[steam] Call of Duty 2 start niet op
  • 209 views sinds 30-01-2008
Specs:
amd x2-3800+
gb k8n-sli
2gb ram
gb 6800gs
Bij het opstarten van cod2 sp krijg ik de volgende melding:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
CoD2 1.2 build win-x86 Mar 30 2006
----- FS_Startup -----
Current language: english
Current search path:
d:\program files\steam\steamapps\common\call of duty 2\main\iw_15.iwd (85 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_14.iwd (4038 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_13.iwd (22624 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_12.iwd (1016 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_11.iwd (1462 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_10.iwd (1936 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_09.iwd (2142 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_08.iwd (2723 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_07.iwd (3384 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_06.iwd (990 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_05.iwd (928 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_04.iwd (698 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_03.iwd (26 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_02.iwd (40 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_01.iwd (16 files)
d:\program files\steam\steamapps\common\call of duty 2\main\iw_00.iwd (102 files)
d:\program files\steam\steamapps\common\call of duty 2/main
d:\program files\steam\steamapps\common\call of duty 2/raw
d:\program files\steam\steamapps\common\call of duty 2/raw_shared
d:\program files\steam\steamapps\common\call of duty 2/devraw
d:\program files\steam\steamapps\common\call of duty 2/devraw_shared
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw11.iwd (1 files)
    localized assets iwd file for english
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw10.iwd (414 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw09.iwd (98 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw08.iwd (8 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw07.iwd (1014 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw06.iwd (3110 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw05.iwd (5310 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw04.iwd (6240 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw03.iwd (6580 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw02.iwd (6404 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw01.iwd (5510 files)
d:\program files\steam\steamapps\common\call of duty 2\main\localized_english_iw00.iwd (4764 files)
File Handles:
81663 files in iwd files
execing default.cfg
couldn't exec language.cfg
========= autoconfigure
configure.csv: using CPU configuration 2 GHz 512 MB
execing configure.cfg
configure.csv: using GPU configuration "GeForce 68*"
Measured CPU speed is 2.01 GHz
System memory is 1024 MB (capped at 1 GB)
Video card is "NVIDIA GeForce 6800 GS "
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
Trying SMP acceleration...
...succeeded.
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 3.0
Vertex shader version is 3.0
Direct3D 7 code path is available.
Direct3D 9 code path is available.
Using Direct3D 9 code path because it is the best available path on this hardware.
Attempting 800 x 600 fullscreen with 32 bpp at 60 hz
Game window successfully created.
Creating Direct3D device...
Com_TouchMemory: 0 msec. Using sum: 0
Initializing render targets...
Requested frame buffer to be 24-bit color with 8-bit alpha
DirectX returned a frame buffer that is 24-bit color with 8-bit alpha
Initializing static model cache...
Initializing dynamic buffers...
Initializing particle cloud buffer...
Creating Direct3D queries...
Setting initial state...
DirectX reports 256 MB of video memory and 555 MB of available texture memory.
Using video memory size to cap used texture memory at 240 MB.
Texture detail is set automatically.
Using picmip 0 on most textures, 0 on normal maps, and 1 on specular maps
ERROR: Couldn't open techniqueSet 'materials/techniquesets/ j" j".techset'
Error during initialization:
couldn't load material '$default'
Ik heb het spel al verwijderd en opnieuw gedownload van steam maar dit helpt niet. Ook de laatste nvidia drivers erop gezet. Steam opnieuw erop zetten heeft ook geen zin.
Is iemand bekend met deze foutmelding?
  • Pubbert
  • Laatst online: 15-10 08:16
Pubbert
random gestoord
Daar gaat het mis, het lijkt er toch op dat hij hem niet compleet gedownload heeft.
Thund3r schreef op vrijdag 19 januari 2007 @ 11:49:
hmm ok ik zal hem nog eens verwijderen en opnieuw downloaden, ik heb maar een 3,1mbit verbinding dus gaat weer even duren :o
  • Dutchmega
Properties van game -> Local files -> Verify integrity
Waarschijnlijk gaat Steam dan niet alles opnieuw downloaden
  • sjongenelen
  • Laatst online: 15-10 16:47
welke servers speel je op? :p
you had me at EHLO
Dutchmega schreef op vrijdag 19 januari 2007 @ 12:13:
ja download hem nu al opnieuw, mocht het dan weer niet werken dan probeer ik dit thx :)
grapjas, wat dacht je van geen een zover? :P
na weer opnieuw downloaden werkt de game nu helemaal goed :)
