Cisco WLAN Controller - clear config error
  • 290 views sinds 30-01-2008
  • witchdoc
  • Laatst online: 09-10 13:20
Ok, probleempje.. Bezig met configuratie van een Cisco Wireless Lan Controller 2006.
Helaas verkeerde ip adressen en dergelijke gebruikt dus even opnieuw. Ik dacht even snel de config te deleten zodat'k de installation wizard weer kon doorlopen.. Helaas zit'k nu vast in een loop.
Iemand een idee hoe'k dit opgelost krijg?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
(Cisco Controller) >
    Cisco Bootloader (Version 4.0.179.11)
                      .o88b. d888888b .d8888.  .o88b.  .d88b.
                     d8P  Y8   `88'   88'  YP d8P  Y8 .8P  Y8.
                     8P         88    `8bo.   8P      88    88
                     8b         88      `Y8b. 8b      88    88
                     Y8b  d8   .88.   db   8D Y8b  d8 `8b  d8'
                      `Y88P' Y888888P `8888Y'  `Y88P'  `Y88P'
                                   Model AIR-WLC2006-K9   S/N: FTX1051802J
Booting Primary Image...
Press <ESC> now for additional boot options...
    Boot Options
Please choose an option from below:
 1. Run primary image (Version 4.0.179.11) (active)
 2. Run backup image  (Version 4.0.179.11)
 3. Manually upgrade primary image
 4. Change active boot image
 5. Clear Configuration
Please enter your choice: 5
    Boot Options
Detecting hardware . . . .
Clearing system configuration: done.
Configuration has been cleared.  Restarting...
Generating Secure Shell DSA Host Key ...
Generating Secure Shell RSA Host Key ...
Generating Secure Shell version 1.5 RSA Host Key ...
Cisco is a trademark of Cisco Systems, Inc.
Software Copyright Cisco Systems, Inc. All rights reserved.
Cisco AireOS Version 4.0.179.11
Initializing OS Services: Failed to open /mnt/application/eeprom.dat.
Cisco Crash Handler
This build was configured to copy this crash information to
  a file called: "/mnt/application/mwar_dump1.crash"
Laatste boot replies (failed to open, crash handler) blijft ie dus herhalen. Booten vanaf image 1 of 2 maakt niet uit. Nogmaals menu keuze 5 helpt evenmin als powercyclen van de unit.
  • Question Mark
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Field Notice: FN - 62555 - Clear Configuration Boot Menu Option 5 on Cisco Wireless LAN Controller 2006 Corrupts Image
Problem Description
Customers should not choose the clear config (option 5) from the boot menu on controllers running 3.2.78.0, 3.2.116.21, 3.2.150.6 or 3.2.150.10, 3.2.171.5 or 3.2.171.6, 4.0.155.5 or 4.0.179.8 and 4.0.179.11.
Background
Due to bug CSCsg18356 in clear config code, the eeprom.dat file does not get backed up and is deleted during clear config. This is the file which holds serial number, Mac Address and other manufacture information related to the box. Without this file, the WLC2006 controller cannot bootup and the unit has to be RMA'd.
  • TrailBlazer
  • Laatst online: 21-10 10:00
TrailBlazer
Karnemelk FTW
die had je snel gevonden knap waardeloos dat ze dit nooit getest hebben.
  • witchdoc
TrailBlazer schreef op woensdag 17 januari 2007 @ 10:17:
lekker nuttig ook dat dit niet in de release notes staat :(
Ook wel "raar" (lees: ongehoord schandalig) dat zowel de primary als de secundary IMAGES corrupt raken door het clearen van een CONFIG.
question mark, knap gevonden, zit al een half uur te googlen zonder resultaat. Mag'k vragen hoe je die info precies hebt gevonden?
Edit: nu'k er even bij stilstaat.. best logisch dat het niet bij de release notes van de betreffende versie staat.. toen hadden ze't nog niet ontdekt. Bij de volgende releasenotes staat't gewoon bij zie'k nu.
[ Voor 26% gewijzigd door witchdoc op 17-01-2007 10:32 ]
  • TrailBlazer
TrailBlazer
Karnemelk FTW
zoeken op cisco.com op je serienummer
http://www.cisco.com/pcgi...co.com=cisco.com&x=16&y=8
1e hit is jouw probleem ongeveer 5 seconden :p
