[vhdl] fout: "Illegal sequential statement."
  • 131 views sinds 30-01-2008
  • hanneshoffie
  • Laatst online: 19-05-2022
ik heb 2 files:
-- dflipflop.vhd --
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY dflipflop IS
    PORT(RESET: IN std_logic;
         D: IN std_logic;
         CLK: IN std_logic;
         Q:OUT std_logic);
END dflipflop;
ARCHITECTURE dfliparch OF dflipflop IS
BEGIN
 process(RESET,CLK)
 begin
  if RESET= '1' then
    Q <= '0';
  elsif rising_edge(CLK) then
    Q <= D;
  end if;
 end process;
END dfliparch;
-- configflip.vhd
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
LIBRARY ieee;
ENTITY configflip IS
    PORT(R:IN std_logic;
         S:IN std_logic_vector(1 downto 0);
         D:IN std_logic_vector(1 downto 0);
         CLK: IN std_logic;
         Q:OUT std_logic);
END configflip;
ARCHITECTURE fliparch OF configflip IS
signal d_out,d_in,qx,qi: std_logic;
BEGIN
 process (S)
  BEGIN
case S is
-- d-flipflop
when "00" =>
n1: ENTITY work.dflipflop(dfliparch) PORT MAP(R,D(0),CLK,qx);
Q <= qx;
-- t-flipflop
when "01" =>
qi <= D(0) XOR d_out AFTER 5 ns;
n2 : ENTITY work.dflipflop(dfliparch) PORT MAP(R,d_in,d_out);
Q <= d_out;
-- de-flipflop
when "10" =>
n3: ENTITY work.dflipflop(dfliparch) PORT MAP(R,D(0),qx);
if D(1) = '1' then
   Q <= qx;
else
   Q <= '0';
end if;
-- jk-flipflop
when "11" =>
d_in := (NOT(D(0)) AND d_out) OR (D(1) AND (NOT(d_out)));
n4: ENTITY work.dflipflop(dfliparch) PORT MAP(R,d_in,d_out);
Q <= d_out;
when others =>
Q <= '0';
end case;
 END process;
END fliparch;
ModelSIM wordt gebruikt als compiler.
deze meldingen worden gegenereerd:
# ** Error: H:/computerorganisatie/work/configflip.vhd(24): Illegal sequential statement.
# ** Error: H:/computerorganisatie/work/configflip.vhd(30): Illegal sequential statement.
# ** Error: H:/computerorganisatie/work/configflip.vhd(35): Illegal sequential statement.
# ** Error: H:/computerorganisatie/work/configflip.vhd(44): Cannot assign to signal 'd_in'.
# ** Error: H:/computerorganisatie/work/configflip.vhd(45): Illegal sequential statement.
# ** Error: H:/computerorganisatie/work/configflip.vhd(52): VHDL Compiler exiting
iemand een idee?
alvast bedankt
  • whoami
Hallo, lees even de PRG Quickstart.
Zowiezo zijn dat compiler errors, en deze zou je toch makkelijk zelf moeten kunnen fixen:
foutmelding goed lezen, en evt manual erbij pakken, en zien wat er syntactisch niet correct is.
https://fgheysels.github.io/
  • NMe
  • Laatst online: 29-09 10:17
NMe
Quia Ego Sic Dico.
En nu kunnen wij jouw code gaan debuggen? Zo werkt het hier dus niet, zie ook Programming Beleid - De "quickstart" en Programming FAQ - Debuggen: hoe doe ik dat? :)
Je zal eerst eens uit moeten zoeken wat die foutmeldingen betekenen en daarna eens kijken in welke zin die meldingen van toepassing zijn op je code. Een simpel debugproces brengt je een stuk verder, daar kunnen wij je verder ook niet mee helpen. ;)
Of anders doe ik eerst even een F5. :P
[ Voor 5% gewijzigd door NMe op 10-01-2007 14:28 ]
