Error met branden HP9100. Log included.
  • 141 views sinds 30-01-2008
Ik fik me'n cd's met Nero.. Nou komt hij bij het afsluiten van de cd met een 'scsi target error'. Ik vroeg me af of iemand hier ervaring mee heeft en toevallig weet wat het is..
Ik heb een searchgotje gedaan maar kon de oplossing er niet vinden :(
Nero logfile:
Windows 98 4.90
WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 8-6-2000 17:00:00
ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2, 0, 0, 11, size=143427 bytes, created 5-4-2000 17:09:38
Nero Version: 5.0.1.3
Recorder: <HP CD-Writer+ 9100> Version: 1.0a - HA 0 TA 0 - 5.0.1.3
Adapter driver: <ESDI_506> HA 0
Drive buffer : 4096kB
CD-ROM: <HP CD-Writer+ 9100>Version: 1.0a - HA 0 TA 0 - 5.0.1.3
HP CD-Writer+ 9100 (Target 0, E :): Autoinsert Off, DMA On, Disconnect On, SyncDataXfer Off
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261632kB)
Free physical memory: 0MB (40kB)
Memory in use : 67 %
Uncached PFiles: 0xFC
Wizard: On
CD-ROM (ISO)
11.7.2000
18:48:24 #1 Text 0 File BusArbiter.cpp, Line 84
bus arbitration: bus type category
SCSI 0
unknown 1
other 2
IDE 3
drives from category 1 and 3 competition level 1
stall writers at 95%, reactivate at 70%
18:48:24 #2 Text 0 File Reader.cpp, Line 75
Reader running
18:48:24 #3 Text 0 File Writer.cpp, Line 101
Writer HP CD-Writer+ 9100 running
18:48:24 #4 Text 0 File BusArbiter.cpp, Line 827
Tue Jul 11 18:48:24 2000
HP CD-Writer+ 9100: Register
arbitration enabled
n. category bus drive writer name
0. 3 0 0 yes HP CD-Writer+ 9100
i
r
18:48:24 #5 ISO9660GEN -11 File geniso.cpp, Line 3236
First writeable address = 0 (0x00000000)
18:48:24 #6 Text 0 File ThreadedTransferInterface.cpp, Line 636
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 295997 (295997) = #295997
relocatable, CD pos for caching/writing not required/required, no patch infos
18:48:28 #7 Text 0 File Burncd.cpp, Line 1443
Recorder: HP CD-Writer+ 9100; CDR code: 00 97 26 60; CDR manufacturer: CMC Magnetics Corporation
18:48:28 #8 Text 0 File ThreadedTransferInterface.cpp, Line 768
Prepare recorder HP CD-Writer+ 9100 for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 606509056
18:48:28 #9 Text 0 File ThreadedTransferInterface.cpp, Line 636
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 295995 blocks [HP CD-Writer+ 9100]
18:48:28 #10 Phase 24 File dlgbrnst.cpp, Line 1147
Start of caching files
18:48:28 #11 Phase 25 File dlgbrnst.cpp, Line 1147
Caching files completed
18:48:28 #12 Phase 36 File dlgbrnst.cpp, Line 1147
Start of burnprocess at 6x (900 KB/s)
18:48:28 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1683
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
18:48:29 #14 Text 0 File BusArbiter.cpp, Line 827
Tue Jul 11 18:48:29 2000
READ: Register
arbitration enabled
1. 1 -1 -1 no READ
i i
r r
19:04:56 #15 Text 0 File ThreadedTransfer.cpp, Line 211
all writers idle, stopping conversion
19:05:04 #16 SCSI -400 File Cdrdrv.cpp, Line 1118
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x071EFDDC
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x52 0x01 0x00 0x00 0x00 0x01 0x00 0x00 0x1C 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x00 0x00
19:05:04 #17 SCSI -400 File Cdrdrv.cpp, Line 1118
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x04540F30
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x5A 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x40 0x00 0x00 0x00
19:05:04 #18 SCSI -400 File Cdrdrv.cpp, Line 1118
Sense Code: 0x00
Sense Qual: 0x00
19:05:04 #19 CDR -400 File ThreadedTransferInterface.cpp, Line 1398
SCSI Target error
19:05:04 #20 TRANSFER -40 File ThreadedTransferInterface.cpp, Line 1398
Could not perform EndDisk
19:05:04 #21 Phase 38 File dlgbrnst.cpp, Line 1147
Burnprocess failed at 6x (900 KB/s)
19:05:04 #22 Text 0 File Scsicmd.cpp, Line 260
SCSI not using temporary buffers
19:05:04 #23 Text 0 File Scsicmd.cpp, Line 283
10 out of 10 temporary buffers allocated
19:05:04 #24 Text 0 File WinNeroThreads.cpp, Line 909
Thread priorities:
Pri. name -> class / level
0. Idle -> 32 / -15 = default
1. Background -> 32 / -2 = default
2. Normal -> 32 / 0 = default
3. HighIdle -> 128 / -1 = default
4. High -> 128 / 0 = default
5. Higher -> 128 / 1 = default
6. Realtime -> 128 / 2 = default
19:05:05 #25 SCSI -400 File Cdrdrv.cpp, Line 1118
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
19:05:05 #26 SCSI -400 File Cdrdrv.cpp, Line 1118
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x1B 0x01 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00
19:05:05 #27 CDR -400 File Burncd.cpp, Line 1052
SCSI Target error
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 8-6-2000 17:00:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 8, size=30887 bytes, created 1-7-2000 10:29:46<B
  • Rashann
  • Laatst online: 24-08 07:20
Rashann
Zoek de hond...
EEN KEER POSTEN IS GENOEG!!!
Sorry dat ik schreeuw, maar 3
oh nee, 4
posts is toch echt teveel...
En helaas weet ik geen antwoord...
If nothing is written below, I was the last to reply...
del *.post
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Sheetje.. je zou maar een keer een foutje maken zeg..
zet de dma eens uit. niet nodig bij een brander
Maakte geen verschil... Ik las iets over het feit dat Nero raar gaat doen mocht hij de serial key niet slikken ? Ik heb een keygen gebruikt en dit viel me op:
Dit staat ergens tussen de log.. Of heeft het heel ergens anders mee te maken ? Verder ben ik benieuwd of iemand de fout kan ontdekken via de log !
Nieuwste Aspi drivers ff installeren zou het moeten verhelpen denk ik
Nog klein vraagje.. Waar kan ik nieuwere vinden ?
