BSOD, winxp, debugging report
Goedemiddag,
WinXP sp2
CPU: Int pent 4 2,4 Ghz
Graph: Nvidia Gforce4 MX 440 with AGP8X
RAM: 256MB
Ik heb een die om de zoveel vast loopt.
Daarnaast piept het soms een keer of drie rijdens opstarten (videokaart ?)
Ik heb een debuggingtool report bijgevoegd, maar weet niet zo goed wat ik hier nu uit lezen moet.
Mijn gevoel zegt me dat het of het geheugen of de videokaart is (??)
Wie kan en wil me verder helpen ?
TIA
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini011007-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: C:\WINDOWS\Symbols
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420
Debug session time: Wed Jan 10 20:38:22.625 2007 (GMT+1)
System Uptime: 0 days 0:43:28.218
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000000A, {10888240, 2, 1, 804e5010}
Unable to load image Fastfat.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for Fastfat.sys
Probably caused by : ntoskrnl.exe ( nt!KeSetEventBoostPriority+34 )
Followup: MachineOwner
kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 10888240, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 804e5010, address which referenced memory
Debugging Details:
WRITE_ADDRESS: 10888240
CURRENT_IRQL: 2
FAULTING_IP:
804e5010 897204 mov dword ptr [edx+4],esi
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: WMIPRVSE.EXE
LAST_CONTROL_TRANSFER: from 8058c67d to 804e5010
STACK_TEXT:
f9af0a84 8058c67d 82298250 00ff0000 ffdff120 nt!KeSetEventBoostPriority+0x34
f9af0b14 f9789e98 82298250 f9af0b94 00000000 nt!SeQueryInformationToken+0x3e9
f9af0be4 f978469a 821add48 ffa3b260 ff9c4230 Fastfat!FatCommonRead+0x597
f9af0c54 804e37f7 82382c30 ffa3b260 8232f780 Fastfat!FatFsdRead+0x13d
f9af0c54 00000000 82382c30 ffa3b260 8232f780 nt!KeUpdateSystemTime+0xba
WARNING: Frame IP not in any known module. Following frames may be wrong.
00000000 00000000 00000000 00000000 00000000 0x0
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!KeSetEventBoostPriority+34
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntoskrnl.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 42250ff9
FAILURE_BUCKET_ID: 0xA_W_nt!KeSetEventBoostPriority+34
Aantal pieps is wel belangrijk, is nl een foutcode. 3 voor memory waarschijnlijk. Even een tijdje memtest86 draaien, memory sticks per stuk testen bij meerdere.
http://www.pchell.com/hardware/beepcodes.shtml
