met zo'n BB usb chipje, in dit geval de PCM2606. Ik kan niet zeggen dat ik daar zo waanzinnig kapot van ben. Ik gebruikte hem eigenlijk ook enkel en alleen om wat dingen mee te meten.
Maar beats audigy I guess... Heel veel ligt ook aan de uitvoering van het spul eromheen. Trends doet dat zo te zien erg netjes :) Maar er zijn nog zoveel USB geluidskaarten, er is dus keuze zat.
[ Voor 8% gewijzigd door voodooless op 31-01-2007 21:35 ]
Do diamonds shine on the dark side of the moon :?
/me vindt dat binnenwerk er wel heel strak uitzien. Creative, M-Audio en Terratec kunnen daar een puntje aan zuigen...
  • sebastius
sebastius
Dat is inderdaad wél zo. Tis een simpel chipje maar ze hebben het systeem wel heel keurig ingericht.
Ik heb ook een interne audigy en ben daar niet over te spreken. Een CD speler van beetje kwaliteit klinkt al vele malen beter. Heb het ook aan mn versterker hangen.
Ik heb hem aangeschaft voor 90 euro op hifi.nl
Als het meezit zaterdag as binnen.
EDIT: Hij staat hier nu heerlijk te spelen, met de ASIO drivers en FooBar2000 is het echt een grote stap voowaards in vergelijking met de Audigy.
Ik ben er erg blij mee :D
[ Voor 26% gewijzigd door Verwijderd op 05-08-2007 13:13 ]
